How do you open the cowl under the wiper to access the ac inlet vent?
Unhook the rubber weather strip and fold it over to the driver side. No need to remove the whole thing as the cowl is divided into two.
To remove the round clip that holds the cowl down, press the center button with a key or blunt tool to unlock it. Once pressed in, extract the whole clip. The cowl should come off by unsnapping it from the body and the driver side cowl.
To reset the button clip, pop out the center lock, reinsert the clip and depress the center lock until it sits flush with the clip's head.
For simple drain and fill ng ATF ilang liters dapat sa innova? Sabi sa casa 4 liters daw, may nabasa ako 3 liters lng daw.
Alam ko din 3 liters eh. Btw, u dont have the manual with me
Sakto lang sir yung 3liters tingin ko. Nun nag diy kasi ako yung 3.5liters sobra sa dipstik
Sent from my SM-J500G using Tsikot Forums mobile app
Good eve mga bossing.😊 Hihingi po sana ako ng advise para sa Toyota Innova G 2015 20k km pms. Ang sabi po kasi ng SA sa akin eh nasa 20k pesos daw ang babayaran ko. Tapos sinulat niya po ang mga gagawin. Ito po yung mga sumusunod;
- palit ng break lining
- change oil
- oil filter
- aircon vacuum
- linis aircon
- linis makina
- babaklasin mga nasa ibabaw
Please advise naman po, kailangan po ba talaga mga yan or may other options po na pwede gawin? Salamat ng marami mga bossing. 👍😊🙏
Bro read the maintenance chapter sa owners manual.
A/c maintenance isnt necessary. I would prefer they dont touch my a/c lines. Lalo na pag ice cold parin.
Oil change lng dapat and brake cleaning...
Speaking of PMS.
Had a major PMS of the innova outside casa.
1st 10k km pero since 2nd hand yung unit medyo extreme ang ginawa ko.
ZIC x7 5w30 7 liters: 2000 pesos.
BT223: 235 pesos
ATF T-IV 4 liters 1200 pesos (discounted sa casa)
PS fluid: 1 liter ZIC 300 pesos
Change brake fluid= 1 Liter prestone 230 pesos.
Cabin filter 300 pesos
Labor suking mekaniko 600 pesos.
Linis brakes, inspect bolts, suspension, linis air filter
Pwede na uli sa long drive
leave the aircon alone. i let the guys open the aircon when it doesn't cool, anymore.
unless you plan on entering her to a beauty contest, i'd ask the guys to leave the dirty engine alone. it'd just get dirty again in a few weeks.
change brake lining after only 20K? i changed mine only when it started making funny noises, well after 50K. the funny noise was the built-in warning that my brake lining was getting thin. you can decide for yourself, when you see the lining of your vehicle, po.
Good day sir madame, tanong ko lang sana if how much po ang tensioner pulley assembly kung sino man nakapag palit na nito.
di po ba pwede yung bearing lang po palitan? maingay na po bearing nya.
Meron na rin po ba nagpalit na ng belt sa Innova dito?
Innova VVTI 2005.
Salamat po sa lahat.
tanung lang po ano po okey na pang alis ng scratches yun kahit mababaw lang po na gasgas
Good afternoon mga sir, tanong ko lang po kung may naka-experience na dito ng squeaking sound na galing sa makina ng Innova 2008? 2x pa lang siya nangyari, nung una pagkastart at yung sumunod the next day habang tumatakbo. Sinubukan ko apakan ng todo yung gas while idle pero hindi naman lumabas yung sound. tingin nyo po ba belt na to? kay erpat kasi yung innova kaya hindi ko namonitor yung mga PMS nya dati.
Thank you in advance.![]()
Baka fan belt.
Have it check sa kilala mong mekaniko.
