Results 101 to 110 of 2382
- Dec 2002
- 2,335
- May 2007
- 70
May 19th, 2010 06:14 AM #102
May 19th, 2010 11:06 AM #103
Gary, ganda ng ginawa mo. :thumbup: Maganda rin yung GINAWAN mo. :2thumbsup: :drool:
hehehehehe
- Dec 2002
- 2,335
May 22nd, 2010 03:10 PM #104my latest: Ford Focus TDIC 2007, diesel power! all oem setup. FXR, Philips, Matsushita. I am very happy with the results kahit ang hirap gawin. B)
this shroud was made for this headlight, hehe. saktong sakto and mukhang oem.
will retrofit the fogs neto soon using 3000k bulbs with mini hid projector H1.
- Dec 2002
- 2,335
May 25th, 2010 01:09 PM #105bolt on projector sa EK. These projectors are modified to improve light spread and also to have a sharper cutoff. The bulbs and ballasts are non-oem but with a one year warranty. Less than one day rin ang retrofit na to. This package is for peeps asking me to offer a package na mas mura sa oem but output is still good in terms of width and intensity. Of course oem is still best but this is a good retrofit for a start. This will outperform any bolt on projector in the market right now. Output pictures mamyang gabi or bukas.
with mini gatling shroud
with Gti shroud
with Sclass shroud
- Dec 2002
- 2,335
May 26th, 2010 10:02 AM #107starex: yup ok nga yun. Did several EK's na ganyan ang shroud and ok lumabas. Kmusta retro mo?
- Jan 2008
- 1
May 29th, 2010 03:12 AM #109
good am sir! may nagawa na kyo hid retrofit for an oldschool mazda b-series pickup truck? same headlamp housing po to ng lumang toyota hilux, isuzu fuego, l300 fb, etc.. what parts po ang ilalagay i.e. shroud type, fx/fxr, ballast and other hardware? galing ng mga gawa nyo!pa PM po quote. thanks!azzkkr2600
- Dec 2002
- 2,335
May 30th, 2010 11:01 PM #110Ok here are the initial output pix of my bolt on projector. I was suprised to see the output nung bolt-on projector side by side sa output ng fxr. The width and intensity is almost the same! You can see it sa pictures. Actually some experienced retrofitters have posted already similar findings but I had to see it myself. The foreground output of the bolt on is actually thicker although in road conditions not so much effect neto. Anyways the bolt on used H1 aftermarket bulb na 4300k and the FXR has Philips 4300k na OEM. Same ballasts for both.
Pros/Cons
H1
Advantages:
Price
Mas madali sa actual retrofit (less than one day)
Thicker output so more foreground lighting
Disadvantage:
Aftermarket lang ang bulb and ballast na pde gamitin so long term reliability is less vs. the FXR with oem setup
Output of aftermarket bulb is less crisp/clear vs. Philips
Projector needs tweaking to get better cutoff
FXR
Advantages:
Best lighting performance in terms of output ng bulb and stability ng ballasts.
Best sa reliability. Bulbs will last 4-5 years, ballasts as long as the car. (Installed a 1st
Gen Matsushita Ballasts, 2nd hand and more than 5 years na
wala pa rin problema)
Better build quality, no adjustments needed.
Ability to overdrive the bulbs to 55w, hehe.
Disadvantages:
Price
Mas matagal retrofit
Size is bigger
Will post road output in the next few days.
This pic shows the width:
Hyundai Santa Fe GLS 2024
Tsikot Hyundai Registry
