meron delivery.. pero parang per distributor yata.. not like motolite na parang centralized yung delivery nila then refer nila sa nearest branch
Yes but yapoy86 is right, you have to call the dealer directly
Hindi ko naisip. Pag PMS ko sa casa pa check ko battery, pag mahina na i replace ko na rin. Buti nag offer naman Mom ko to pay pero I told her wag na kasi siya naman bayad ng PMS [emoji23]
Yeah pero buti dumami na Amaron dealers [emoji4]
Hi life lang binibili hinde yun pro?
Another HiLife user here.
It has more than enough watt-hours and CCA to handle the car so IMO no reason to go Pro.
Less chance of heat (and hopefully not fire) pa since there will be fewer cells packed into the same volume.
I'm tempted to see how long my Gen 11 battery lasts 😂 Mabilis lang naman tumawag ng Amaron for delivery, hassle lang kung abutan ng gabi sa labas. I don't wanna be forced to buy Motolite. It's going 5 yrs na. What if casa says malakas pa naman?
Bili ka Ng pang jumpstart, Yun powerbank type
7 Mai Car Jump Starter Portable 111 mAh Type-C Power Bank
Tested Kuna sa Montero at innova diesel. Iwas hassle.
Sent from my Mi A2 using Tapatalk
I always check my alternator charge and the moment when I start the car and if it feels a bit different (hard starting) I change the battery right away. I know it will still last for about a week but better be safe and sure. I just had my cable booster on my car trunk.
1. cost. it is easy to put up with it, if one does not have the money to buy a new battery. as i recall, in our younger years, we would push-start the car for 1-2 months, before finally coming up with the money for a new battery. well... re-built battery. it's cheaper than a brand new battery by a couple of hundred... 200 hundred bucks was already big money back then.
2. ignorance re. the nature of dead battery syndrome.
dati di pa uso ang jump starter... sa umaga pag ayaw mag start i'd charge the battery with a 12V charger for several minutes -- just enough power for the starter to crank then let the alternator continue charging the battery
i'd drive without aircon para mas mabilis mag charge haha
then later in the day pag balik sa kotse fingers crossed sana mag start
the things i used to put up with
doubledouble.
