Page 19 of 118 FirstFirst ... 91516171819202122232969 ... LastLast
Results 361 to 380 of 2351
    #361
    Quote Originally Posted by kev09 View Post
    Dieseldude, I have toyota revo with a 2LII-T in it..Just wanna know if its possible to convert a 2l-t into a 2l-te?? or swap nlng sa 2l-te?
    2LII-T na ba yung revo pagbili mo?
    #362
    Quote Originally Posted by Dieseldude View Post
    ito sir website nila...
    http://www.bioactiv.com.ph/
    Bale approved fuel enhancer sya.... Salamat sa information. Binisita ko na ang Bioactiv website. Mukhang ok naman ang produkto nila.
    Pinatataas ko lang %blend ng biodiesel na kinakarga ko kaya naglalagay ako ng additive....
    Thanks for the reply.
    Pag balik ko sa pinas, mga October eh magpa check ako ng usok or compression test. Meron ba sa Isuzu Quezon Ave? or sa Inyo?
    Mga magkano kaya yun sir? Wag mo na muna isipin ang compression test dahil model 2007 ang Sportivo mo. Batang bata pa yan. Siguradong maayos ang compression pressures mo. Btw, nasaan ka ba?
    Art
    Nasa Russia ako ngayon sir./.....bali ang work ko dito eh 6 weeks nasa russia ako then 3 weeks eh nasa pinas naman ako for vacation.
    Thank you ulit sa reply.
    Art
    Sep 2006
    #363
    Art
    Mabuhay ka kabayan. Parang maganda yata ang work jan mo dahil pwede ka makapagbakasyon every 6 weeks.
    Good luck, chaka ingat lang,
    Dieseldude
    Sep 2006
    #364
    Dieseldude, tanong ko lang po. I had my 4 nozzles replaced and installed by Betan-Makati last month (my engine is 4M40) to correct the black smoke. After the installation, wala na ang smoke. However, ngayon mahirap magstart pajero ko kahit maiinit na ang engine (so i think not the glow plugs ang reason). What i did, I stepped on the gas pedal (maximum to the floor), with this, magstart na siya after few revolution of the starter motor (around 2-3 seconds). what do you think is the problem?
    Possible problems are:
    1. glow plugs or preheat system
    2. weak battery if your cranking speed is low
    3. air in your fuel susction lines
    4. injection pump
    5. low compression pressure
    Btw, ano na ba ang mileage ng Pajero mo? Your engine needs glow plug assist even when hot if it's mileage is high due to normal wear on the piston rings and liners. High mileage = low compression pressure = low ignition temperature.
    Start with 1, 2, & 3 before considering 4 & 5.
    Good luck,
    Dieseldude
    Sep 2006
    #365
    Dieseldude * what was the common trouble of CRdi engine?
    We have only serviced a few CRDIs as these engines are still quite new. So it is still quite early for me declare a common problem on the various systems.
    But from my limited experience, I beleive that "water in fuel" is the killer, which affects the high pressure pump. It cannot deliver enough flow and pressure. Symtoms are no start, hard start, and hesitation after a gear shift.
    By the way, do you have a common rail diesel? What's your make and model?
    Last edited by Dieseldude; September 9th, 2008 at 01:22 AM. Reason: add information
    Sep 2006
    #366
    Yes it is possible. It fits perfectly as size is almost identical.
    However, modification is not easy. You will have to get a good running 2LTE, complete with ECU, harnesses, throttle position sensor, fuse box, starting relay, etc.
    If you lack the experience and know-how, I don't suggest you try it. The mechanical 2LT's power is sufficient for the Revo anyway.
    Jun 2007
    #367
    Dieseldue, thank you for the reply.
    Ang mileage ng Pajero ko is 80km. I wonder also, I have been replacing glow plugs every six months (starting last year) and mitsubishi parts pa, which cost 1.8k/pc. do you think something is wrong with the electrical, that's why the glow plugs got busted easily?
    Last, how to check the battery if it needs replacement? kasi kaya pa nitong magstart. Many thanks for your help
    Sep 2006
    #368
    Ang mileage ng Pajero ko is 80km. Your compression should still be fine at 80k kms, not unless your engine has experienced overheat condition/s.
