Page 8 of 29 FirstFirst ... 45678910111218 ... LastLast
Results 71 to 80 of 287
    #71
    ilang years na bro? some toyotas really last long before that water pump fails or that thermostat. how does the used coolant loom like? malinis naman? if thw coolant is a premix-wala gaano rust.. some have rust kasi yun nga..distilled lng ang gamit... wala sya rust inhibitors..
    11 years na next month yun auto
    nung pinalitan 1 1/2 years ago bro, OK pa daw coolant ko sabi nung mechanic. sabi ko palitan parin namin since, 2 years ago pa last replacement (last time). now, ok pa; pink na pink pa naman nasa reservoir
    sa radiator cap ang tignan pag malamig... silip lng😉
    #73
    will do bro, thanks!
    Sep 2017
    #74
    The radiator fan of my Honda City VX 2014 is not working which caused my car to overheat 3 days ago. Sadly, my 3 year warranty just lapsed 4 months ago. Meaning, I would have to shoulde the cost. Badtrip!!
    I live far from a Honda service center -- so I asked the nearest Shell gas station for an estimate. Per the mechanic, original Honda raditor fan would cost around ~P14T. But he said that I can instead buy a brand new Japan radiator (Denso) in Banawe for about P7K and they (Shell mechanic) can install it for P400 labor.
    Any City onwers here experience with their radiator fan not working? What did you replace it with & how much.
    Thanks in advance for the help.
    IM2017
    #75
    Quote Originally Posted by IM2017 View Post
    IM2017
    check first, if the fan is definitely the culprit. baka yung ibang piyesa na nag-a-activate ng fan, ang prublema.
    May 2011
    #76
    IM2017
    Most Honda cars have the radiator fans switch normally open (N.O.) and closes when the threshold had been reached. To eliminate possibilities , unplug the radiator fans switch at the bottom of the radiator and jumper with a paper clip ( with the ignition switching the ON position). The fan should run at full speed,if not, check the rad fan relay or the fan motor. This time, unplug the relay and jumper (with a fused jumper wire)between the two larger female terminal of the relay block where you unplugged the relay. If the fan still won't run, the motor is probably bad.
    Dec 2017
    #77
    Good afternoon, I am seeking assistance from you guys to solve the issue I'm experiencing with my Nissan Urvan model 2009 (UV express). Since the van is experiencing high pressure recently, we brought it to our mechanic, he then performs the following on consecutive days, 1) Removed the Thermostat but still there is high pressure; 2) replaced the water pump and fan blade with brand new ones but again still high pressure while running; 3) cleaned both the radiator and sub radiator but last night my driver called and told me again there is high pressure, he then turn off the engine check the radiator (still full and no water leakage). He restarted the car after a few minutes and it became normal until he finished his duties. Any ideas what other possible factors that causes the high pressure? thanks a lot.
    Aug 2009
    #78
    Quote Originally Posted by Dohabibi View Post
    Check the radiator cap boss baka it needs replacing...
    Feb 2009
    #79
    It couldn't have "higher pressure". The radiator cap that relieves the built up hydrostatic pressure couldn't get stronger but the other way around. Maybe, what you're trying to say is that the temperature is higher.
    Your rad cap is designed to open at 0.9 kg/sq.cm or roughly 13 psig.
    If your situation is overheating, try bleeding your cooling system.
    Oct 2016
    #80
    What are the signs of radiator hose replacement? Thanks!
    Sent from my SM-G930F using Tsikot Forums mobile app
Radiator / Overheating Problem
