Dieseldude, I have toyota revo with a 2LII-T in it..Just wanna know if its possible to convert a 2l-t into a 2l-te?? or swap nlng sa 2l-te?
Yes it is possible. It fits perfectly as size is almost identical.
However, modification is not easy. You will have to get a good running 2LTE, complete with ECU, harnesses, throttle position sensor, fuse box, starting relay, etc.
If you lack the experience and know-how, I don't suggest you try it. The mechanical 2LT's power is sufficient for the Revo anyway.