    I wonder also, I have been replacing glow plugs every six months (starting last year) and mitsubishi parts pa, which cost 1.8k/pc. Mahal talaga ang original Mits glowplugs, but they last long.
    do you think something is wrong with the electrical, that's why the glow plugs got busted easily? Possibilities are:
    1. You may be buying fake glow plugs.
    2. Preheat system is defective, voltage is applied to the plugs on an extended duration.
    3. Injection pump may be causing a hard start condition. Prolonged and repeated starts puts a heavy strain on the glow plugs as they are cycled and energized everytime you do a start.
    Last, how to check the battery if it needs replacement? kasi kaya pa nitong magstart. Many thanks for your help. Low cranking speed is a good indicator of a weak battery if your starter, bat cables and terminals are in good condition. Motolite etc. can check your battery. You can also do a voltage drop test while cranking.
    Do you experience hard start and hesitation during morning starts?
    Jun 2007
    #369
    Dieseldude, thank you for the reply. You are really of help . Just an update, I removed the glow plugs last night, to my surprise 2 are not working and the other 2 are still fine.
    Is there a possibility that location of the glow plugs matters? Of the two glow plugs that are still working, one is already +10months old, while the other one is still 3 months old (kasabay it sa pag-install sa other 2 busted glow plugs). I wonder why this +10 month old glow plug outlives the others? and its located in the 2nd cylinder (starting from the front). Does location matters? or the "new" glow plugs which are installed at the same time were just fake?
    Ok, ill check with the preheat system. Tama kaya if i test the preheat system like this? Ill remove one glow plug (the one still working), attached to the wire leading to the glow plugs, and turn ON the keys (but not crank the engine). If the glow plugs remains glowing after the heater light turns off, therefore the preheat system is defective because it extended the duration of heating the glow plugs = short life of glow plugs?
    Hopefully the injection pump is still working
    Ok, ill do the drop test
    I experienced hard starting in the morning and also in the afternoon. This morning what i did, before cranking, i stepped on the gas pedal to the floor + turn ON the keys twice (without cranking, just to extend the heating of the glow plugs ), and cranked. Once lang ang cranked ko (around 2 seconds) umanaadar kaagad ang engine with 2 hiccups (but I stepped the gas mid-way, so na wala na ang hiccup)
    Many thanks again for the inputs.
    Sep 2006
    #370
    Of the two glow plugs that are still working, one is already +10months old, while the other one is still 3 months old (kasabay it sa pag-install sa other 2 busted glow plugs). I wonder why this +10 month old glow plug outlives the others? and its located in the 2nd cylinder (starting from the front). Does location matter? No, cylinder location does not influence glow plug life.
    or the "new" glow plugs which are installed at the same time were just fake? I'm not sure; but this is a possibility. Close inspection might answer your question.
    Ok, ill check with the preheat system. Tama kaya if i test the preheat system like this? Ill remove one glow plug (the one still working), attached to the wire leading to the glow plugs, and turn ON the keys (but not crank the engine). If the glow plugs remains glowing after the heater light turns off, therefore the preheat system is defective because it extended the duration of heating the glow plugs = short life of glow plugs? No, this is not the way. The system may not even preheat if only one working glow plug is hooked up as it will see a wrong resistance value.
    Injection pump may be causing a hard start condition. Prolonged and repeated starts puts a heavy strain on the glow plugs as they are cycled and energized everytime you do a start. Hopefully the injection pump is still working.
    Do you experience hard start and hesitation during morning starts? I experienced hard starting in the morning and also in the afternoon. This morning what i did, before cranking, i stepped on the gas pedal to the floor + turn ON the keys twice (without cranking, just to extend the heating of the glow plugs ), and cranked. Once lang ang cranked ko (around 2 seconds) umanaadar kaagad ang engine with 2 hiccups (but I stepped the gas mid-way, so na wala na ang hiccup) Install 4 good plugs, and check if engine easily starts in the morning. If you still experience difficulty in morning starts, injection pump may have to be checked.
    Many thanks again for the inputs. You are welcome...
    #371
    GOOD DAY DIESELDUDE
    I NEED YOUR HELP, I HAVE A 1997 NISSAN DIESEL eagle series pickup, mileage is 233,XXX. di pa siya na overhaul kasi sabi ko naman wala naman problem sa makina, me hatak naman siya at kayang kaya pang patakbuhin ng 145km/h regular change oil lang lagi ko ginagawa. Eto mga napansin ko at problems ko
    1.MAUSOK siya, pag umaga start ko visible ang blue smoke tapos pag umandar na ng malayo nawawala na. hindi siya makpal ng blue smoke ha tapos pag umaandar na ayun me black smoke na. Minsan may times na walang visible smoke diko alam bakit ......
