Results 1 to 10 of 72
- Feb 2004
- 200
December 1st, 2004 07:58 PM #1hi!
can you please help me. me mga times na hirap ako mag-change the gear, ayaw pumasok? ang ginagawa ko nuetral muna then saka ko ulit pasok, minsan ayaw pa din. clutch na ba ito o transmission problem?
ride ko po ay lancer glxi m/t.
many thanks..
December 1st, 2004 08:22 PM #2
how long ba since you have replaced the clutch? how's the clutch fluid in your reservoir. kung nababawasan, may leak yan either sa clutch master cylinder or clutch slave cylinder. kung pudpod na kasi ang clutch, it should manifest sliding symptom; as in pag- engage mo ng gear, di agad humahatak yung auto, (tumataas yung rpm as you step on the accelerator pero forward thrust is delayed).
do you experience hard shifting at all times or when the car is at full stop( i.e. engaging first gear when the traffic light turns green at an intersection). baka nasa adjustment lang ng push rod yan kaya ganyan or maybe you need to have your gear oil changed
- Feb 2004
- 200
December 1st, 2004 08:33 PM #3momoyster,
last year lang ako palit, actually dec yun. nde nman nababawasan yung clutch fluid although medyo madumi na sya. la nmang sliding.. i usually experiencing this pag or during stop and go. usually me hardshifting sa 1st and 2nd gear. bagong palit ang gear oil ko din, kahapon lang kasabay ng change oil ko.
many tnx..
December 1st, 2004 08:34 PM #4
Try to adjust your clutch first or replace the whole clutch set(pilot & release bearing, Clutch plate and disc)
- Feb 2004
- 200
December 1st, 2004 08:48 PM #6correct me if i am wrong, dba pagsinabing adjust yung clutch - meaning mataas o malalim na yng clutch.. adjust mo sya pra kumapit, tama ba ako?
in a year time, me possiblity bang worn out na yung clutch ko(pudpod na1). 1 set ko pinalitan yun, daikin ang tatak nya.
December 1st, 2004 09:06 PM #7
Pag nagkamali ng pagkabit possible na masira kaagad, just like what happended to my rig after 30k kms, sliding na. Dinukot lang kasi hindi binaba buong tranny. Malamang di nagpanatay sa flywheel. Mas tangos daw kasi yung flywheel side ng disc.
December 1st, 2004 11:55 PM #8
it seems that the little things that you should look at are ok. pa-adjust mo muna yung clutch mo to try to isolate the problem. if this fails, mukhang dapat tignan na ang transmission and clutch assembly. sa push rod ang iaadjust as far as i know. ganito rin kasi yung sinusumpong ng vr ko pagkatapos ko pa pms sa casa. sabi ng casa di naman nila ginalaw yung clutch during the pms. but i know my car's behavior kasi talaga e so binalik ko sa kanila tapos ayun nga, sa push rod nila inadjust. ang problem ng sa akin, sa first gear lang mahirap e-engage,rowing through the rest of the gears is no problem. if i have time, papa change ko yung gear oil nya. but then again, it could be my clutch rin kasi nung 35k km ko yun pinalitan, the car just hit the 60k km mark e. in my case, baka indication na yun ng malapit na sya mapudpod
- Feb 2004
- 200
December 2nd, 2004 02:31 PM #9ungas: think me problem nga sa pagkabit sa akin kasi after ng palit me naramdaman akong prang "drag" whenever i change shift. me times na ala meron madalas. bka me problem yng flywheel?
drag ba yun? yung bang pag change shift mo tapos bitaw ng clutch me parang nalaglag na mabigat tapos me tunog na "blag"?
momoyster: push rod? dba e2 yung nsa kambyo mismo? maybe, i'll have it check.. sna nga d2 lang yun.
many thanks to all..
- Jun 2004
- 103
December 2nd, 2004 02:35 PM #10Or it could be your 1st-2nd gear synchronizer. With the engine off, is it hard to shift from first to second?
Suzuki JIMNY [merged threads]
