Hindi self adjusting ang drum.
Di mo rin kailangan buksan to adjust, sa likod ng drum brakes papunta differential ay may window dyan na may rubber cover. Kuha ka flat screw sundutin mo window to adjust.
Check the connection to crank sensor, if wiring is good and connection is clean then replace the crank sensor and reset the code, this is the first step, the computer could be a problem also but most times its the crankshaft sensor. good day ;-) COmputer reset can be done by disconnecting the battery for at least 5 minutes.... ;-)
may solution na ba for flickering optitron gauges natin?
it's been more than a year already and may flicker parin gauge ko.
Had the same experienced months ago... what I did is extend my idling time while parked to have my battery recharged before shutting off the engine. In this way, my battery will be able to recover and fully recharge specially during night travels. Also, I think that it has something to do with the life of my battery since its already 22 months...
ganito din na experience ko few month ago. 5 years old na ang battery. nagkakarroon na rin ng hard starting. pero after replacement ng new battery nawala na ang flickering.
from the looks of it mukhang battery related pag nag flicker na gauge natin. 5 years na battery mo sir? sulit na yan.. may i know what brand/model sir? mine kasi was stock pa since mag 2 yrs pa lang unit. Every once in a while sa morning kasi sinusukatan ko battery before starting, 12.54 volts naman, then after start panik sya ng 13.62, just to check kung gumagana alternator at nag charge yung battery.
may nabanggit si ETCG na acting funny ang dash instruments yung isang sasakyan na inayos nya dahil sa low battery voltage. although different car make iyon. forgot the video title. maaring ganun din siguro sa mga innova.
good day mga sir! mayroon ba inyo na nagpagawa ng alternator pulley, yung clutch pulley? may long term effect ba kung gawing solid pulley nlng ang alternator pulley?
Probably not a good idea. You could run into reliability issues. The video shows why decoupling the alternator pulley (non-solid) is important, especially on Diesel engines.
Alternator pulley comparsion.wmv - YouTube