    1a. Nung pinatingin ko sa calibration hindi sa INJECTION pump ang problem kasi papa calibrate ko sana, sabi nila sa makina daw pa overhaul kona daw kasi nung hinugot yung dip stick me preasure ng usok at nung tinangal yung motor cup. Tama ba siya? na dapat pag tinangal yung dip stick walang preasure ng usok na makikita? estimate nya sakin P50,000 kasi NISSAN daw mahal ang parts 25,000 labor alone excluding parts.
    2. MAYTIMES NA hirap mag start, pag start ko maririneg ko lang "CLICK" pero me kuryenteng pumapasok. minsan after 15-30 min pag start ko ayun ONE CLICK na start na. Minsan pag bhaje ka ng malayo pag pinatay mo kagad ganun nangyayari or pag humtaw ka ng 120km/h pag pinatay mo ayun mahirap start. Kaya pag bjahe ako ng malayo, pag malapit nako sa pupuntahan ko dahn dahan nalang sa takbo then idle ko 3 min bgo patayin...
    2a. Sabi Glow plug daw? considering hindi kopa din napapalitan siya eversince 1997 hehe. Yung battery ko amost bnew pa. Nung test ko sa Motolite Ok naman karga ng kuryente sabi nlang check ko wiring sa starter baka nagalaw pag uma andar
    daily ko na bajahe city lang tlga, kaya hindi siya laspag. normally 60-80km/h lang takbo sa mahal ng gasolina minsan binibirit ko para lumabas yung mga usok.
    THANKS
    Sep 2006
    #372
    GOOD DAY DIESELDUDE
    I NEED YOUR HELP, I HAVE A 1997 NISSAN DIESEL eagle series pickup, mileage is 233,XXX. di pa siya na overhaul kasi sabi ko naman wala naman problem sa makina, me hatak naman siya at kayang kaya pang patakbuhin ng 145km/h regular change oil lang lagi ko ginagawa. Worn out na ang pistons, rings, and liners mo. Normal wear & tear yan dahil sa haba ng tinakbo ng car mo. Makikita mo yan sa compression test.
    Eto mga napansin ko at problems ko.
    1.MAUSOK siya, pag umaga start ko visible ang blue smoke tapos pag umandar na ng malayo nawawala na. hindi siya makpal ng blue smoke ha tapos pag umaandar na ayun me black smoke na. Minsan may times na walang visible smoke diko alam bakit ...... Meron blue smoke sa umaga dahil mababa ang compression. Hindi nasisindihan nang mabuti ang diesel; umaakyat na din ang langis sa piston crown dahil worn out na ang rings and liners. Nababawasan ang bluish smoke sa hot engine dahil nagiimprove ang compression dahil sa thermal expansion ng pistons.
    1a. Nung pinatingin ko sa calibration hindi sa INJECTION pump ang problem kasi papa calibrate ko sana, sabi nila sa makina daw pa overhaul kona daw kasi nung hinugot yung dip stick me preasure ng usok at nung tinangal yung motor cup. Tama ba siya na dapat pag tinangal yung dip stick walang preasure ng usok na makikita? Tama sila. Yung pressure at usok na lumalabas sa dipstick ay compression gasses na lumulusot sa piston rings. Estimate nya sakin P50,000 kasi NISSAN daw mahal ang parts 25,000 labor alone excluding parts.
    2. MAYTIMES NA hirap mag start, pag start ko maririneg ko lang "CLICK" pero me kuryenteng pumapasok. Check battery cables and terminals, check starter. minsan after 15-30 min pag start ko ayun ONE CLICK na start na. Minsan pag bhaje ka ng malayo pag pinatay mo kagad ganun nangyayari or pag humtaw ka ng 120km/h pag pinatay mo ayun mahirap start. Kaya pag bjahe ako ng malayo, pag malapit nako sa pupuntahan ko dahn dahan nalang sa takbo then idle ko 3 min bgo patayin... Hard starting talaga ang diesel engine kung mahina na ang compression.
    2a. Sabi Glow plug daw? Possible ito.... considering hindi kopa din napapalitan siya eversince 1997 hehe. Malaking tulong ang glow plugs sa pag start ng makinang mababa ang compression. Yung battery ko amost bnew pa. Nung test ko sa Motolite Ok naman karga ng kuryente sabi nlang check ko wiring sa starter baka nagalaw pag uma andar
    daily ko na bajahe city lang tlga, kaya hindi siya laspag. normally 60-80km/h lang takbo sa mahal ng gasolina minsan binibirit ko para lumabas yung mga usok. Hindi laspag ang body, pero worn out na ang engine. Malaki na ang pakinabang mo sa engine mo. Dapat lang gastosan mo ito kung gusto mo pa itong itago at gamitin nang matagal.
