Page 624 of 775 FirstFirst ... 524574614620621622623624625626627628634674724 ... LastLast
Results 12,461 to 12,480 of 15487
    #12461
    Quote Originally Posted by shark24 View Post
    Good afternoon mga sir, tanong ko lang po kung may naka-experience na dito ng squeaking sound na galing sa makina ng Innova 2008? 2x pa lang siya nangyari, nung una pagkastart at yung sumunod the next day habang tumatakbo. Sinubukan ko apakan ng todo yung gas while idle pero hindi naman lumabas yung sound. tingin nyo po ba belt na to? kay erpat kasi yung innova kaya hindi ko namonitor yung mga PMS nya dati.
    Thank you in advance.
    it hasn't yet happened to my innova. but it did, to my other car.
    with the belt in the correct tension, my guess is, the belt idler bearing.
    to confirm, i try a few squirts of WD40 to it (the bearing! not the pulley mating surface!). if the sound disappears, then that's it.
    the long-term solution is to replace it.
    how much? i don't know.
    Feb 2006
    #12462
    Quote Originally Posted by crosswind View Post
    Any wax would do sir
    thanks sir crosswind sana po kahit may brand name po
    Jan 2009
    #12463
    Quote Originally Posted by jovz View Post
    tanung lang po ano po okey na pang alis ng scratches yun kahit mababaw lang po na gasgas
    I use this. They're available in popular colors (I have the Silver) so any residue will better match your finish.
    The bearing itself should be cheap. Replacing the whole assembly (including the damper) will cost more, tho.
    Depends on the wax. To fix light scratches, the wax should have polisher compounds that can clean up the light scratches. These waxes are otherwise known as Cleaner Wax.
    Car wax without polishing compounds and are typically applied as the final coating are called Finisher Wax.
    Oct 2016
    #12464
    Thank you po sir.
    Quote Originally Posted by dieselpowah View Post
    Baka fan belt.
    Have it check sa kilala mong mekaniko.
    Baka nga po sir. Thank you po.
    #12465
    in some models, the bearing can't be replaced. the entire assembly has to be purchased.
    i don't know about the innova.
    #12466
    [QUOTE=dr. d;2780456]The bearing itself should be cheap. Replacing the whole assembly (including the damper) will cost more, tho.
    i don't know about the innova.[/Good evening po, hingi lang po ako advise kung ano magandang product pang tanggal ng Acid Rain Stain sa car windshield. 'Yung para sa car body po? Maraming salamat po.
    Apr 2016
    #12467
    [QUOTE=Slasher07;2780904]
    for winshield try mo elevo brand medyo pricey lang then sa body try mo 3M synthetic wax maganda sya compare sa turtlewax
    Sep 2009
    #12468
    Include nila injector cleaner.
    Ot: di ma delete post using mobile browser and tapatalk..
    #12469
    Black is always a pain. It would not work on it based on my experience... 😂
    Jan 2009
    #12470
    T-Cut is available in Black. But you're right, your mileage varies with removing scratches from dark-colored paint. Silver is still, by far, the only color that's practically impervious to minor scuffs and scratches.
    Apr 2010
    #12471
    nag DIY replacement of fuel filter ako. mas mura ng onti yung element sa casa conpared sa auto supply
    binaklas ko to clean the assembly, it was surprisingly clean and no traces of dirt or sludge.
    pinalitan ko yung o-ring dun sa canister, pagpihit ko dun sa ring na nagsesecure ng two halves parang mahigpit masyado? or baka dahil lang kasi bago yung o ring?
    primed and one click start naman
    #12472
    Bakit ganun yung unit ko, napansin ko lang nung nanggaling kami sa sementeryo. Pag dating sa bahay, mga 5km mula sementeryo, napansin ko yung temp, mataas lang ng konti sa linya ng C, as in 1 mm lang. E diba ang normal temp ng innova is mga 1/3 or 1/2 sa temperature guage? Tapos the next day ganun padin , di masyado tumataas at parang medyo mahina ang hatak, naisip ko nga baka may sumama galing sementeryo heheh.
    Unit is 2012 G with only 46,000km.
    May 2012
    #12473
    sa mga naka stock tyres
    ano brand gamit niyo? may promo ba ngayon 3+1 ? wala kasi sa goodyear at yokohama
    mag 5yrs na kasi goma ko need na magpalit, at saktong napako at screw ung 2 gulong ko sa likod
    dapat talaga ugaliin icheck bago umalis or galing sa parking icheck ang gulong
    hindi ko na alam saan ako napako
    Jan 2014
    #12474
    Quote Originally Posted by evincar View Post
    I use goodyear assurance bought already two set since new
    May 2016
    #12475
    Quote Originally Posted by oliver1013 View Post
    baka nagstuck open po yung thermostat nyo boss kaya di tumataas yung temp nya.
    Aug 2013
    #12476
    malamig kasi panahon ngayon. pansin ko din, mas matagal than normal ma-achieve ng makina yung optimum operating temp niya.
    Feb 2006
    #12477
    tanung ko lang po mga sir normal lang po ba mas naging maugong yun fan ng innova kumpara sa dati after malagyan ng silicone oil, napansin po kasi ng mekaniko na mahina yun ikot ng fan, nun macheck ubos na daw pala yun silicone oil
    Apr 2010
    #12478
    ^ possible naman na masyadong malapot yung viscosity nung silicone oil and/or marami ang nailagay
    Feb 2006
    #12479
    ah pero mabago pa po kaya yun o mabawasan yun ugong
    Feb 2006
    #12480
    meron na po ba nagpapalit ng serpentine belt ng innova diesel dito nasa magkano po kaya ang price ng gnaun, nasa 74k km na po yun inoova namin posible po ba na ganitong mileage palitan na yun belt
Toyota Innova Owners & Discussions [continued 3]
