Page 613 of 775 FirstFirst ... 513563603609610611612613614615616617623663713 ... LastLast
Results 12,241 to 12,260 of 15487
    #12241
    Quote Originally Posted by frequenzy View Post
    innova 2012 at 60k, no major replacements just regular 5k pms sa shell.
    napansin ko parang nagiging malikot yung manibela lalo na kung medyo uneven yung road. kapag straight road wala naman issue yung kabig.
    depende po.
    if it's only slight likot, than that's normal.
    if you have to fight hard against it, that's abnormal.
    Aug 2013
    #12242
    fuel filter?!! before 10K km?
    i've changed my fuel filter only twice in the car's 100K km life so far. and one was because i couldn't get that damned fuel filter warning light to turn off!
    No, Sir. 1st time lng nagpachange oil out of casa pro 65K na odo ko & 3yrs na din si innova. I decided na papalitan na kasi umilaw na fuel indicator. I tried to flush out pero nandun prin then I discovered this method sa net of removing the electrical connector from fuel filter while engine off, then switch on & put back the connector after 3secs. It works the light goes off. But since schedule na rin kako ng change oil nya & I really assumed na madumi na filter pinapalitan ko na and un nga confirmed sobrang dumi na filter likewise, ung fuel inside the housing.
    Jan 2009
    #12243
    depende po.
    hmm, di pa naman lumalaban pero it's lose compared nung bago pa. hehe!
    Aug 2013
    #12244
    ipa check mo shocks sa next pms mo. malambot or may leak na.
    ganyan din yung sakin, tapos sobrang ramdam din yung lubak, palit shocks na ako sa harap. nawala yung ganyang feel, naging compose yung sasakyan lalo na sa highway na hindi pantay yung kalye.
    May 2009
    #12245
    Quote Originally Posted by Vann-O View Post
    Here's the cost breakdown po:
    Wurth 10W-40 (Synthetic), 7Liters (1L/P400) = 2,800
    Oil filter = 800
    Fuel filter = 1,500
    Air filter = 1,200
    Cabin filter = 1,800
    after reading threads/comments & online regarding sa prices, i think mjo mahal singil sa akin. Mali ko lang mas huli ung effort ko magresearch bago nagpagawa...newbie kc hehe
    aha! mejo malaki ang ipinatong. hehe
    yung oil filter ng toyota is around P400 plus lamang nung huli kong bili.
    P862 yung fuel filter.
    yang air filter naman i think is 1k lang ata yung nakita ko sa display ng toyota baguio at la union.
    ganyan pala kamahal yung anliit na AC cabin filter.
    well at least nalaman mo na kung ano ba dapat mga presyo sir....either you change your service center sir or buy the parts at toyota then sa labas mo na ipagawa.
    May 2009
    #12246
    wow naman dok.....50k km replacement interval sa fuel filter (on the average)? di naman kaya nagkagasgas na high pressure pump at nozzles nyan?
    #12247
    Quote Originally Posted by miked View Post
    hindi ko alam. hinihintay ko kasing umilaw ulit ang fuel filter indicator.
    after 105K km, the engine still performs like brand new.
    Aug 2013
    #12248
    Mjo pricey nga sir mga filters nya, may nakita ako cabin filter for toyota in OLX ranging from 500-700 lang. Hindi man lang kasi ako tinanong ng service center ng other options. but anyway, that serves as a lesson for newbies like me next time alam ko na!
    And by the way, iba pa rin minsan pag nagbabasa ng manual. I've watched them change my oil, napansin ko 6L lang ung suppose na ilalagay nila so I told them na diba dapat 6.9L. Dun lng sila kumilos para kumuha ng 1L pa.
    Apr 2010
    #12249
    kasya ba Baldwin B2 or Fleetguard LF3487? or Baldwin BT223 lang ang pwede? any other aftermarket filters?
    Aug 2013
    #12250
    Hi Sirs!
    Consult ko lng my experience with my inno. 1st time nangyari. Last week we attended an occasion, about 1hr naka-park then pagbalik namin ayaw na mag-unlock ung doors. Inspect ko mismong key kung umiilaw, ok nman. I tried to play with it (i.e. alternate lock/unlock several times) but no luck so I have no choice but to "force entry" --- of course the alarm activated.
    What causes this? Is it my key..early sign of battery deterioration? Eh until now ok naman na ulit...
    Or mismong sensor ni inno? Do I have anything serious to worry about?
    Btw, my inno is 2014 model (2yrs 9mos old) G Diesel M/T..
    #12251
    Hi Sirs!
    the first time i had it, it turned out to be the remote's battery, dying.
    err... malakas pa ba ang pag-ilaw ng remote? dapat ay kitang kita yan.
    #12252
    Hi Sirs!
    Did the other vehicles with remote control lock/unlock encounter the same problem?
    I assume that the key is OEM,- did you try powering it off and then on? Or, removing the battery and re-inserting it?
    Did it work after?
    _/_/_/
    30.5K _/_/_/_/_/_/_/_/_/_/
    Aug 2013
    #12253
    Upon checking it now, yes sir malakas pa naman! Hassle lang talaga pag inabot ng ganun sa parking akala mo kina-carnap mo sarili mong sasakyan..kidding!
    Really, what an inconvenience..
    Pro siguro replace ko na din remote battery as preventive measure kasi almost 3yrs na din cia.
    Jan 2009
    #12254
    I don't know how advanced the keyless entry is on the Innova but it may be possible that it is a security feature.
    Many car alarms will go into lock-out mode when it detects what seems like somebody's trying to brute force into the car by trying random encrypted RF codes. Once it enters that mode, it will stop responding to any RF code for a preset duration, even if the correct key fob is used.
    Think of it as typing the wrong password into your computer or website one too many times. That will usually result in the system requiring a password reset/recovery or lets you wait for a predetermined delay before you can try again.
    Another possibility is that the area where you parked has excessive RF interference. That would either trigger the lock-out or prevent it from receiving the relatively weak signal from the key fob.
    Aug 2013
    #12255
    Did it work after?
    _/_/_/
    Yep OEM sir. Actually, as I got home I did remove & clean the battery & contact points. So far I haven't experience it ulit.
    Aug 2013
    #12256
    That I can't answer
    Pero teka baka nga my kumalikot ky Inno while we are away ah so she locked herself out!
    Oct 2009
    #12257
    ung infrared sensor (reciever) ng alarm medyo malayo ba pinto?
    minsan kasi kahit di sa innova nangyayari yan kapag medyo mahina na ung batt ng remote.lalo na kung Open parking ka pumarada
    Jan 2009
    #12258
    Quote Originally Posted by jaypee10 View Post
    The keyless system works via RF, not IR.
    Jan 2013
    #12259
    Hello mga ka innova.. out of curiousity lang.. ilang torque and hp ba ang nage gain pag kinabitan ng unichip ang innova natin?
    Btw.. meron na pala unichip na pang vvti.. kala ko pang diesel lang unichip.
    maraming salamat..
    Oct 2014
    #12260
    Busted rear driver side shock absorber * 23k ODO Time for a warranty claim!
Toyota Innova Owners & Discussions [continued 3]
