1.3J
1.3E
1.3G
1.5G
1.5 XX
1.5S
1.5SE
I don't own a VIOS.
Ok ba sa toyorama? Mura ba don ang air filter, oil filter Pati langis na rin?
Was able to buy genuine Toyota oil filter for 300 and air filter for 650 pesos sa banawe. For Superman na Vios sabi nung me ari ng shop. Baket Superman pala?
good evening po. sa po pwede omorder ng socket ng signal light. yung nasa tail light po na signal light. sira na kasi yung aking. pudpud tsaka nagcrack crak na ung plastic na socket ng bumbilya nya. vios 2006 1.5g. thanks po.
Share ko lang po. Naka score din ako ng luggage tray/trunk sa wakas![]()
Delo Gold Ultra Sabi sa aken ng taga caltex pang diesel lang daw. Me na Miss ba akong info.
As I understand it, all motor oils designed for diesel engines can also be used for gasoline engines. But motor oils designed specifically for gas engines are not recommended to be used for diesel engines. That is because diesel engines required more cleaning detergents which are present in diesel motor oils.
Tanong ko lang mga sir. Magkano ba magpapalit or repair ng starter solenoid? May cranking sound kasi pag iniistart ko. Sabi ng ka opisina ko solenoid daw pag ganun.
Ah thanks for sharing bro. pano kaya ito ibig sabihin dumihin AC nya? Or may cabin filter man lang?
Btw kaya pala di nailaw yung signal light sa fender naka double contact daw sabi nun gumawa. binalik sa normal, kaso pag nalulubak parang nawawalan ng current. Feeling ko maluwang lang bulb eh.
