Results 1,261 to 1,270 of 1594
- Nov 2017
- 16
November 23rd, 2017 01:51 PM #1261
- Nov 2017
- 242
November 23rd, 2017 07:56 PM #1262Got both matic and manual tranny cars...malaking ginhawa talaga pag a/t gamit ko lalo ngayon na traffic everywhere.Ease and comfort talaga ang pros ng a/t lalo na sa driver.
Sent from my Redmi Note 4 using Tsikot Forums mobile app
- Apr 2006
- 419
November 26th, 2017 11:24 PM #1263How will you rate MT vs. CVT in terms of engine breaking while going downhill? Say going down Kennon road, if you’ll rate the following from 1 to 10 in terms of engine brake effectiveness (10 being the most effective):
1. MT on 1st gear
2. MT on 2nd gear
3. CVT on ‘S’ mode
4.CVT on ‘L’ mode
November 28th, 2017 07:49 AM #1264
For manual tranny doing engine braking going downhill is dependent on driver skill.
If the driver knows what gear to use that can adapt to road conditions then the efficiency rating would be 10.
Again, it depends on driving skill
Sent from my ASUS ZenFone 4 using Tapatalk
- Aug 2017
- 124
November 28th, 2017 01:27 PM #1265Nagddoubt tuloy ako mag MT. Espana at Quezon Ave pa naman dadaanan araw araw kung sakali..
- Nov 2017
- 1,748
November 28th, 2017 02:31 PM #1266
- Apr 2007
- 487
December 13th, 2017 08:45 AM #1267What if i plan to keep the car for at least 10 years? What would you recommend for a more hassle-free maintenance?
December 13th, 2017 09:15 AM #1268
Short answer: Get a manual.
Long answer:
If you're still considering buying an A/T, there are a lot of factors in play here. Are you a careful driver? Is the car known to have reliable A/Ts for that car model and generation? How well do you maintain your vehicles?
Then there's the decision you have to make whether an A/T is worth the extra TCO for the benefits it can provide. It's usually true that convenience adds complexity. And the more complex it is, the chances of things going wrong increases. With the A/T, you're buying the convenience at an extra for a better driving experience.
December 13th, 2017 02:34 PM #1269
there are some automatic transmissions that are reliable like toyotas 6at (fwd) hyundai/kia 6at (fwd) fords 6at (fwd) and 6r80(rwd) on the ranger/everest.
so many AT failures in our country because of stupid owners(late atf changes) and bad mechanics.
almost all the atf changes at zix and everest garage is fukcing brown atf wtf...
Sent from my SM-G935F using Tsikot Forums mobile appLast edited by StockEngine; December 13th, 2017 at 02:37 PM.
- Jan 2008
- 4,726
December 13th, 2017 02:49 PM #1270
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
