Page 563 of 775 FirstFirst ... 463513553559560561562563564565566567573613663 ... LastLast
Results 11,241 to 11,260 of 15487
    Oct 2015
    #11241
    Hi goodpm. My alm po kyo ng oofer ng low down for innova G dsl AT?tia po
    Nov 2014
    #11242
    Sir para sure ka sa condition ng battery mo ipa capacity check or load capacity check mo sa battery shop meron tester to check the status of your battery
    Nov 2014
    #11243
    newbie lang mga sir ... have done a mod on my innova by installing a 2 stage oil catch (home made) and off the shelf items just making sure that the bronze filter and metal filter is cleaned every 2 weeks to make sure there will be no back pressure or build up that might damaged the oil seal on the crankshaft, this is installed between the breather outlet on the cylinder head cover-- before it enters the rubber manifold that connects the air filter and the turbo .... did also blanking of the EGR, using semi-synthetic oil from shell grade 10w-30w been 2 years so far no oil accumulation sa rubber manifold between the air filter and turbo.... so far so good .....
    #11244
    Good day mga bossing, tanong lang if you've experienced yung slight arangkada when you reached the 80kph speed? Does that mean the turbo charger kicked in or it's just a change of gear on A/T's or both? TIA..
    Nov 2014
    #11245
    Sir you can do it by yourself the cabin filter can be easily accessed by removing first the glove compartment then you can open the cover to gain access to the filter if you want to replace it by all means but on my experience I found out that the filter is hand washable and can be reused ......
    Nov 2014
    #11246
    Quote Originally Posted by MrQ5 View Post
    ayon sinagot na ni sir CVT, may benefits ang pag rev upto redline paminsan minsan to expel carbon build up. yun ang paliwanag saken ng toyota ewan ko lang kung totoo hehehe. "poor man's decarbonization" ok ba?
    Mga sir maybe you can rty decarbonization using water being sprayed into the the intake ---- steam wash effect to clear the carbon build up you can check out this on you tube on how to decarbonize using water....
    Nov 2014
    #11247
    Sir since nagpalit ka ng filter change oil there might be some residue or langis na tumulo sa crankcase area ng makina di napunasan o nalinisan this will eventually turn in to smoke once the engine starts to run and reach its operating temperature probable cause of the smell of burning oil
    Jan 2012
    #11248
    Quote Originally Posted by sn0wbLind View Post
    Up ko lang po! [emoji16][emoji106]
    Sir, sa akin gas na 05 model, so far eto na maintenance nya (1)air filter (2) fuel filter (3) oil filter (4) head gasket sealants (5) oil change and spark plug every 10k (6) 4 tires (7) fuel pump at 100k kms (8) coolant cover/gas tank cover (9) wiper arm (defective) (10) coolant bypass valve from plastic (2005 model) to alloy (2014 model) (11) brake system cleaning (12) battery (13) aircon evaporator (front/rear) replacement and system cleaning (14) front camber alignment - para ok acceleration at speed kahit 180 pa.
    Sundan nyo lang po yung nasa manual, may maintenance schedule sa parts kahit out of warranty na. Yung iba sa listahan ko, defective na kaya kailangan palitan kahit wala sa schedule.
    Wala pa po ako napalitan na fuilds for transmission/differential. Longlife naman daw sabi nila sa toyota. Next plan is car alarm na di na gumagana.
    thanks
    #11249
    wrong post
    May 2012
    #11250
    *natzt
    ilan na odo mo sir?
    near 30k palang ako pero parang gusto ko na pa replace transmission at differential gear fluid
    innova 2012 E
    katakot masiraan transmission AT kasi saken
    May 2012
    #11251
    *natzt
    ilan na odo mo sir?
    innova 2012 E
    Mar 2005
    #11252
    Quote Originally Posted by evincar View Post
    *natzt
    ilan na odo mo sir?
    innova 2012 E
    Don't sweat it its not a Honda. I replace every 40k sa honda due to their history of bad AT. Sa toyota i do it every 50k though sabi ng madami 80k daw.
    Apr 2011
    #11253
    Quote Originally Posted by 1natzt View Post
    thanks
    Thanks sir! Ano o brand and model ng spark plugs naten?
    #11254
    *natzt
    ilan na odo mo sir?
    innova 2012 E
    Your call bro. I suggest you do it earlier than 40kkm...
    Replaced ATF at 40kkm a few days ago... I was not really proud of the "color" of the fluid..
    27.8K _/_/_/_/_/:starwars:_/_/_/_/_/
    Jan 2012
    #11255
    *natzt
    ilan na odo mo sir?
    innova 2012 E
    Nasa 115k na sir. kung automatic, yung A/T fluid lagi binabantayan dyan. kung may makuha po kayo dextron 6 (gamit ng porsche), yan maganda.
    Sa differential/transmission oils, every 40 or 50k yung alam ko po na normal change.
    tia
    Jan 2012
    #11256
    Sir, Denso po, K20HRU11 stock plugs sakto sa unleaded gas. Na try ko na din yung iridium, tapos high octane 98, maganda acceleration pero mabilis consumption.
    tia
    Apr 2011
    #11257
    tia
    Salamat ng marami! [emoji106]🏼
    Oct 2014
    #11258
    Hello po sa inyo.
    Alam nyo po ba kung bakit may tagas na ganito sa may crankcase blowby?
    http://tsikot.com/forums/engine-fuel...ba-eto-101543/
    Thanks po in advance.
    Oct 2014
    #11259
    Hello po sa inyo.
    Sep 2006
    #11260
    [COLOR="#008080"]
    may strainer ba or filter yung auto tranny? naalala ko kasi yung sa Starex GRX ko may nilinis na strainer yung mekaniko nung nagpa change ATF ako eh.
Toyota Innova Owners & Discussions [continued 3]