    THANKS
    Maayos ka magalaga ng sasakyan kaya umabot ito ng 233k+ kms. Bihira ang umaabot dito.
    #373
    GOOD DAY Thanks You so much sa mga replies it was really a big help sakin.
    So worn out napala siya kung ganun talaga, malayu na bhaje sa metro manila lang naman karamihan at ako personally nag ddrive kaya maalaga ako hehe. Salamat kung ganun na umabot ako sa 233,XXX km bihira lang pala yun? bakit? naman....
    My Queztions are now:
    1. Engine Overhaul talaga ang dapat kong gawin?
    2. Tama ba yung quote nila na P50,000.00 ang (est) nila for the parts/labor?
    3. Glow plugs cost est 200/pc (4) daw kailangan hindi ba complicated palitan yun? sabi kasi ng iba complicated daw kelangan balance ang pag balik.
    4. San ako mag papa compression Test? MagKano?
    5. Any idea san mura magpa ayos para ma budjet.
    6. Pag ganun worn out na mga PISTON RINGS LINER, does it affect my fuel consumption? So far kasi normally 10-11km/L ang konsumo ko city driving 60-80km/h low rpm shfting, NUng nag tagatay kami MANDALUYONG VIA SANTAROSA EXIT 15km/L ang record ko, this month lang 600 pesos lang ginastos ko approx 116 total KM.
    So far yun lang talaga ang problems ko, Ang body wala ko problem walang kalawang Yung bed rust at water proof pa at my roller slide cover. Papa paint ko lang hood faded na kasi kulay hehe P2.300 daw.
    Thank you Very Much
    Sep 2006
    #374
    GOOD DAY Thanks You so much sa mga replies it was really a big help sakin. You're welcome.
    So worn out napala siya kung ganun talaga, malayu na bhaje sa metro manila lang naman karamihan at ako personally nag ddrive kaya maalaga ako hehe. Salamat kung ganun na umabot ako sa 233,XXX km bihira lang pala yun? bakit? Dahil maraming car owners na gamit lang nang gamit ng car, pero hindi nila inaasikaso ang regular car service, gaya ng change oil and filters, atbp.
    1. Engine Overhaul talaga ang dapat kong gawin? Yes. Pero pwede mo idelay ang overhaul kung maayos ang starting ang pickup mo.
    2. Tama ba yung quote nila na P50,000.00 ang (est) nila for the parts/labor? Medyo fair price na yan kung genuine Nissan parts ang gagamitin, at kung magaling ang mekaniko at machine shop.
    3. Glow plugs cost est 200/pc (4) daw kailangan. Bakit mo papalitan? Sira na ba ang glow plugs? Hindi ba complicated palitan yun? sabi kasi ng iba complicated daw kelangan balance ang pag balik. Hindi naman complikado palitan yan sa marunong gumawa.
    4. San ako mag papa compression Test? MagKano? Try mo sa Nissan dahil sila ang may adapter tools. Sila din ang may specifications ng passing and minimum acceptable compression pressures.
    5. Any idea san mura magpa ayos para ma budjet. Meron akong kilalang magaling, pero medyo mahal singil nya.
    6. Pag ganun worn out na mga PISTON RINGS LINER, does it affect my fuel consumption? Not so much on fuel consumption. But oil consumption will gradually increase as the piston rings wear out. So far kasi normally 10-11km/L ang konsumo ko city driving 60-80km/h low rpm shfting, Nung nag tagatay kami MANDALUYONG VIA SANTAROSA EXIT 15km/L ang record ko, this month lang 600 pesos lang ginastos ko approx 116 total KM.
    Thank you Very Much
    Advice ko lang sayo. Pumili ka ng marunong at honest na mekaniko. Baka masayang lang ang parts na bibilhin mo, or mag-ulit ka pa nang overhaul kung palpak ang unang gawa. Kadalasan, mas mahal ang kinalalabasan ng overhaul na ginawa ng mekaniko napakamura ang singil.
    #375
    were u able to resolve this issue? pano po? i have the exact same problem po.
