Page 105 of 115 FirstFirst ... 55595101102103104105106107108109 ... LastLast
Results 2,081 to 2,100 of 2297
    Cathy’s record breaker is Hi-life.
    hahaha! I am impressed, you remembered pa that it's hi life! My second Amaron turned 5 yrs old na! I am not sure if I should wait for it to die rin but then my 11th gen is an automatic so I can't make tulak if it dies when I am out.
    Apr 2005
    #2082
    How can you break your record kung papalitan mo agad!
    Mar 2021
    #2083
    Which amaron is often being referred to in this thread? Hi life, go or pro. I'm being offered hi life for 4900 and go for 4000 net of 200 trade in. I'm now coming off Emtrac, after several Motolite golds. Emtrac lasted longer than my Motolites, but I don't know it's equivalent with Amaron.
    Sent from my Mi A1 using Tsikot Forums mobile app
    Ito equivalent ng Motolite to Amaron models:
    Excel - Hi life Pro
    Gold - Hi life
    Enduro - Go
    Usually yung middle models ang mabenta. Motolite Gold/Amaron Hilife.
    Jan 2016
    #2084
    Excel - Hi life Pro
    Gold - Hi life
    Enduro - Go
    Salamat Sir
    Hahaha! Super sulit na 5 yrs but I am again tempted to see how long it will last
    Feb 2018
    #2086
    How about if you buy the spare and store it in the trunk so you can replace the battery immediately once it dies? is it practical? or nah?
    #2087
    a battery "ready to go" deteriorates with time, even if it is not used.
    if one wants a replacement battery on hand for justin (just in case), one can have a battery, but with the electrolyte not yet poured in. this allows the battery to sit there for many years, with minimal deterioration. you pour the electrolyte into the battery when you need it.
    Jan 2016
    #2088
    Another problem would be that it shortens the warranty, it's already running the moment you bought it
    #2089
    that is correct.
    that is why i wouldn't recommend it to myself.
    but it does have its uses...
    like when one is in the boondocks...
    Dec 2014
    #2090
    Umabot sakin 44 months (hindi pa ubos pero nagpalit nako)
    Twice a week ko lang ginagamit (before covid) pang mall and church lang. Then nag covid, mga twice a month na lang pang grocery. Not bad!
    Pero ako na ang sumuko wala na ako peace of mine. Hindi ako sanay kasi before lagi ako motolite na laging sakto tapos na warranty na uubos.
    Nag palit nako kanina amaron ulit
    meron naman mobile delivery ang amaron. or wala dyan sa lugar mo ?
    Dec 2014
    #2092
    may malapit dito samin, dinaan ko na may pinuntahan din kasi ako.
    #2093
    mga ka-tsikot ask ko lang. 2015 fortuner MT 2kd-ftv. stock wala naman ako accessories na power hungry like a killer sound system.
    worth it ba mag 3sm pa na battery or balik 2sm uli from the factory? amaron pa din. libo din kasi price difference. salamat
    Feb 2019
    #2094
    Yes the bigger the better you can get 3smf pro if your budget permits.
    Jan 2009
    #2095
    If the stock battery is 2SM, you'll be fine with a replacement 2SM. Practical advantage lang ng 3SM is the bigger reserve capacity and cranking Amps. Depending on actual use, the additional capacity may offer some insurance in starting the engine even if an accessory was left on overnight, for example, or if you run into an engine issue that requires you to crank it longer than usual.
    It's up to you if you feel that the extra capacity is worth its weight (literally) in Pesos.
    FWIW, I have a 3SM Amaron in my 2.5 Innova G.
    #2096
    issue with installing larger battery: kakasya ba? will the battery footprint be accomodated? will there be enough room above, so's the metal hood won't touch the terminals?
    will a larger battery result to longer battery life in that vehicle? i do not know.
    the larger CCA might result in chronic under-charging, which predisposes to faster battery deterioration.
    i do not know.
    in my non-diesel sedan with only a stock radio as electrical toy,
    i install the next smaller size battery.
    over the years, i did not perceive a shorter lifespan.
    Mar 2021
    #2097
    Stock sound system, definitely no need for a bigger battery. Will just be a waste of money especially if a few thousand pesos difference.
    May chance pa na hindi aabot mga cable sa terminals ng bigger battery.
    Jan 2012
    #2098
    I would just stick with using the same battery size
    Unless there is no stock of the correct battery and there is no choice
    #2099
    From what I understand naka 3SM na ata si babkalakal ngayon, so it will definitely fit, and the alternator is definitely capable of charging a 3SM battery.
    His question is if it's worth it to continue using a 3SM or go back down to stock size of 2SM.
    If the car is frequently used, there are no accessories with big power draw, and accessories aren't operated on battery for extended periods I vote to save the money and size back down.
    #2100
    he can answer his own question.
    all he has to do is to see if that larger battery did last longer than the regular-size battery.
Amaron battery
