Page 14 of 32 FirstFirst ... 410111213141516171824 ... LastLast
Results 261 to 280 of 2385
  1. #1
    mikki: pls check out my website: HIDRetrofit.net - HID Projector Retrofits | LED Lightning Innovation
    ako: not yet but same lang internals lang ng previous model. Halogen projectors, very familiar with how Honda mounts halogen projector. Straightforward lang retrofit nyan.
    - - - Updated - - -
    mikki: pls check out my website: http://www.hidretrofit.net
  2. #2
    Jun 2011
    Hi GaryQ,
    Just saw this post. Can you PM me how much to retrofit headlights of a 2006 Honda Civic 1.8. and a 2010 Nissan X-Trail. Pls include options. My main reasons for adding more light is really just to see more at night especially on drives in the province along long stretches of road. Aside from a brighter headlight, will the retrofit provide a longer and wider distance of light? How much longer and wider? However, can you do the retrofit without producing a lot of glare as this is one of the major causes of accidents in the provinces. Are you open on weekends? Thanks
  4. #4
    Quote Originally Posted by Rallyweapon View Post
    Hi GaryQ,
    Will PM you. The main reason for a retrofit is to allow you to use the higher output of an HID (high intenstity discharge) bulb without causing glare to other motorists. HID bulbs will produce 3x more light than your stock halogen bulb so you can expect that improvement. I have never encountered anyone na ginawan ko who even considered going back to halogen. Retrofit is the perfect solution for you especially for provincial trips. Madami na rin ako na-retrofit na ganyan ang situation. Pls wait for my PM
  5. #5
    2010 Honda City on Stage3 retrofit
    Feb 2010
    Sir Gary, i am planning to retrofit my Nissan Grand Livina. Ito sana yung gusto kong set up.
    Stage 2 Retrofit 3" projectors *in Cooper or Gatling or New F2 *custom mat/flat silver finish shroud, D2s *aftermarket setup, *50w, 4300 kelvin
    I am Not so familiar with the specs so paki correct na lang if possible yung gusto kong set up. Pa pm na din how much aabutin para mapaghandaan ko. Thanks
    Nga pala 2 members of our Livina Club have there cars retrofitted by you si Sir Bobot and Si Sir Dexter. I was impress nung nakita ko yung gawa mo.
  7. #7
    chualie: retrofitted those Livinas. Sent you a PM na.
    Some projects lang over the holiday season:
    The all new Mazda BT50 4x4, same platform ng Ranger na bago. Complete lighting upgrade for the headlights and fogs.
  8. #8
    did several Altis 2012 last week, fresh from the casa. Eto yung isa, stage3 HL plus fogs
    Feb 2010
    ano mas maganda for fogs? projectors on hid o stock halogens?
    in consideration sana with how bad our weather can get and how thick fogs can be...yung wide sana at malayo ang bato, with yellow light ayaw ko kasi ng fogs na whitish o yung common na hid....
    - - - Updated - - -
  10. #10
    hid stock halogen projectors will not give you a considerable increase in output. hid on stock halogen hl is a no-no coz of the glare. For what car?
    - - - Updated - - -
    Quote Originally Posted by garyq View Post
    naman naman!!! ang ganda. magkano inabot neto sir?
    Aug 2012
    boss gary nagiinstall ka din ba ng high power led parklights? parang ganito
    gusto ko sana palitan ng white led ung parklight nung 3rd gen crv..
    actually may alam ako na shop kaso mas tiwala ako sa gawa niyo sir
    May 2011
    Sir pa-PM naman how much yung price for Stage 1, 2 and 3 set up for Honda Civic EK. Also ilan days yung turnover.
  14. #14
    half: sent you an email
    Another LC200
    Stage3 S30 projectors
    Macho talaga ng LC200!
    Jul 2004
    Another LC200
    This unit you retrofitted comes with factory/OEM HID high beams right?
    Were you able to take pictures of the high beam? What bulbs and ballasts does it use? Is it the same as regular ones? I find it amusing
    kasi na OEM HID ang high beams. Very unusual and I don't know of any car that has the same set up.
    Sir gary baka sa tuesday ko na madaan
  18. #18
    bro wag baka, make sure para I can do some proper scheduling. If you're not sure sa day and you come, most probably I cannot accomodate you kasi planned na ahead ang mga work days namin. thanks.
    Another big bike, Honda CBR 1000, dual projector setup, sobrang hirap ng mounting pero we did it with custom shroud to boot!
    Aug 2010
    Sir gary kamusta? Pa pm ako ng quotatio for kia sportage 2013
  20. #20
    slvr: So 4x4 yung CRV mo on stock HIDs and HID projectors? maganda naman output nyan bro but the a fog projector retrofit will still help.
    Eto yung CRV which I retrofitted with stage3 on the HLs and 50mm fog retrofit.
    Honda CRV 2010 | HID Retrofit
    eto yung 50mm output on a Jazz 2010
    Honda Jazz GE | HID Retrofit
    Igi: Happy New Year bro! wow ganda naman nang pinalit. PM kita
    - - - Updated - - -
    http://www.hidretrofit.net/V2/honda-crv-2010/
    http://www.hidretrofit.net/V2/honda-jazz-ge-6/
HID Projector Retrofits by garyq
