Pogi ng sticker, bro.![]()
hi sir gary, can i also have a quotation (if possible to retrofit) for a '10 Nissan Livina using 4300k bulb color.
picture of the headlight below for your reference. thanks!
sir gary,pa PM naman po ng quotation nyo sa GE8,magkano aabutin,ganda kase ng pagkakagawa nyo nung kay sir jonas ng Gegarage.tia
Sir,
Can I ask how much for retrofit OEM for 2009 City with Angel Eyes?
Quad projector kaya?
Also for a Vios 2004.
Thanks
(Pls PM me)
just sharing the output of my ride..
Outside(low)
Outside(Hi)
Inside(low)
Inside(Hi)
denki: thanks for sharing
eric: will PM you.hindi pwede quad setup sa City. A pair is more than enough basta tama pagka setup.
Here's my latest. Civic 2010, modified H1 projectors, 4300k bulbs. This is my aftermarket setup and this projector will outperform any "bolt on" projector in the market right now in terms of intensity and width.
The customer wanted the stock mini gatling shroud so eto ang kinalabasan.
got comparo pix nyan sa honda club. mas makapal actually ang H1 ko sa FXR sa gitna. This H1 is the best "bolt-on" projector na nagamit ko and I've tested and used many bolt on projectors. Meron lang ngang modifications na kailangan gawin. Advantage naman ng FXR OEM, ang bulbs na pwede gamitin at mas crisp yung output and also the solenoid mechanism is better. OEM ang design ng FXR so mas maganda but sa output, pareho lang. Only a trained eye will see the minor difference.
starex: bro ano na, tagal na project natin, ma bi-birthday na yan, hahaha. Go for the H1 na, dika magsisi-si.
pwede na yan ken!!! hahaha wag ka na bumili sa hancars.. hahaha
*gary kelan naten i-schedule yung tail lights?
denki: mid-feb most probably bro pwede na.
SG: your thinking of buying the projector headlight na oem? ok naman but among retrofitters, hindi known na maganda output nung projector ng IX. Definitely mas malakas output ng FXR or H1. Ok lang bro
foreground limiter: you dont need to see 2-3 steps away from the bumper when you're driving. you dont actually see that area when you're sitting inside the car. TL, FX/R, H1 have this foreground limiter or the dark spot in front of the bumper so that light output will not bounce back to you that can cause eye strain. Almost all OEM projectors have this. I've personally used TSX, FX,FXR,TL and in the actual road conditions, this is very helpful.
azz: bro mag bi-birthday na rin project natin, hehehe, joke langtuloy na ntin yan, hulugan mo na lang, hahaha.
