palitan ko sana cabin filter, inquired Gant kung magkano, 900 OEM and 300 for replacement
binaklas ko and may konting dried leaves and lint, at maitim. washed it with detergent and brush. eventually papalitan rin pag numipis na due to constant washing, hindi yata talaga washable yun
next project ko ay DIY oil catch can and fuel filter replacement. saan bagay ilagay yung OCC and pano ang mounting?
A regular Shell gas station in your neighborhood should have the dialysis machine bro.... It is now a fairly standard car service equipment....One was just outside the village.
I bought all of the ATF from Toyota Alabang. I do not remember now the cost per liter. I remember paying P500 for the service....
^mura lang pala, dialysis na yun sa shell
akala ko 1k-2k damage
kahit ba 4-5yrs palang need pa dialysis? or kahit drain nalang pede na?
biglang umilaw yung airbag icon sa dashboard habang nag dra-drive ako. kaya ang ginawa ko, pinatay ko yung makina at start uli. nawala naman yung warning sign. meron bang naka experience sa inyo ng ganito? after now. ok naman na. almost 5 yrs na yung innova J gas ko. TIA
good day to everyone. mga sirs, i hope you can help me with my headache. my car, a manual transmission, diesel fed, toyota innova 2014, as i have observed, lost some speed or power. i dont know which is which (speed or power). explanation: 3 months ago, it used to give me a good speed at 2,000 rpm.
at gear 1 it gives me 20km/h
gear 2 --> 40km/h
gear 3 --> 60k/h
gear 4 --> 80km/h
gear 5 --> 100km/h
but now it gives me lesser speed for the same RPM (2,000rpm)
gear 1 gives me 16km/h
gear 2 --> 34km/h
gear 3 --> 54 k/h or less
gear 4 --> 80km/h
gear 5 --> 90km/h
in short, there is around 20-25percent speed reduction or power reduction regardless of the RPM (either 2,000 or 3,000rpm). i dont know which is which. i have asked mechanics and they gave me different suggestions - all of which never rectified the problem.
oil change
gear oil change
fuel additives
engine air filter
engine oil filter
fuel filter
all done but the problem still persist. can you please enlighten me on what could be the problem?
thanks in advance po sa sinumang sasagot at talagang masakit sa ulo isipin .
When an engine is doing 'x' RPM, with the transmission set to 'y' gear, the resulting vehicle speed 'z' can be determined, as they're mechanically connected. In other words, if you measured it correctly the first time, the results can be reproduced and should give you the same results as before.
If not, one of two things may be happening. The speedometer is not giving the same readout as before or your clutch is slipping.
salamat bossing. dahil sa suggestions, may idea na ako kung saan ko pwedeng i-zero in ang solutions. i am more leaning to the clutch slipping. yung speedometer kasi mukhang ok naman. dati nag flick yun from zero- to biglang 50 then zero ulit kahit umaandar. pero ng nilinis ko na ang sensor hindi na naulit ang problem.
baka po may alam kayo na maayos ka deal sa clutch services? around kalookan area or pwede rin tondo at QC. maraming salamat po. more health and power to your family!!
salamat po bossing sa suggestions, i will check these two items. nakaka lungkot kasi pag natingin ako sa RPM / speedometer tapos hindi na parehas ng 3 months ago. kahapon nga long drive NLEX mas lumala. a few days ago 80KPH something sa 5th gear using 2k RPM pero kahapon 75KPH. napapa isip nga ako baka clutch naman medyo hindi na madikit.![]()
Try mo check speed mo sir using gps para ma check mo kung accurate speedo meter mo. Dapat minimal lang difference mga 3kph. Gamit ko digivel apps. Tnx
Sent from my SM-J500G using Tsikot Forums mobile app
loss of power sa diesel... hmmm, experienced this sa casa maintained isuzu trooper AT moonroof ed, culprit clogged injectors due to poor quality of diesel in phil used on a japanese designed to run diesel engine...
now the question is, what fuel do you use and what preventive maintenance do you do?
may mga instances na gumagamit ako ng fuel save na diesel ng shell dahil minsan, walang supply na nitro diesel (premium diesel) mga 40percent since nabili ko ang unit ay fuel save kinakarga ko. wala po ako preventive measures sa diesel injectors maliban sa fuel additive na nabibili sa petron panglinis ng carbon deposits.
