Results 171 to 180 of 287
October 26th, 2018 10:13 AM #171
- May 2011
- 481
October 26th, 2018 11:14 AM #172Looking back at post 144, how reliable was your temperature reading? Otherwise, have fun chasing your tail
- May 2011
- 481
October 26th, 2018 11:29 AM #174
October 26th, 2018 11:47 AM #175
Your car might have inter-computer communication problem or your CTS is giving wrong signals. Have your car scanned for communication or U codes. What you are doing is way too far from the possible cause. You might even have IPC problems. Be very careful of mickey mouse trouble code readers and dongl
- May 2011
- 481
October 26th, 2018 12:20 PM #176
By communication errors, it means your control modules within the car may not be communicating.
Your car might have obd 2 ISO 9141 communication protocol.
Toyota/Lexus OBD II diagnostic interface connector pinout diagram * pinoutguide.com
October 26th, 2018 04:32 PM #177
mukha pareho kami problem nito ..
Overheat warning @ 94C
- Jan 2010
- 283
October 27th, 2018 07:16 AM #179
will have the water pump replace later bro
previous owner replaced the orig 50k km ago with a surplus, so i think OK lang to have it replaced narin; if OK condition pa, atleast may backup ako. already sourced water pump aisin brand * 950 php via toyocars.
after nito thermoswitch naman, but ill try to clean it thoroughly muna before buying since brandnew orig is at 3.1k and was told this rarely breaks naman daw baka masayang pera.
last na yung aux fan since it is still functioning, and no mechanic (5 of them) wanted to replace it.
- 54,215
October 27th, 2018 09:32 AM #180if the thermo$witch ha$ no moving part$ outside, cleaning it$ outside$ won't amount to much.
good luck, $ir.
we await the blow by blow.
well, i have never met a victim admitting they maltreated their trans box...
The Toyota Fortuner has landed (fortuner pics at...
