i replace the fuel filter every 15K km, for peace of mind lang. orig costs around 850, replacement ones at around 300-500
pwede pa naman i-extend beyond 15K, praning lang akoi guess mahal magpa rebuild/linis ng injection pump and/or injectors since CRDI na ito
kung mahihintay mo this weekend, mag DIY ako ng coolant flush, wait mo na lang kung ilang bottles nga magagamit ko![]()
nag-inquire ako for the A/T filter
casa: PHP4222
pasay parts store: PHP4100
pricey huh
and you need another liter or two siguro of the ATF since you will be dropping the A/T pan
^ i was not able to get the filter part number, pero i specified my year model and engine
sabi ng parts store, gasket maker will be sufficient na daw, kahit hindi yung original Toyota 1-piece(?) gasket
edit: Toyota BGC called back and informed that the part number is 35330-60030
If you drop the oil-pan, it may usually require replacement of gasket and torque it evenly as if it was against a flat marble surface. Esp those felt-paper like gasket, they break easily when improperly torqued. Silicon gasket maker usually leak over time if not properly bedded-in the pan-lip/gasket-slot.
I will be going to have my timing belt replaced including the water pump this weekend and the shop told me I need 4 to 5 bottles of toyota pre-mixed so I guess your right with the coolant. Btw the shop quoted me the following:
T- belt (oem toyota) - 3,300
Tensioner (koyo) - 2,300
Water pumo (gmb) - 4,100
Labor - 4,500
Are the price reasonable? I will be buying T-Belt from toyota which is much cheaper but other items im not quite sure. For the idler bearing and oil seals the shop told me no need to replaced if no problem.
^ no idea sa prices, we haven't changed t-belts pa kasi, puro chain-driven or timing gear yung iba
i would have replaced the seals if i were you kasi sayang ang labor
malayo ba presyo ng OEM tensioner vs Koyo? reputable brand naman yun pero kung di naman nalalayo, i'd go OEM
parang mahal yung water pump for a replacement GMB
I always buy from Toyota for the parts and have little knowledge on where to buy aftermarket brand from reputable store. I appreciate if you can provide the number of the shop selling Koyo and GMB so that I can compare prices.For the oil seals are there 2 oil seals or just 1? also the idler bearing do I need to replaced this? Casa recommend to replace it but the shop told me not to replaced if no problem. Im getting different answers.
Mga bro, I have an Innova 2008 Gas and I religiously do a PMS outside of casa every 5k km with change oil (15w40) and oil filter change. I am reading a 130,000 km ODO but I have not done a fuel filter change and now I realized that it should have been done every 40,000km. What is the part number of the fuel filter for our Innova? Could I use another brand other than OEM for that fuel filter?
By the way, wala akong problema so far.... But still the same, I think it is already long over due, right? I do not have to wait na magka problema dahil hindi ko napalitan di ba?
Aside from fuel filter, do I have to perform any change of the ATF? I have read kasi na I only have to check the ATF level every now and then...
Any unit owners using Petron ATF as their power steering fluid? no problems so far? Because some psf might be too abrasive and would damage the hose.
At 120k it should be major (replace all filters and fluids).
FF is environmental/cartridge-type, lots of store selling online.
With the ATF, if it was not replaced every 40k then don't replace it since new fluid will dislodge the dirt and clog/damage the pump/solenoid. There is a procedure of changing ATF gradually to avoid damaging the tranny.
Sir, thank you for the part number. Went to casa to inquire, at first the sales person told me that fuel filters for gasoline engines seldom are changed but I told him that the owners manual says that it should be changed after 40,000km and he checked their system and said that the filter is part of the fuel pump and the whole assembly is around 16,000.00. I was then held aback and remembered your part number you provided and the sales person in casa then said that that fuel filter part costs around 3,500.00. I took pictures of the OEM fuel filter but did not purchase yet. Checked online sellers of the fuel filter and saw one Nitro yung brand and cost 400.00 sa lazada. Will be looking from local auto parts stores but can you please suggest a reputable brand for fuel filters that I'm looking for... thanks in advance
Need pa ba palitan yung Filter Atf? Hindi ba pwede hugasan na lang yun since metal naman ata yon.
Sent from my SM-G950U using Tapatalk
Pwede naman kung kaya mo linisin babad sa acetone o brake cleaner overnight siguro tangal lahat ng dumi trapped sa filter. Kung ako palit nalang para wala iniisip.
BTW iba yung filter sa loob ng tank na sinasabi ng casa, yon yung kasama sa pump-yung parang tea bag filter doon sa dulo ng intake hose. May separate filter sa fuel line at yun yung pinapalitan periodically.
