Results 31 to 40 of 41
October 30th, 2006 05:25 AM #31
meron dalawang klase ng boat changer manual and electrical.ang purpose nila ay to SUCk the oil coz ang makina ng boat ay wala rin drain plug.Meron mga cheap and expensive.Usually they run from $25-$80 .
Ilalagay mo sa trans oil dipstick hanggang makarating sya sa trans oil pan.Pwede rin tong pang oil change.
electric.
October 31st, 2006 02:17 AM #32
mukhang mahirap ata ipasok yan sa dipstick ng transmission kasi maraming pasikot sikot yung daanan ng a/t dipstick
October 31st, 2006 06:24 AM #33
Nope.madali lang if you look at your dipstick straight lang yan at konting bend.btw, Mercedes dealership here in my area use the manual topsider to change oil.
November 4th, 2006 01:43 AM #34
it happened again kanina, after driving for about 45 minutes and pag dating sa destination ko nag reverse ako to park, then when i put it in D ayaw umabante, nung pinilit ko umabante naman kaso may malakas na tunog na parang may pumipigil at ingay ng preno. weird thing is hindi naman stuck up ang brakes ko. I just parked it then after a few hours nung pauwi nako wala na yung stuck up feeling. Na we-weirduhan na talaga ako. transmission na siguro diprensya. Any of you had this experience yet?
November 4th, 2006 03:28 AM #35
Bring it nalang to a reputable a/t shop... in the long run mas malaki ang maggastos mo pag tumagal yan. Kung may warranty bring it to casa.
November 4th, 2006 10:13 PM #36
brat,
Your AT is giving you a sign.If you don't want the sucker route then do a trans oil bath.
November 5th, 2006 02:52 AM #37
Ill have the transmission fluid replaced tomorrow, hope its not too late. sa mga gas stations diba meron sila pang suck ng mga fluids? Ngayon lang ako naka enconter ng a/t na parang nagprepreno pag sa drive. Anybody experienced this?
November 5th, 2006 05:31 AM #38
have you already tried moving the shifter to L or 1-2 like sir Otep suggested?
kung baga excercise the stick using the overide botton... who knows, maybe the shifter is doing a P and D at the same time...
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 5th, 2006 12:40 PM #39try to have the atf flushed and if that still doesn't work then you're going to have to pull it down na.
November 5th, 2006 11:21 PM #40
haay, I was gonna flush the atf today kaso lang family errands got in the way.Ayun, nung ginamit ko yung everest for the first few meters ok naman takbo.kaso after stopping at the intesection ayaw na umusad nung nasa "D", try ko rin sa "2" at "L" ayaw din. binanatan ko ngayon yung brakes sa pumping at ayun umusad na. Ngayon iniisip ko naman baka sticky brakes and not the transmission. konting apak lang kasi sa brakes ang lakas ng kapit and parang mag lo-lock. Ang brakes ba pwedeng maging occasionally sticky lang?
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
