can you do that to my 1992 nissan bluebird U12 body?
teamnitro: technically pwede ang retrofit sa kahit anong vehicle basta clear lens yung headlight. Hindi pwede pag fluted or may lines yung lens nung headlight.
jopsiawe: pwedeng pwede sa avanza
may black projector headlights with angel eyes ba para sa honda civic 2010? how much po? salamat.
How much will it cost to retrofit the headlights of my 2002 Honda Civic Lxi. Please PM me the estimate and/or options available. Thank you.
sir,magkano po sa honda vtis 04' model,headlite assembly tapos hid bulbs.ang set up po ay yong stock na low na ilaw lang papa retrofit/hid with hi/lo beam then yong stock na hi beam ko is yon pa rin ang magiging pang flash/pass lite ko.pwede po kaya yon?pm na lang po or dito sa e-mail ko.xrm_explore *y.c.
thanks!!!
obsessed/jops/nplazaro: you got PM guys. email me info*gpglobalph.com or 9178554454
HID Projector Retrofit for Everest 2010
Details:
FX bixenon
Philips 85122+ 4300k, 3200 lumen bulbs
55 watts ballasts (internals of these ballasts are the same as my Matsushita Ballasts)
Cayenne Apollo shroud
Custom Fog light retrofit
65mm sealed projector
D2S bulb
Matsushita ballasts
the everest had plug and play hid on both main hl and fogs which of course had terrible output as glare was all over the place and not so much light on the road. It was a popular brand installed with more than 1 year warranty but one bulb in the fogs exploded and burst in one year (hid bulbs are highly pressurized) and the ballasts were just wire-tired and dangling.
ballasts were now bolted on to the body
supply direct from the battery, 4 fuses and 4 relays. 2 on each side, oem style and the relay sockets are ceramic.
apollo/cayenne shroud
output, fogs only:
fogs and main hl, both bulbs 4300k
left output is limited by a car parked but the output is wide and intense
Please see first page for pricing. Retrofit for main headlamps or fog lamps. Cheaper if bought as a package.
sms 9178554454, info*gpglobalph.com
stock
ballasts were now bolted on to the body:
sir garyq, im using global dmax..nkprojector na xa.what improvements pa pwd gwin sa headlights ko pati fogs.nkHID na projector ko but d ako mxado satisfied.and want ko din sna HID fogs ko..what can u suggest me to do with it? pa-pm nmn po..tnx!
[SIZE=4]Reminder: do not post messages in SMS/TXT shortcut format.
Read the rules.
Ignorance of the rules is not an excuse.
Repeated offenses will lead to banning.[/SIZE]
sir gary pa pm kung magkano abutin pag headlight at fogs pa retrofit ko, pati home service charge. nag kaka fogging headlights ko pag naulan or malamig pero nawawala naman. claim ko sana sa warranty pero mukhang normal naman.
kent: that is not normal especially with that amount of fogging pero we will solve it kung sealant lang problem. will send you a PM
javee: will send you a PM. Halogen projector lang kasi yan. Do be honest with you, mediocre talaga output niyan at best and placing hid bulbs will not really help as the width and intensity ng output dala talaga ng projector design (bowl and lens combo). Meron akong interesting suggestion sayo
*garyq - thank you sir, yan dahilan kaya medyo hesitant akong mag pa retrofit agad. minsan kahit hindi naulan merong fogging, lalo na pag galing akong tagaytay. waiting for your pm, sana matuloy na retrofit ko this month![]()
kent: bro wala dapat fogging kahit magpunta ka sa tagaytay. I use oem headlight sealant from Japan and USA. Will send you a PM asap.
