Page 76 of 392 FirstFirst ... 266672737475767778798086126176 ... LastLast
Results 1,501 to 1,520 of 7833
    Feb 2012
    #1501
    Sirs,
    Bought a new silver car and now keen on detailing it. Am only a beginner and based sa mga nabasa ko dito ok na ang nanogloss and nanosliq then eventually try ko nalang mag move to collonite. Any other suggestions for a newbie?
    Now eto na yung question ko about curing and applying the nanosliq, let say after washing and drying the car apply na ng nanogloss and pacure muna ng around 8 hours, dahil medyo road side kami after 8 hours medyo marami ng dust yung car, ang gagawin nalang ba dito is yung feather duster then apply nanosliq? or kelangan pa ulit water wash? medyo dun lang yung part na medyo hindi clear sakin.
    Salamat sa magclaclarify thanks
    #1502
    kung nasa tabi ka ng kalsada, i'm pretty sure kapal na ng alikabok after 8 hours. it would be safer to wash the car before applying nanosliq. just let nanoglos cure for a day and perform car wash next day using a good shampoo then apply nanosliq. it is not advisable also to use feather duster it can cause paint marring. there are better dusters available but at a higher cost.
    Aug 2010
    #1503
    Personally, I dislike touching the paint unnecessarily. The only time I'll touch it ASAP is when birds try to make my car a shooting range. I'd rather go for washing the car -> apply Nanoglos -> wait it out until the car's dirty -> Nanosliq.
    If eager, I suggest you go invest in a good duster. My Microtex Duster has been with me for a year and it's still dusting dust away before I apply Nanosliq as part of a weekend regimen. If you're still a newbie, I would suggest going for Optimum Car Wax for the ease-of-use and durability.
    #1504
    Question, safe ba ang degreaser sa dashboard and other interior plastic panels or kailangan pang i-dilute? I'm using D'best biodegreaser. P150 lang yata from Handyman Trinoma.
    Feb 2012
    #1505
    Thanks Ginnova, jhnkvn. Went to ace hardware and boought some better duster. I think yung brand is mrclean? Microfiber daw sya. Will look for that microtex duster.
    Yung optimum car wax wala sa ace. Tomorrow hopefully makalabas to go to blade.
    Salamat sa mga payo
    #1506
    ace should have microtex duster. kung hindi mo pa nabuksan yung mr clean duster , exchange it for microtex. allowed naman yan for up to 7 days.
    i suggest invest ka for a more durable wax like collinite that could last a month or more. kakatamad din mag-apply ng wax after every car wash unless you're using a spray wax/sealant.
    Oct 2011
    #1507
    I have seen both Microtex NanoGlos and TireBlack. Parang same lang ang texture nila and scent. My question is, under the engine compartment, can I use NanoGlos or Tireblack sa mga hoses and black plastic? The idea is to repel and para hindi kumapit ang dust.
    Feb 2006
    #1508
    Hi guys, any idea kung how much po locally ang Collinite wax(467s,915 at 845)? Sa Ebay $55.95 for the TRIO mura na kaya ito?
    Collinite TRIO SPECIAL one of each 915 & 476 & 845 Kit of the BEST of the BEST | eBay]
    Thanks in advance
    Aug 2008
    #1509
    Parang medyo matapang yung D'Best Biodgreaser bro - at the very least, it can make my hands itch. For maintenance lang ba? I use ONR in QD dilution for light cleaning of interior plastics.
    Aug 2008
    #1510
    The Nanoglos is for paint work, the Tire black is for tires, other rubber parts, and black plastic trim. You can use the tire black for the plastics and rubber under the engine hood - one tip I've gotten is to dilute it 1:5 (tire black:water) to make it sprayable and more easily spreadable. Just not sure whether it will attract dust or not, as I've not used it under the hood yet (I use the diluted version for wheel wells).
    Aug 2008
    #1511
    Quote Originally Posted by jhnkvn View Post
    I agree with this - one of the most important things you need to learn about minimizing marring on your paint finish is to resist the temptation to touch it when it's dirty. It's always better to be safe - if you want to wax, be it a spray wax or an actual liquid/paste wax, always do a wash beforehand; resist the temptation to use a QD when you have anything other than a few smudges to remove (I don't even use QD for light dust removal); and stop yourself from running the back of your hand across your paint to feel how slick and smooth it is
    Aug 2008
    #1512
    Quote Originally Posted by collit99 View Post
    Thanks in advance
    I believe the prices of the local distributor are 1,200 for 845, 1,400 for 476, and 2,400 for 915 - total of 5,000. However... you don't really need all three of the waxes - if you want the best durability, go for 476; if you want ease of use, go for 845; and if you want the best looks on darker colors, go for 915 (I'd probably go for 845 on whites, silvers and metallics, just because it really has a bright look that goes well with lighter colors).
    Apr 2010
    #1513
    speaking of inside the vehicle/under the hood / trims etc.. ... anybody still using Armor-all? and around how much dilution is best if ever?
    thanks!
    Feb 2006
    #1514
    Quote Originally Posted by umi001 View Post
    Thank you umi011 my ride is a light blue metallic Innova as per your advise, the 845 is the right choice.
    thanks again
    Dec 2011
    #1515
    Tatanong ko lang po kapag nilgay na ung nanosliq/nanogloss, ilang minuto o oras ba dapat hintayin bago punasan? 1st time ko po gumamit dati ng 3m kaso d kumapit ung wax. Salamat
    Aug 2010
    #1516
    Hmm, none I guess? For the Nanoglos, work with it on a panel basis then buff. Waiting too long (ex. deciding to wax all 4 doors worth before buffing) would make it harder to buff but waxing then instantly buffing might be time-inefficient compared to waxing a medium-sized surface area then buffing it.
    For the Nanosliq, it's spray then wipe... then wipe.. then wipe some more as it has known streaking issues. To make it last longer, you might want to dilute it with distilled water as most of us do.
    #1517
    Frankly, I'm a noob when it comes to auto-detailing. Gusto ko sana mag-DIY carwash session sa kotse ko soon -- if hinde tinamad. I'm quite aware of the process in general since nagpapacarwash naman ako, pero ask ko lang kung may iba pa ba kayo process? Like ilan times kelangan sabunin at linisin etc.
    I don't plan to take on detailing pa. Just the usual car wash. Ask ko lang din kung ano yung mga recommended products such as car shampoo and the likes...
    Tia guys
    #1518
    ^ Pare, anong nakain mo?
    #1519
    Kiki lang. Este, kikiam pala.
    Gusto ko labg ma-try ano yung feeling ng satisfaction pagtapos. may nabili na kasi ako carnauba car shampoo, matagal na. Hindi ko naman magamit. Hahahha.
    Aug 2008
    #1520
    Baka naman hindi na fresh yang nakain mo
    Here's a link to v.2 of doc scharnhorst's Tamang OC guide: Tamang OC Lang v.2
    It's got a list of tools and products needed, and a procedure for the wash itself. Oh, and very few car washes actually follow correct procedure in washing vehicles, hehe
"Tamang OC lang" - a newbie's guide to car appearance maintenance
