1.3J
1.3E
1.3G
1.5G
1.5 XX
1.5S
1.5SE
I don't own a VIOS.
no idea din ako eh, may 20,000 KM pa ako bago umabot dyan, pero may sticker kase sa hood na need i check ang valve clearance, tapos pag ni reference mo sa manual naka lagay i check ito every 80,000 KM
yong mga nabasa ko dati dito at sa iba forum (VCP) na umabot na ng 80,000 km na casa maintained eh di naman chineck ang valve clearance...
well di na ako nagugulat dun kase kahit casa mali din ang type/viscosity ng MT transmission oil na binebenta nila na pag tinignan mo sa users manual eh di tugma... (para siguro ma accelerate ang pag ka laspag at mag palit ka agad, in short para may sure income sila), kase kung mali naka imprenta sa users manual dapat may recall yong users manual...
the statement wasn't on the manual. it was in the advertisement, which was all over the place.
i had a manual once. the pasted-over fuel octane rating was 91. flashing a strong light under the paper, i thought the original read 93 or 95... nasayangan siguro sa stock of "un-corrected" manuals.
Who's using Achilles tires? Not the 123S though. I'm planning to buy a new set of tires na kasi. Ok ba Achilles? Pag GT Radial anong model dapat bilhin? Champiro ba yun? 195/55/R15 sana. Worth it din ba Toyo DRB? Gusto ko yung malambot pag 'kinurot' yung gulong haha.
Maxxis MA-Z1 ang gamit ko ngayon for almost 60k kms already. Di pa kalbo pero manipis na. Matagal sya maupod kaso sobrang tigas ng rubber compound nya nakakairita na. :bwahaha:
Not only you but each of us tsikoteer wants to share and help our fellow members to the best of our KSA. Now going back to the coolant issue, I can't find my owner's manual but what I got from my PC file, was the TMPC preventive maintenance checklist (attached herewith) posted by our fellow member way back. If the checklist is still doubtful, I will try look into the forum thread source but it takes a long time to repost. perhaps who ever posted the checklist kindly acknowledge para di na tayo mahirapan mag-dig up sa threads.
AFAIK TMPC come up that checklist, suitable in MM heavy traffic condition. If you notice item nos 5 in checklist, it says "replace radiator coolant" either 20k, 40k and so forth. It's illogical to replace the coolant when the car mileage reached 100K KM as what you said in your post 10258.
if you're not still convinced to my post nos 10259 then it's your turn to prove me wrong. The burden of proof is now in your side.
Attachment 32127
Ito naman sample job quotation for 80k pms
*kimbon & Devin miles
Salamat
btw pag gusto ko totally drain the coolant, ilan liters need ko to refill? may nagsabi 4, may nagsabi naman 6. salamat![]()
Thanks to both of you for sharing these infos. Lesson learned...never ever change your coolant when it reached 100k mileage . Case Closed coolant issue kumpanero.
bro 4 liters ang sa vios. may konting matitira mga kalahating baso ng coolant kapag ibinuhos na ang 2nd container (2 lts) sa radiator.
if you don't mind tips for draining & refilling the coolant.
1. flush the radiator with water -when the coolant is totally drained from radiator, flush it with water using garden hose. to make sure only ma-flush out ang kalawang or small debris inside ng radiator.
2. Coolant Refill- fill up until coolant is visible but a few inches below cap level of the radiator. Start the engine but don't accelerate. the coolant level will lower as the engine sucks in coolant. Continue to fill with coolant until the level stabilizes then install and tighten the cap.
3. finally, fill up the plastic coolant reservoir with coolant up to max level only. Hwag punuin ng coolant pls. Goodluck bro.
