Page 617 of 775 FirstFirst ... 517567607613614615616617618619620621627667717 ... LastLast
Results 12,321 to 12,340 of 15487
    #12321
    Further, front shocks,- at what mileage did you change yours, bros?
    [I think I saw some traces of leak when we lifted the Innova a couple of nights ago]....
    How long did it take for the shop to do this activity? TIA (again)....
    Note: Replaced my rear shocks (with visible leak), at 35KKm...
    _/_/_/
    30.7K _/_/_/_/_/_/_/_/_/_/
    i replaced mine at about 90K km, when the car was already dribbling after going over humps.
    i chose the lighter duty white ones, kyb yata, thinking it would be softer.
    judging from the "hardness" up to now, 15K km later, i will probably get the black, fatter, more heavy duty ones, the second time around. ang tigas pa rin nung puti.
    Jan 2013
    #12322
    Quote Originally Posted by oliver1013 View Post
    Mga ka Innova, talaga bang aabautin ng P12k ang replace atf ng ating Innova? kamahal naman, 2 talyer na nag quote sa akin, 10 litro daw uubusin flush palang. Grabe naman
    12k din quote sakin ng speedyfix - atf dialysis 12 liters daw atf uubusin. Sa Toyota North Edsa naman 6.9k quote sakin - atf flushing naman tawag nila at 8 liters daw uubusin. Tapos sa Exalta banawe 600 labor ng atf dialysis 8 liters din daw uubusin at pwede magdala ng atf.
    Naguguluhan na ako kung sino tama sa kanila. Parang leaning towards drain and refill na lang ako tutal 32k+ pa lang naman odo ng innova ko.
    Sa petron 200 lang labor bili na lang ako atf sa casa.
    #12323
    Quote Originally Posted by homhomnova View Post
    Bro - Bought ten liters of Toyota atf and had atf dialysis from a shell station for P500...
    I do not remember the price per litre of the Toyota atf but I am certain that it is significantly lower than P11.5k...
    #12324
    Thanks for the feedback bro.
    The right front shock has leak. However I do not observe any performance degradation with it. I'll keep this in mind for my next PMS...
    Ours is gasoline and I think yours is diesel, right? So I guess that with everything else equal, ours with a lighter load, should have slower wear.
    #12325
    Wow iba iba nga, sa akin 46,000km na, ano ba ang dapat. Ang goal naman is tumagal ang ating Transmission. Kung drain and fill ba ayos na ba yun up to 80,000km at drain and fill uli.
    #12326
    Sa Toyota (casa) bro.,- drain and fill every 40KKm.....
    Sa manual,- replace every 80KKm. If exposed to severe driving conditions, replace every 40KKm.... Toyota is following the latter [schedule (only)] in the PMS.
    _/_/_/
    #12327
    Just did minor PMS. 55k km na 2005 innova namin haha
    #12328
    batang bata!
    ours is '06 nasa 161+K Kms na
    #12329
    Nag major PMS na ako nung 50k km hehe coolant nalang hindi pa napalitan. Tires might need replacement soon. Weekend/coding car lang kasi e hehe
    #12330
    Gasolina pala ang Innova mo bro.,- pareho tayo....
    Ours is 45KKm at 3 years younger than yours....
    I will be replacing the PS, Brake fluids and Coolant in the next PMS... Probably the tyres too....
    I could still feel the tyre grade in the tyre markers e....
    _/_/_/
    Jun 2014
    #12331
    they might not honor warranty on a busted shock absorber with 23K km on the odometer. wear and tear item, yata.
    but i hope you get it, po. sayang din. anyway, relatively cheap lang naman yan, kung bibilhin.
    Kasama sa warranty dr d un shocks..2x na ako naplitan ng toyota bicutan.front at rear.
    #12332
    Quote Originally Posted by Stewmaker View Post
    good for you!
    Oct 2014
    #12333
    Nearing 25k PMS (currently 23k) PMS for our 2014 Toyota Innova Gas. Sabi sakin due na ako for Engine Decarb nung 20k PMS. mas malaki daw gagastusin ko ngayon kasi isasabay ang linis ng aircon at engine decarb. hindi ko alam kung ipapagawa ko na ito parang ang baba pa kasi ng odo for it. hmmmm...
    #12334
    First time mo pa lang magpalit bro?
    Ilan years ba buhay ng radials?
    BTW may buy 1 take 1 goodyear for our OEM specs
    Jun 2012
    #12335
    Quote Originally Posted by Salamander13 View Post
    Kalokohan yan sir. Modus ng casa. Hindi kailangan yang decarb. Wag nyo gawin
    Sent from my SM-G920F using Tapatalk
    Sep 2009
    #12336
    How much ang 20k pms mga boz? Already at 18.5k run na ang 7 months old inno namin. Madugo yata ang 20k eh.
    #12337
    engine decarb? aircon linis? nasa owner's manual ba yan? kung wala, ay optional lang yan.
    in lieu of engine decarb, itakbo na lang nyo sa expressway nang 100 kph for 30-45 minutes, on the way to tagaytay or nasugbu or baguio. ganun na rin yon.
    aircon cleaning? i never did. i have them open and clean the aircon, when it refuses to cool. i reckon, pareho lang o mas mababa pa, ang gastos. but this is my opinion only, po.
    look at your manual, po, and see the required maneuvers for the 25K pms.
    Oct 2014
    #12338
    Pupunta kami ng Baler by next month. dun ko nalang gawin. hehe! Yung aircon kasi wala ring problema e. unless siguro humina. Yung isa naming oto (Hyundai Getz 2010 model - never cleaned) pero super lamig parin kahit tanghali.
    #12339
    ikaw na rin ang maglinis o magpalit ng aircon filter.
    ako, hinuhugasan ko lang. mahal kung bibili, e.
    Jul 2016
    #12340
    Yung innova ko 2012. After 5k pms dinako bumalik casa hehe. Hussle kasi pila and mahal pa. 70k+ na odo. Change oil lang every 8k ginagawa ko using vic. Wala pa naman nasisira. Aircon never been cleaned and open.
    Sent from my SM-J500G using Tsikot Forums mobile app
Toyota Innova Owners & Discussions [continued 3]
