Page 111 of 120 FirstFirst ... 1161101107108109110111112113114115 ... LastLast
Results 2,201 to 2,220 of 2385
    Apr 2014
    #2201
    Hi Sir. Pa-pm naman ng retrofit quotations for Toyota Corollas '93 and 2014 models. Kailangan ba stock unit ang nakakabit? Ung '93 kasi namin is plastic na with moist na din. if you have also foglights for '93 models baka magpakabit na din kami. Thanks.
    Posted via Tsikot Mobile App
  2. #2202
    Quote Originally Posted by tevilo View Post
    clear lens dapat yung sa '93, yung crystal type ang tawag sa banawe dun. Sa fog for the '93 model I need to check first the backside to see kung meron space. 2014 model I will PM you.
    #2203
    Sir gary pa-pm po ang price yung parang hid set-up ng bmw para sa trailblazer. Ty po
  4. #2204
    Subaru Forester 2014 SJ daylight running lights
    Aftermarket but oem quality. Double intensity output, auto ON, MAX output when engine ON> DRL function. LOWER output when you turn ON park lights, automatic. With 6 months warranty. after sales service available after warranty.
    Jul 2011
    #2205
    Sir, i'm wondering kung nakapag clear lens swap ka na ng '14+ Sorento?
    HID low beams with auto-levelling na kasi oto ko, but the fresnel lens makes a very fuzzy cutoff.
    Iniisip ko lang what kind of clear lens ang pwede, kasya kaya sti-r or tsx-r lens, or maybe e55.
    Thanks!
    #2206
    My apologies. Wrong post.
  7. #2207
    Quote Originally Posted by greatauror28 View Post
    Thanks!
    Sa mga korean cars mahirap mag clear lens swap although we can try. Mediocre kasi gamit ng Kia at Hyundai sa hid projectors nila. We can replace the HID projectors with clear lens type tapos bixenon pa and retain the bulbs and ballasts. Parang OEM yan.
  8. #2208
    Another Honda City GM retrofit.
    Client wanted the LED bar on top with angel eyes. Not bad. Our aftermarket setup using OEM 3" projectors including ambient lighting with OEM leds.
  9. #2209
    Corolla big body
  10. #2210
    Nissan Navara HID Projector Retrofit
    We started this LED bar upgrades on automotive headlights and our aim is always to use this and have a result na hindi ricey. Meron headlights lang talaga babagayan and I think this one is a good example. We did a re- retrofit on this Navara coming in with a "bolt on setup" and customer was complaining about very poor output. The actual headlight shroud was touching and pushing the lens outwards. The last shop forced fitted the lens just to seal the HL again. What a horror story! The wiring layout is also a mess. We installed our aftermarket package with a new 5000k D2S bulb na aftermarket which is an alternative sa Osram CBI. Parklight and signal indicators function nung LED bar. We also installed our 70mm fog projector retrofit with vehicle specific brackets.
    old ballast mounting
    old bolt on projector, shroud was hitting the lens and previous shop had to forcibly pushed it together to reseal the whole thing.
    #2211
    Hi gary, did the owner mentioned who did the install. That's really horrible....
  12. #2212
    daylight running lights for Subaru Forester 2014 SJ body, FXT
    with 70mm fog projector retrofit
    Apr 2008
    #2213
    Quote Originally Posted by garyq View Post
    shok: so many things caused this. the HID, sealing, etc
    Have several clients asking for this and we finally developed this:
    Toyota Vios 2014 Daylight Running Lights.
    Get the DRL look of the top of the line Altis on you Vios!
    OEM leds, with complete DRL module for auto ON when engine runs and auto DIM when you turn ON the park lights.
    We also have another type of DRL mounted on the fog light bezel. Also comes complete with DRL modules and oem spec wiring harness.
    boss magkano ung ganito?
    Jul 2003
    #2214
    my monterosport headlights are still stock.
    may bago designs for montero?
    pwde/bagay ba sa montero yun altis type DRL. 4-5 LEDs, not the whole width-height of headlight para mas tipid i think
  15. #2215
    kurt: Let me know if you have some design ideas.
    Jul 2013
    #2216
    hi good evening sir
    ask ko lang po, kaya nyo po kayang gawin sa drl ko po na auto ON kapag nag engage yun transmission ko sa "D" "R" and "N" tapos pag "P" off
    then pag park light auto hina yung buga?
    yun drl ko po kasi yun LED na tag 6 pcs federal brand po...
  17. #2217
    RF: masyado mabago stock wiring harness mo. I dont suggest it.
    Santa Fe DM angel eyes with dual color output. One of the few cars, IMO na bagay aside from BMW.
    Jul 2013
    #2218
    how about timer? lets say 30 secs after magkaron ng power? para sakto after mag start ng engine?
    #2219
    Ang gaganda sir gary. May picture po ba kau na gawa para sa vios 2012?
    Jul 2014
    #2220
    Sir gary
    pm'ed you and also sent you an email.
HID Projector Retrofits by garyq
