ano po ok na stepboard bukod po sa shark
Napakaganda tlaga ng innova G ko. Umaga tanghali at gabi puro innova kasama ko.mahal ko na talaga saka napakaastig tignan sa kalsada. :D hehe
Mga sir, normal lang ba sa matic yung pag Park na ako or Neutral, tapos pagbitaw ko na sa preno, may konting andar pa din? Ewan ko kung andar yun o yung body lang may galaw na parang biglang preno.
that's normal.
but allow me to recommend my procedure..
"when parking, step on the brake when your car reaches its intended position.
then put the stick to "N".
then apply the hand brake.
only then, do i release the foot brake.
then put your stick to "P".
then turn off engine and pull out key.
the "P" is not really intended as the main brake in parking. it is not strong enough, and can be damaged should the vehicle be forcibly moved.
and in some cars, the key may not be pulled out if the "P" position is not engaged.
Me ask pala ako pagka paakyat ba kelangan ba naka off drive o on drive sa matic? Ganun rin ask ko pagka pababa?
Mura na yan paps. Pero mura pa rin sa akin hehehe.
