Yung Amaron ko sa daily driver lasted 23 months only. 2 months after ng warranty.
Then switched to Panasonic that lasted 35 months. Replaced with another Panasonic. [emoji4] at sana umabot ng 35months din
Is there a difference between gas or diesel engine in the life span of the battery? Because diesel requires more amps during startup and might cause the battery to deteriorate more compared to gas.
Iirc mas demanding ang diesel cars kaya mas tumatagal talaga battery with gas fed engines. Diesel cars need more oomph to power the cranks as they are compression type.
Fasten your seatbelt! Or else...Driven To Thrill!
Guys I don't really fancy posting about work so let me start and end with this. Energizer has only been in the market for 2+ years. Too early to tell if it will perform better or worse than Amaron. And yes it was under the same company as Amaron's past technical partner, Johnson Controls (now Clarios). Varta and Optima were under JC in the past as well. Main differentiator would be the EFB and AGM batteries. Standard start/stop cars require EFBs. Those with regenerative braking and/or luxury makes usually require AGMs.
baka yun short trips mo bro, traffic tapos di masyado mainit yun byahe. long enough yun byahe to charge the battery, and cool enough not to degrade the battery.
Sent from my Redmi Note 9 Pro using Tsikot Forums mobile app
May diesel specific battery ba doc?
The 2003 vios and the 2015 innova both use amaron pro 2sm. Hehe
Sent from my MI MAX 2 using Tsikot Forums mobile app
Alam ko yung battery ng kotse has a specified size per car. It’s not based on the engine fuel.
The biggest battery sizes I have used is a DIN74 and DIN66. I used it on the Fiesta Ecoboost which requires a DIN66 size. DIN74 has almost the same specs as the DIN66 but just a bit taller (few millimeters). These battery sizes are even bigger than what is required on the FXT and Sorento gas. The Jetta TDI uses a DIN60 or DIN55 which is about the size of 1SM/NS50.
battery manufacturers do make heavy duty batteries for larger diesel engines.
the larger engines need more starting amps kasi.
but i believe that many of us use ordinary automotive batteries in our diesel auvs, mpvs and suvs, because the engines are not that large, naman.
technology has probably blurred the border between the smaller diesel-engine batteries and gasoline-engine batteries.
when the battery of my sedan is replaced, i opt for the next smaller size. by my experience, the battery life therein is not shortened, naman.
Ah... Got me worried there. I just realized that 2 years ago, on this day, i purchsed the battery for the innova.
Byebye warranty na bukas. Hopefully naman di biglang masiraSent from my MI MAX 2 using Tsikot Forums mobile app
add ko lang sa post ni bro yapoy,
sabihin mo dapat under warranty pa, ganun kasi ginawa ko dun sa pinagbilihan ko. kaya sabi ni kuya nag test malakas pa battery.
Which amaron is often being referred to in this thread? Hi life, go or pro. I'm being offered hi life for 4900 and go for 4000 net of 200 trade in. I'm now coming off Emtrac, after several Motolite golds. Emtrac lasted longer than my Motolites, but I don't know it's equivalent with Amaron.
Sent from my Mi A1 using Tsikot Forums mobile app
