Page 104 of 115 FirstFirst ... 45494100101102103104105106107108114 ... LastLast
Results 2,061 to 2,080 of 2297
    #2061
    That falls within the normal expected. Yours seem to fall on the exception/anomaly, ma'am. How many kms do your cars clock yearly?
    More or less 5k
    Haha well compared to yours. Hindi normal yung sayo hehe. Ok na ako with that, it exceeded its supposed lifespan with the 21 months warranty. Whe I was still using Motolite usually sakto with the lifespan then palit na.
    Hahaha. Pero weird kasi sa Motolite it dies just after warranty din pero sa Amaron haba ng lifespan
    Mar 2021
    #2062
    Yung Amaron ko sa daily driver lasted 23 months only. 2 months after ng warranty.
    Then switched to Panasonic that lasted 35 months. Replaced with another Panasonic. [emoji4] at sana umabot ng 35months din
    #2063
    More or less 5k
    one of our cars was highway driven, much of the time.
    over 4 years tumatagal ng motolite sa kanya.
    #2064
    More or less 5k
    That's less than half my usual. Glad yours lasted that long.... can't expect the same off any brand out there with our usage. Got a Panasonic on its 39th month & still kicking....for how much longer? Dunno. Can't complain.
    Feb 2019
    #2065
    Is there a difference between gas or diesel engine in the life span of the battery? Because diesel requires more amps during startup and might cause the battery to deteriorate more compared to gas.
    Iirc mas demanding ang diesel cars kaya mas tumatagal talaga battery with gas fed engines. Diesel cars need more oomph to power the cranks as they are compression type.
    Jan 2009
    #2067
    But this is more or less compensated by Diesel cars having bigger and usually more robust batteries.
    #2068
    Guys I don't really fancy posting about work so let me start and end with this. Energizer has only been in the market for 2+ years. Too early to tell if it will perform better or worse than Amaron. And yes it was under the same company as Amaron's past technical partner, Johnson Controls (now Clarios). Varta and Optima were under JC in the past as well. Main differentiator would be the EFB and AGM batteries. Standard start/stop cars require EFBs. Those with regenerative braking and/or luxury makes usually require AGMs.
    #2069
    i must confess.
    i use automotive (gasoline) batteries for my diesels.
    they still manage to die a couple of weeks after warranty lapses.
    They have to be, bugbog sa biyahe eh hehe. Kaya yung motolite kita mo yung mga diesel batteries nila na pang-harabas, truck master ang product code.
    #2071
    Quote Originally Posted by gls2001 View Post
    Been waiting for the Motolite Excel on the econobox Mirage to conk out to be replaced by an Amaron. Surprisingly 3 years na and ayaw pa bumigay and puro short trips lang yun daily(10km) for the last 3 years. Marami na shops carrying Amaron. Price wise is the Energizer at par in pricing with Amaron on an equivalent spec’d battery?
    baka yun short trips mo bro, traffic tapos di masyado mainit yun byahe. long enough yun byahe to charge the battery, and cool enough not to degrade the battery.
    Sent from my Redmi Note 9 Pro using Tsikot Forums mobile app
    #2072
    Pwede, 8am normally ang byahe then 5:30pm na uwi with 10-15min traffic per one way trip(5km one way for a roundtrip of 10km daily)
    Jun 2005
    #2073
    i must confess.
    May diesel specific battery ba doc?
    The 2003 vios and the 2015 innova both use amaron pro 2sm. Hehe
    Sent from my MI MAX 2 using Tsikot Forums mobile app
    #2074
    Alam ko yung battery ng kotse has a specified size per car. It’s not based on the engine fuel.
    The biggest battery sizes I have used is a DIN74 and DIN66. I used it on the Fiesta Ecoboost which requires a DIN66 size. DIN74 has almost the same specs as the DIN66 but just a bit taller (few millimeters). These battery sizes are even bigger than what is required on the FXT and Sorento gas. The Jetta TDI uses a DIN60 or DIN55 which is about the size of 1SM/NS50.
    #2075
    Quote Originally Posted by sirkosero View Post
    battery manufacturers do make heavy duty batteries for larger diesel engines.
    the larger engines need more starting amps kasi.
    but i believe that many of us use ordinary automotive batteries in our diesel auvs, mpvs and suvs, because the engines are not that large, naman.
    technology has probably blurred the border between the smaller diesel-engine batteries and gasoline-engine batteries.
    when the battery of my sedan is replaced, i opt for the next smaller size. by my experience, the battery life therein is not shortened, naman.
    Jun 2005
    #2076
    Ah... Got me worried there. I just realized that 2 years ago, on this day, i purchsed the battery for the innova.
    Byebye warranty na bukas. Hopefully naman di biglang masira
    Jan 2008
    #2077
    try mo dalhin dun sa pinagbilhan mo.. sabihin mo parang mahina na yung karga.. tapos pa load test mo.. pag bumagsak sa load test, dapat palitan nila yan.. hehe
    #2078
    add ko lang sa post ni bro yapoy,
    sabihin mo dapat under warranty pa, ganun kasi ginawa ko dun sa pinagbilihan ko. kaya sabi ni kuya nag test malakas pa battery.
    Jan 2016
    #2079
    Which amaron is often being referred to in this thread? Hi life, go or pro. I'm being offered hi life for 4900 and go for 4000 net of 200 trade in. I'm now coming off Emtrac, after several Motolite golds. Emtrac lasted longer than my Motolites, but I don't know it's equivalent with Amaron.
    Sent from my Mi A1 using Tsikot Forums mobile app
    Apr 2005
    #2080
    Cathy’s record breaker is Hi-life.
Amaron battery
