Results 151 to 160 of 287
October 26th, 2018 04:50 AM #151
bro ano yun red LLC?
mileage is 221k km
btw bro, yun aisin and GNB water pump price, thats for vios na? palitan ko nalang din kaya since wear and tear naman ito, if OK pa condition atleast may reseba ako.
kasi nung mag inquire ako sa mga tao sa banawe parang 4k daw yun plus 2.5k labor O_o
October 26th, 2018 04:52 AM #152
October 26th, 2018 06:26 AM #153
palitan mo na yun water pump. with 221,000km+
thats over 10,000hrs already on the bearing if the aveage speed is 20kph.
October 26th, 2018 06:55 AM #154
- Nov 2009
- 3,509
October 26th, 2018 08:20 AM #155
October 26th, 2018 08:30 AM #156
October 26th, 2018 09:13 AM #158
salamat bro! watching vids online, i think kailangan ko pagawa sa mechanic muna; para makita ko paano pasukin LOL
pero mukhang kaya DIY after ko makita pano baklasin hehehe
btw found this thread in vcp .. not exactly the same issue but close
Login
author=jcboy link=topic=40695.msg927223#msg927223 date=1414676153
Go with the cheapest route ALWAYS. (well as much as possible)
1) replace with original Radiator CAP --often neglected.
2) replace thermoswitch --original as what has been mentioned, since aftermarket thermoswitches are not calibrated with OEM specs (degrees Celsius when opening), let alone racing thermoswitches have a lower "open" temp.
3) replace thermostat --or just check it. rarely do thermostats break down. siguro 10-15 years is the average lifespan sa mga nasisiraan nito, pero of course 7-10 years pwede mo na siguro palitan.
4) check/replace rad fan --minsan kahit umiikot hindi na pala ganun kabilis/kalakas, kaya you need to have 2nd opinions kung kumusta ba pagikot ng rad fan mo.
5) replace radiator --minsan barado na pala sa ilalim kaya hindi umiikot tubig. yung kalawang kasi ng radiator sa ilalim nagaaccumulate. kaya minsan kahit malinaw pag sinilip sa butas yung water/bakal na fins nya, nagooverheat ka pa din. yun pala hindi nakakadaan yung coolant/water.
6) head gasket --ayan tinamad na ako, so pag the 5 steps do not seem to work, paconsult mo na sa trusted shops.
HTH.author=deathscythell link=topic=40695.msg927408#msg927408 date=1414994054
Maraming salamat mga sirs. Lahat nung mga suggestion nyo chneck namin - ok nman. Ni-trace din namin ung mga dinadaanan ng tubig baka may leak pero wala naman. Before kami dumiretso sa head gasket (kasi mahal daw kapag kinalas un) chneck muna nmin water pump and ayun, water pump daw yung sira. Nung ni-replace nmin nag-ok na. Dagdag kaalaman.
Thank you ulit mga sirs.
October 26th, 2018 09:15 AM #159
*Ninja
Note lang. Yung belt kelangan tama ang pagkabalik / higpit kung mag diy ka.
October 26th, 2018 09:16 AM #160
found this pricing too ..
sana di malayo sa 2015 price ..
Login
author=jeffman link=topic=41830.msg939375#msg939375 date=1432361702
Aisin Clutch Disc + Cover
1NZ 1.5L = 2,600 pair
2NZ 1.3L = 2,500 pair
Aisin Water Pump
1NZ 1.5L = 900 each
2NZ 1.3L = 900 each
KYB Gas Shocks
Robin Front = 2,500 each
Robin Rear = 1,400 each
Batman Front R =2,950 each
Batman Front L = 2,950 each
Batman Rear = 1,500 each
MKK Brake Pads
Robin Front = 600 set
Robin Rear = 500 set
Batman Front = 700 set
Batman Rear = 500 set
Destination charges may apply
Edsa is about 24kms long. So, 15b / 24 is approx 625m per km?
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
