Page 620 of 775 FirstFirst ... 520570610616617618619620621622623624630670720 ... LastLast
Results 12,381 to 12,400 of 15487
    #12381
    I believe there are only two generations of the Innova. The 2016 'all-new' model is the 2nd Gen.
    From what I've read, the 2nd Gen has a 6-speed A60 transmission while the 1st Gen uses a 4-speed A/T; A340E for Diesel, and A45DE for Gas.
    Thanks bro.,- that aligns with what I know, too.. Good day!
    _/_/_/
    30.8K _/_/_/_/_/_/_/_/_/_/
    Feb 2015
    #12382
    Kung parehas lang sila sa innova e. Yung audio jack cable sir ginamit ko papuntang android fon to play music.
    Sent from my SM-J500G using Tsikot Forums mobile app
    Thank you sir mokong.. ang nagawa ko pa lang kasi e i-connect via usb cable.. subukan ko yung using audio jack 😀
    Sep 2009
    #12383
    Zic x7 5w-30 or x7 10w-40 for diesel fed innova? Sa labas na lang ng casa papa change oil. Thanks
    May 2009
    #12384
    regarding brake fluid replacement:
    may special tool bang kelangan during bleeding procedures....special tool for bleeding the abs????
    or pwede na yung usual "2-man pump & bleed" method?
    any info sa mga nagpapalit na ng brake fluid sa casa.
    salamat
    Jul 2016
    #12385
    Question sir sa pag diy flush ng radiator. Sa reservoir lang po ba lalagay bagong coolant? Diretcho na ba coolant sa radiator pag dun nilagay sa reservoir? Wala po kasing radiator cap innova natin tnx.
    Jun 2005
    #12386
    Quote Originally Posted by miked View Post
    salamat
    Samin. Gamit sa mga sasakyan yung mightivac na pang vacuum ng brake lines
    Sep 2016
    #12387
    Sir, Fyke,
    Amaron ang binili ko. Sa store near Roces and Quezon Ave.....fronting Fishermall.
    Subok ako ng iba.
    Thanks for the advise.
    Quote Originally Posted by fyke View Post
    Sir try replacing it with Amaron battery mas maganda daw ito kesa sa Motolite. Hindi ko pa na try but marami nagsasabi and plannig nto replace mine pag nag dead na battery ko. Hope this helps and madami na din sa market ang amaron battery sa OLX meron din nagbebenta.
    Oct 2005
    #12388
    Quote Originally Posted by ac.benitez View Post
    Sir, Fyke,
    Subok ako ng iba.
    Copy boss yan din bibilin ko kasi subok na ng grupo namin yan (Samahang Innova ng Pilipinas).
    May 2009
    #12389
    Quote Originally Posted by sirkosero View Post
    innova with abs din ba sasakyan mo brader?
    ang iniisip ko kasi baka kelangan ng special tool para maactivate yung motor, pump or kung anumang pyesa nung abs during the bleeding procedure.
    Jun 2005
    #12390
    Nope bro. Sa vios at sa mga honda namin ginagamit. Wala naman nasira na ABS.
    Yung innova, in the coming days pa magkakaalaman kung may masisira. Wag naman sana. Pero based sa google wala dapat problema
    May 2009
    #12391
    isa rin sa inisip ko e parang hindi na toyota kung kelangan pa ng special tools....what if kinailangan magrepair ng brakes or magbleed ng brakes on the road, kelangan pa tumawag ng casa kung nagkataon.
    btw, i was thinking of getting that mightyvac before...pero ngayon may nakita ako sa lazada. a cheaper version.
    Sep 2006
    #12392
    TNE quotation for 90k PMS of my Innova, including replacement of all fluids.
    paying 29k was nuts, and even taking out all the non-essentials i would still have paid TNE around 12k.
    Instead, I bought all the fluids and filter from TNE but brought the Innova to a local shop for service. All fluids cost me around 5.5k and labor from the shop was 1.5k so total damage, just 7k.
    Note: I asked the SA if it was really a requirement to perform ATF dialysis and they said it was optional. Normally they just drain and fill even at the 80k service interval, unless there was something wrong with the tranny already. So ended up doing a drain and fill as well.
    Oct 2015
    #12393
    Quote Originally Posted by ptk675 View Post
    Don't know if it's just me, but in the last 5 years Toyota service has become expensive. 5 years ago Honda and Nissan service cost more. Now it seems Toyota has one of the highest rates.
    Quote Originally Posted by Wh1stl3r2 View Post
    Everyday toyota/mitsu casas make over 1M 💩💩💩
    Oct 2015
    #12395
    I remember we spent 100k+ at Toyota C5 just for a pair of upper and lower arms. Nagmamadali lang kaya no choice.
    At least the parts last much longer than Hyundai, which for me are near disposable.
    Jul 2016
    #12396
    Ano yung engine metal protector sa quote? Sensya na outside casa kasi innova ko mula noon 5kpms.
    Wheel alignment and balancing 3300pesos? Wtf Dapat kasama na bagong gulong dyan.
    Jun 2012
    #12398
    Grabe 4k na engine decarbonizing na walang kakwenta kwenta. Easy money ang mga loko loko. Daming mga useless sa quote
    Up natin to para makita ng iba na kalokohan tong casang to
    Sent from my SM-N930F using Tapatalk
    Engine flushing 3550pesos?
    Wallet flush... sarap ipa inom ke ms rodelyn.
    Jun 2005
    #12400
    Hello. Got a 2nd hand 2015 innova 2.5E.
    Low mileage naman. Anything i should watch out for? Ano ba usual sakit nito?
Toyota Innova Owners & Discussions [continued 3]
