Page 138 of 160 FirstFirst ... 3888128134135136137138139140141142148 ... LastLast
Results 1,371 to 1,380 of 1594
    #1371
    Quote Originally Posted by Vodka View Post
    hindi reliable yan top gear na yan
    pag old school slushbox a/t, yes you should put to neutral
    pag meron slushbox in front of the CVT, yes shift to neutral
    pag DCT, no need. the clutches disengage when you step on the brake
    pag meron clutch in front of the CVT, probably no need to neutral for the same reason as DCT
    experts are welcome to correct me
    DCTs and CVTs need not shift to Neutral at long traffic stops. However, that does not stop people from doing it out of habit. On my end, I don't want to step that long on the brake pedal and also, accidentally letting go of the brake pedal at a stop with Drive engaged might cause you to bump the car in front.
    Jul 2013
    #1372
    Iba naman ang sabi dito (3:28) [emoji37]
    5 Things You Should Never Do In An Automatic Transmission Car! - YouTube
    Well, in other countries... Kung traffic light lang, I keep it at "D"
    Pero Philippine traffic kung saan minsan 10 mins na di pa din gumagalaw... Different story.
    My personal rule...
    If I will use the handbrake... Linalagay ko muna sa "N"
    Aug 2018
    #1373
    My personal rule...
    Got it. Thanks.[emoji106]
    #1374
    This is when I really appreciate the brake hold function in the CR-V. During long stops I can rest my legs.
    Jul 2013
    #1375
    I finally found the right term... hehehe
    Do not let the car "idle" on Drive...
    So back to my personal rule, if I pull the handbrake, I put the car on "N"
    Traffic... depende sa tagal na non-moving yung car...
    Wife needs to withdraw sa ATM/quick 7-11 purchase... "N"
    Aug 2018
    #1376
    Sorry I don't know anything about cars. I read somewhere to not idle in D. Why not P na lang?
    #1377
    P kasi yun parking pawl naka engage
    so kung mabangga ka, malaki chance na masira
    P kasi pag naka engage, dadaan ka pa ng R bago N, tapos Drive
    so pag nagkamali ka, pwede sa R mo mailagay tapos kung may kotse sa likod mo ... bang ..
    kaya pag yun sa harap ko umiilaw reverse light ng split second, di ko na binubuntutan
    Jul 2013
    #1378
    ^I agree... Kapag ilaw ng ilaw yung reverse light ng nasa harap ko... Medyo lumalayo ako. Mahirap na.
    2nd, older AT cars, di mo na kailangan ipress yung button to shift to N.
    Sent from my ASUS_Z017DA using Tapatalk
    Aug 2018
    #1379
    Di mo to tinuro sakin nun ah [emoji39]
    Thanks ninj
    Aug 2018
    #1380
    Binalikan mo pa talaga ako nung maalala mo yung term. Thanks, appreciate it [emoji4]
Battle of the Transmissions: M/T vs. A/T
