Page 628 of 775 FirstFirst ... 528578618624625626627628629630631632638678728 ... LastLast
Results 12,541 to 12,560 of 15487
    Jan 2009
    #12541
    Quote Originally Posted by frequenzy View Post
    since ang innova fixed ang wheel alignment ng rear, anu possible cause ng inner wear sa left rear tire? yung right rear naman ok.
    Possible causes:
    1. When the tires were rotated, that particular tire probably came from one of the front tires, which may have been out of alignment, OR
    2. Wheel bearing(s) on the solid axle is worn out
    Jan 2009
    #12542
    Possible causes:
    mukang malabo yung 1, since hindi ako nagrotate ng tires. simple lang ba yung wheel bearing replacement at kaya sa mga gasoline stations? sa shell lang kasi ako nagpapachange oil. nasa 65k na rin yung odo.
    Jan 2009
    #12543
    ngayon nga pala pinagpalit ko lng yung rear tire, to check kung mapudpod din yung isa.
    Jan 2013
    #12544
    Quote Originally Posted by homhomnova View Post
    I am planning to install unichip in my innova gas. Pero gusto ko muna sana humingi ng inyong feedback.
    Tanong ko sana kung meron ng nakapag install ng unichip sa inyong ride. Totoo ba na may added power in terms of toque and whp?
    I called speedlab and they said 10 to 15 increase in torque at 10 to 15 increase in whp din.
    Your feedback will be greatly appreciated and will definitely help in my decision.
    Btw, I already installed sprint booster TC and knn air filter and I am quite happy with it already but I am curious with this piggy back.
    Up ko lang po mga sirs..
    Jan 2009
    #12545
    share lang.just replaced rear shocks sa innova, kyb at 1150 each, orig fuel filter and air filter, 750 at 1k.
    Jun 2009
    #12546
    KYB gas shocks or fluid? Musta naman po and ride?
    Jan 2009
    #12547
    Quote Originally Posted by desertfox615 View Post
    its gas type, didn't notice any difference with the stock shocks.
    #12548
    after 3 years of suspicion, i have finally decided to find out if my diesel innova's thermostat is stuck, or if it is installed at all! napaka-bagal kasi umakyat ang temp needle, unlike my other innova.
    problem is... saan po nakalagay ito sa engine block? i tried google, to no avail.
    a little help, po?
    May 2016
    #12549
    a little help, po?
    di pa ko nakakapagpalit ng thermostat ng innova (diesel) namin. pero nacurious lang din ako nun kung san sya nakalagay para alam ko na din incase na magloko sya. ang kaso (correct me if i'm wrong) mukang mahirap sya i DIY kasi sa may lower hose sya nakalinya.
    Attached Thumbnails Attached Thumbnails 3_1kd-ftv_prado-2_386.jpg   thermostat-innova.jpg
    Jan 2009
    #12550
    a little help, po?
    Same here. I think my 2015 Innova D4D might also be missing the thermostat.
    On your other Innova that presumably has a thermostat, how long does it take to reach normal operating temp (half-way mark on the gauge) when just left idling?
    #12551
    sorry, po, but i don't know. i drive out immediately, kasi. sayang crudo...
    but in my older innova, my needle settles to its usual level, just slightly below 1/2, within 2 km.
    in my newer one, halos tapos na ang 5 km trip, ay hindi pa umaabot dun sa same level as above. eventually a-abot din siya, but later pa.
    #12552
    Quote Originally Posted by treb23 View Post
    thanks!
    kaya yan! .. ang pinaka-mahirap siguro dito ay yung pag-basag ng gasket seal.
    and that fact that i have to grow an extra joint in my arms...
    Jan 2009
    #12553
    I think we're in the same boat. Even when I've driven several kM, it takes forever for the needle to reach the normal spot. If the engine is left to idle, it'll probably take all of 15 or so minutes to get to operating temp.
    With a thermostat, this should be like 5 minutes on idle or 3 minutes when you drive off immediately.
    Aug 2013
    #12554
    ask mo sir kung plug and play yung piggyback (unichip). kung plug and play, mas maganda kasi madali baklasin kung nagpapa Casa ka pa. mas safe din kasi hindi na kailangang mag splice ng wires.
    yung 10 to 15 WHP increase, malaking difference na yun sa current power ng engine mo pero mas maganda kung malaki din ang improvement sa torque, mas hindi hirap mag overtake.
    weigh mo na lang yung price sir, worth it ba yung P2000/HP na price niya? (assuming na P30K yung unichip tapos 15HP ang increase).
    May 2013
    #12555
    Hi guys,
    Do you have any leads if there are, Toyota dealers that still sell the previous model? Maybe they're offering it at a discount? Baka mas affordable na. I'm interested at their base to mid level if available.
    Thank you.
    #12556
    Quote Originally Posted by bugoys View Post
    Hi guys,
    Thank you.
    ako rin! inform nyo rin ako.
    #12557
    I suppose this is the d4d innova? Matagal talaga umakyat to normal temp ng diesel, unlike sa gasoline engine na 2 mins lang normal operating temp na
    #12558
    my old 2005 thailand-assembled innova's temp needle went up pretty fast.
    my 2012 locally assembled one, took forever to reach the same needle position.
    my 2005 model is also 10% more fuel-efficient than my newer one.
    #12559
    Fellow Innova owners, ask ko lang how long ba talaga before pinapalitan ang FUEL FILTER ng Innova diesel?
    Sabi kasi ng casa on a per need basis lang nila pinapalitan ang fuel filter. No fixed number of kilometers.
    So I'm running 30,000++ kms now, and if the fuel filter is still "clean", then Toyota casa won't change it. Tama ba ito?
    Sabi naman sa Isuzu, the diesel experts, Isuzu vehicles need to change fuel filters every 10,000 kms. Yan ang Preventive maintenance schedule nila.
    Sabi naman ng mekaniko, every 10,000 kms. dapat magpalit na sa dumi ng diesel sa Pilipinas.
    So bakit sa Toyota ganun ang PMS on fuel filter? Maganda ba talaga quality ng fuel filter nila?
    #12560
    So I'm running 30,000++ kms now, and if the fuel filter is still "clean", by say, 35,000 kms., then Toyota casa won't change it. Tama ba ito?
Toyota Innova Owners & Discussions [continued 3]