    Quote Originally Posted by GundamWing View Post
    nakakapag cause din ba ng white smoke not the normal gray kapag wala sa proper setting ang fuel injection system yung parang hilaw yung burn? pansin ko kasi din sa ride ko kapag medyo cold pa yung engine tapos medyo hirit ng konti sa accelerator lumalabas sya pero nawawala din kapag medyo matagal na sya nagamit, madalas din sinasabi ng mga isuzu 4ja1 owners na normal yung white kapag cold pa engine but mine is thicker white smoke. I checked my oil everyday morning kung nagsusunog na sya ng oil pero consistent naman yung level ng oil nya nasa max level. Im also thinking that it might be my valve seals pero im not sure or yung mga naliligaw na nahihigop na oil from the air breather galing sa valve cover direting to the air intake. Kakapaadjust ko lang din ng valve clearance ko last two weeks pino naman yung andar. medyo mahina din hatak and 8km/L consumption ko pero tyaga lang muna ako kasi wala pa budget kung magpapa calibrate ako, sana meron ng christmas bonus hehehe
    #376
    FOLLOW UP LANG:
    1. Wala naman Problem ako sa makina its just mausok lang talaga so you mean pwedeng hindi ko ipa overhaul, ano gagawin ko? palit lang? anung mga parts papalitan lang para maka mura? saan nabibile mga yun? para maka ikot ikot ako ng murang parts.. any idea kung magkano aabutin? gusto ko lang ma tangal yung usok sir....
    2. Sa glow plug wala naman ko problem kala ko lang kailangan ko lang palitan so di rin pala kailangan..
    Sep 2006
    #377
    White smoke when cold, and which lessens as engine temp rises is most often a sign of poor compression. Compression improves as temp increases due to thermal expansion of pistons. To be sure, ask Isuzu to perform a compression test on your engine when cold.
    Ano mileage mo?
    Nake experience na ba ng overheat ang engine mo?
    Check injection pump to engine timing. Has your pump been previously repaired, removed, and/or reinstalled?
    Madali mo din makita kung marami ang oil gasses sa blowby pipe/hose. Try mo tanggalin ang hose or dipstick. Pag nabawasan ang white smoke, huli mo na ang cause. Piston ring na ang problema kung ganyan, dahil ang blowby gasses ay nanggagaling sa compression gasses na nakakalusot sa piston ring and sleeves.
    Sep 2006
    #378
    FOLLOW UP LANG:
    1. Wala naman Problem ako sa makina its just mausok lang talaga so you mean pwedeng hindi ko ipa overhaul, ano gagawin ko? Gamitin mo lang muna kung hindi mo pa ipa overhaul.
    2. Anung mga parts papalitan lang para maka mura? Magkakaroon ka ng idea nito after the compression test. Ang total parts required naman ay makikita lang pag nabuksan na ang engine.
    3.Saan nabibile mga yun? para maka ikot ikot ako ng murang parts.. any idea kung magkano aabutin? Sorry, no idea at the moment. Ang choices mo lang naman ay sa Nissan mismo or replacement parts sa Banawe.
    4. Gusto ko lang ma tangal yung usok sir.... Mag second opinion ka sa Nissan para makasigurado ka kung saan nanggagaling ang white smoke. Kung failed na ang compression, the only solution is engine overhaul. Dapat masaya ka dahil binigyan ka nito nang napakahabang servicio, 233k kms.
    5. Sa glow plug wala naman ko problem kala ko lang kailangan ko lang palitan so di rin pala kailangan.. Good, wag mo na palitan. Pa check mo din ang glow controller. Maski OK ang plugs, hard starting ang engine kung kulang ang heating time.
    Good luck
    #379
    HEHE ok sir salamat yung takbo ng pickup para pa din bago kaht ang interiors ok lahat. pero panu ko malalaman pag kailangan na ipa overhaul? pag nag pa compression test nako or pag iba na ang takbo ng makina at tunog? salamat ng marami this sat bjahe kami sa san juan batangas sa rest house ng barkada ko at gagamitin ko ang pick up ko
    #380
    sometimes, even with a loose compression, the fuel consumption is not that bad. specialy on m/t's.
    it's still a mystery to me, sometimes, two same diesel rides, the one is smokey and loosy compression, and the other ride's smoke is barely seen. yet both consumes fuel almost the same.
    to see if your compression is right, first you need to know what model/year your engine is. so the mechanics will compare the factory value with yours.
    ex: engine: TD25
    engine: SD25
    a compression test will give an idea, but it doesn't tell everything. ang hirap talaga malalaman ang totoong kundisyon ng sasakyan.
Diesel Fuel Injection System Help Desk
