Results 11 to 20 of 41
- Aug 2003
- 32
October 17th, 2006 04:45 PM #114L30E is a GM tranny but understand that some BMW 5 series are using the same. Know of any good mechanic - one who knows how and understands auto tranny ?
October 17th, 2006 06:44 PM #12
You'll be hard pressed to find one here in RP...
But dont ever go to Automatic Transmission Master along Visayas Avenue...first thing they'll recommend is to overhaul your A/T (without doing a comprehensive diagnosis), and charge you an arm and a leg for it...
October 17th, 2006 09:46 PM #13
after last sunday nung nangyari ang incident about my a/t hindi pa nauulit uli, sana hindi na bumalik, its pretty expensive to repair an a/t pa naman
October 20th, 2006 02:01 AM #14
it happened again a while ago, while im reversing ok naman, tapos when i put it in D parang may kalso sa gulong, so nilagpasan ko "D" and deretso sa "2" pero ganun parin. Nung piniga ko mabuti accelerator umabante kaso when i release the gas pedal hinto rin siya. tingin ko stuck up ang brakes, pero its weird dahil pag reverse ako wala namang problema, pag forward lang.sa brakes kaya ito?
October 20th, 2006 09:30 AM #15
Try to check the brakes as the caliper may be sticking. Same thing happened to my Frontier before and i had to overhaul the calipers.
BTW, if you want to change all the fluid in the ATF (since the regular drain and change only changes what's in the tranny and not in the torque converter), try the Transtech at Autotechnika... we did it to our old Corona and it was worth it. ;) Nawala din yung shift shock.
October 20th, 2006 01:36 PM #16
Nawala ba ang shift shock dahil kaunti or sobra dati ang ATF? Or luma lang ang ATF nun? Kasi sa Crosswind ko, malakas ang shift shock niya in the morning (first shift from overnight), pero pag warmed up na ang transmission, may shift shock pa din pero lessened na (normal).
Gusto ko pa-adjust sa Casa kaso ayaw nila galawin kasi baka daw lumala. Nung ganun ang sinabi di na ako nagpumilit kasi parang di nga nila alam gawin.
October 20th, 2006 07:53 PM #17
I feel it was more of a case of the ATF being sooo friggin old as the previous owner didnt bother to change it... as i mentioned on the Autotechnika thread, we used up 24L of ATF to get it to clinically clean readings. It got rid of the shift shock I would experience after suddenly releasing/flicking the gas pedal at a mid to high RPM.
October 20th, 2006 09:09 PM #18
ano ba klase ng atf para sa everest? i tried looking at the manual and walang nakasulat dun. dexron 2 ba o dexron 3? and ilan ang capacity sa isang atf change? halos lahat yata ng capacity nakasulat dun sa manual except yung atf quantity and kind of atf
October 21st, 2006 05:59 AM #19
did i tell you to change the fluid? anyway since 36k lang ang mileage just drain and fill lang ang gawin mo(no need for flushing)and don't forget to drop the pan, remember to torque it right kung hindi mag leak ang oil pan mo.kung wala sa owner's manual try mo sa dipstick or tanong mo sa dealership.
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 21st, 2006 09:08 AM #20most auto trannies will have between 6-10 liters total capacity. about half will be in the torque converter.
sinabi moh! i hardly see my children now. when they were young, schedules were more predictable.
Traffic!
