Page 674 of 775 FirstFirst ... 574624664670671672673674675676677678684724774 ... LastLast
Results 13,461 to 13,480 of 15487
    Oct 2013
    #13461
    guys need help. our innova G 2013 started to have this squeaking sound when the road is bumpy. it just started now. do i need to have the front shocks repaired? or replaced na agad? can someone recommend a shop near QC and Manila? anong shock replacement ba ang OK and good bang for the buck? thanks.
    #13462
    Maybe have the bushings and tierods checked
    Nov 2007
    #13463
    Quote Originally Posted by barnz View Post
    Bring it to Velocity along aurora ave. Honest people and reasonable prices
    #13464
    Quote Originally Posted by babytoyoka View Post
    Good morning!
    Newbie po ako here. and Newbie po and 1st time ko po magka innova. Kakakuha ko lang po kahapon ng innova ko.
    Question lang po.
    Ano po mas prefer nyo po ba bilhan ng engine cover o hindi?
    Nagcacanvass din po ako engine cover..
    Thank you po sa mga sasagot and tutulong sa akin...
    What exactly is the engine cover that you are referring to bro?
    #13465
    you will have to find out, what the sounds are caused by. there are many possibilities. bring it to the shop.
    otherwise, you might end up replacing everything.
    Jun 2005
    #13466
    If its is the new model, the blake ornamental piece thst covers the engine is only available with the G and V variant. The E and J variant doesnt have this. Weird nga bakit nila tinanggal. Parang ewan lang.
    That cover costs 6k.
    Sent from my MI MAX 2 using Tapatalk
    Jan 2011
    #13467
    Quote Originally Posted by sirkosero View Post
    Kelan kay maglalabas ng facelift ng current model ng innova?
    I'm more interested when stability control will be found across all variants and not just in the totl.
    Nov 2018
    #13468
    Hi! We recently bought an Innova, got it 2 weeks ago. Napansin ko lang na prang hindi ganon ka-isolated ung cabin ng Innova from outside noises. I frequently use a revo and a crosswind, compared to these older cars parang mas napapasok ng outside sound ung Innova. Is this normal?
    Jun 2005
    #13469
    Quote Originally Posted by ngeshu View Post
    Go get yourself sound deadening. Malaki engine ng new innova. The added weight of the extra sound deadening material is easily handled by the engine.
    #13470
    i have an old innova.
    i am ok with its inside noise. nilakasan ko lang ang volume ng dzmm ni ted failon.
    sound deadening? i hear it's not cheap...
    Jan 2009
    #13471
    Well, the Innovas aren't exactly luxury vehicles so average to high-average NVH is to be expected.
    Nov 2018
    #13472
    Ok pa naman sa akin yung outside noises medyo naninibago lang ako compared sa crosswind at revo. Nagtanong lang din ako if normal kasi baka may lining or seal lang na hindi maayos.
    If the outside noise gets unbearable or annoying, I'd probably have sound deadening material put in din. Haha.
    May 2015
    #13473
    Tahimik kasi makina ng bagong innova. Compared sa revo at crosswind mas rinig mo makina kaysa sa mga ingay sa labas
    Sent from my Redmi Note 5 using Tapatalk
    #13474
    in truth, we should not expect the same level of nvh insulation in all cars.
    each manufacturer has its manufacturing priorities.
    another point to consider, is that not all traffic generates the same level of noise.
    but yes.
    the noisier the engine, the more it drowns out the other sources of noise around it.
    Nov 2007
    #13475
    Check the weatherstrips of the doors. Baka naging loose lang. Our new innova has great noise insulation, comparable sa camry at monty (2nd row at least)
    #13476
    oil viscosity could play a part also. a newly oil changed vehicle would normally feel smoother quiter from pre-oil change. from experience some well maintained broken-in old generation diesels like in the aforementioned revo could be relatively quiet nga pero yun bagong diesel ng toyota should be quiet too relatively speaking.
    #13477
    some car sellers intentionally put in heavier oils, to make the engine quieter.
    and to hide that flickering oil pressure warning light.
    #13478
    Yes, lakasan lang ng kaunti ang sound ng radio o stereo, - hindi na dinig o masked na ang hum ng makina o ingay sa labas ...
    May 2009
    #13479
    planning to put mobil 85w-90 sa transmission at differential ng innova 2013 (2kd) instead of the oem fluids.
    any feedback?
    Jan 2017
    #13480
    ask ko lang po if may naka experience na po dito at 100KPH NLEX parang my tunog sya na pumapasok na hangin sa loob passenger side, habang bumibilis sumasabay din ang tunog, 2018 Innova G. 700km ODO
Toyota Innova Owners & Discussions [continued 3]
