^ go get yourself proper headlight retrofits. Xenon concepts can do the innova projector retrofit for around 10k. Mas sulit than the keon sondra bulb that costs about 6k imho
Sent from my MI MAX 2 using Tapatalk
Belated Merry Christmas mga ka tsikot.
Tanong lang po. Paano ba pinapalitan yung rubber ng wiper nung harap at likod ng Innova natin o may alam.ba kayong shop sa qc area na nagpapalit nun?
Maraming Salamat.
the front is easy.
one just has to learn how to remove the blade from the arm, via a "special procedure" that is easy to learn. and just like many instructions, following the instructions initially entails some guesswork. it's like one of those hand puzzles... difficult if one does not know how, very easy once one learns how.
installation is the reverse of the removal procedure.
the most difficult part is reaching over from the side of the vehicle, to get to the blade.
i am confident, you can ask the tambay mechanics around the store, to do it for you. "pang-taho na lang, boss."
the rear plastic wiper is something else.
i haven't changed mine since new, even as the rubber is already feathery. i rarely use my rear wiper kasi.
as i am adventurous, i would probably crack off one of the locking ends of the plastic holder, slide off the blade inside, and slip on a new refill that has been cut to size. HEY! do not cut at the end with the locking mechanism; cut it to size, at the opposite end. namimili ng diameter ang holder, so we better have the right diameter size. unlike the fronts, the rear is plastic and is non-adjustable.
if i fail in the above procedure, i'd probably replace the entire wiper arm. one unscrews the wiper nut holding it, by exposing the plastic cover at the base, by pulling sideways at the "ears". malambot po, at hindi mag-ca-crack.
Yung wiper sa likod hindi ko pa napalitan, okay pa naman kasi kaya hindi ko rin natanong sa Ace kung meron sila. Try mong magtanong sa Concorde or Ace sa SM Malls kung meron sila. Minsan sila na rin mismo nagvo-volunteer na magkabit sa kotse mo.
Yung steering wheel cover ng Innova ko sa Ace ko din binili, sila din naglagay pinuntahan yung kotse ko sa parking. Medyo nahirapan silang ilagay kasi masikip talaga yung goma, pero sandali lang sinalpak, ayus.
Baka merong gusto sa inyo oh lalo na sa mga naka J and E variant na innova [emoji4]
Sent from my Redmi Note 5 using Tapatalk
Hello po fellow Innova owners.
New owner po kami ng 2013 Innova E Diesel MT.
All stock po accessories nya. Gusto ko sana magpakabit ng keyless entry system at head unit with backup camera. Any recommendations po na brand and store. Cainta po location namin. TIA
How do you remove the PCV valve from a 2.5 D4D 2KD-FTV?
Are they screwed in or wedged in?
Hi Guys,
Just read this item, anyone knows the location of the flasher relay. Meron before nagpost ng mga images but for the lower model ng Innova. Already replaced all my external signal light with LED since last year, nag titiyagan sa hyperflashing pag nagsisignal, while normal flashing naman pag naka hazard.![]()
Normally, it's located just under the instrument panel. You can even hear the noise or sound of the flash relay when you activate it. (SWITCH & RELAY & COMPUTER[COWL ILLUST NO. 3 OF 6(11 7- )LHD ] TOYOTA INNOVA/KIJANG [KUN4 ,TGN4#] (ASIA and MIDDLE EAST))
Our unit is Innova 2.8 DSL 2018
Inquiry lang po.
1. Ano po ba yung use ng nasa left side na meter (may nakalagay na 1000r/min)?
2. When to use S4, S5, S6?
3. When to use and stop using D (pag sa expressway po ba, ok pa rin gamitin si D?)
Salamat sa sasagot! [emoji1]
