yikess, ang everest pala walang drain plug para sa atf. You have to remove the oil pan daw according to casa. Around 3 liters ang kelangan. Is is worth it to remove the oil pan and put a drain plug w/ screw para sa susunod na atf change drain yung atf thru the drainplug? or mas ok ang tanggal kabit ng buong oil pan?
