Page 564 of 775 FirstFirst ... 464514554560561562563564565566567568574614664 ... LastLast
Results 11,261 to 11,280 of 15487
    Aug 2013
    #11261
    Quote Originally Posted by NICASIO_Z View Post
    Hello po sa inyo.
    Alam nyo po ba kung bakit may tagas na ganito sa may crankcase blowby?
    http://tsikot.com/forums/engine-fuel...ba-eto-101543/
    Thanks po in advance.
    palitan mo ng screw-type na hose clamp, yung mga stainless.
    or lagay ka ng oil catch can/tank.
    #11262
    Tanong lang po.. ano usually dapat ginagawa sa 25KKM check-up? Mag 2 yrs na si Innova G Dsl A/T and any recommendations kung saan sa Las Pinas maganda pa change oil kasi plano namin hindi na sa CASA.. Salamat po ng marami..
    Nov 2014
    #11263
    SHELL STATION NEAR SOUTHVILLE TRY USING Semi-synthetic 10W-30W grade for diesel SHELL ENGINE OIL - BUY ORIGINAL OIL FILTER FROM CASA AND THE SERVICE MECHANIC will recommend to flush the engine with a least 3 liters of the mineral based oil for diesel to remove the remaining sludge.... Using Kerosene based flushing fluid not recommended........
    May 2012
    #11264
    Quote Originally Posted by jasonub View Post
    Don't sweat it its not a Honda. I replace every 40k sa honda due to their history of bad AT. Sa toyota i do it every 50k though sabi ng madami 80k daw.
    Your call bro. I suggest you do it earlier than 40kkm...
    Replaced ATF at 40kkm a few days ago... I was not really proud of the "color" of the fluid..
    thanks sir!
    Quote Originally Posted by 1natzt View Post
    Nasa 115k na sir. kung automatic, yung A/T fluid lagi binabantayan dyan. kung may makuha po kayo dextron 6 (gamit ng porsche), yan maganda.
    Sa differential/transmission oils, every 40 or 50k yung alam ko po na normal change.
    aoks salamat sa info sir. mahirap na masiraan need alagaan transmission nito AT kasi innova namin
    Jan 2009
    #11265
    Part 1:
    Nobody seems to be posting pictures about how they solved their rear A/C outside-air leak so I took it upon myself to at least, TRY getting to the bottom of things.
    After removing the bumper, some of the few things I noticed immediately was the number of holes there are on the body. Now, I don't know if these actually go through to the double-wall area where the rear A/C is, but aluminum tape is cheap so I taped them all up.
    Before:
    After:
    I also taped up the four (4) underside holes:
    Before:
    After:
    Jan 2009
    #11266
    Part 2:
    I also noticed that the lower flap on the RIGHT vent does not close properly, as evident with the rubber flap not lying flat and the dirt accumulation on the filter where dirty air is leaking in. I just pulled on the rubber tabs where the flaps are attached so it lies flat:
    Before:
    After:
    I'll test this out on my next drive and give feedback.
    Jan 2009
    #11267
    Duplicate.....
    #11268
    Quote Originally Posted by Migizmark View Post
    Tnx very much sir.. yung regular na cleaning and checking of the breaks sa CASA ipasama ko na rin ba? estimate lang sir.. magkano damage natin kung sakali? definitely much cheaper.. TIA..
    May 2012
    #11269
    *OJ88
    hindi ko na expecrience yan ganyan amoy ... o dahil medyo bago bago pa unit namin 2012 E
    Jan 2009
    #11270
    Quote Originally Posted by evincar View Post
    *OJ88
    I have a 2-month old Innova G.
    The flaw is present in all Innovas, apparently since it was first released like 10 years ago. You probably just don't notice it and/or you just happened to own a unit that has better vent seals.
    Jun 2009
    #11271
    Yan din reklamo ng mga anak ko. try parking your car near and imburnal...*OJ88...feedback mo ano result ha.
    Jun 2009
    #11272
    Yan din reklamo ng mga anak ko. try parking your car near an imburnal...*OJ88...feedback mo ano result ha.
    Sep 2008
    #11273
    Ako i pour it as it is.
    Wala naman dilution instructed.
    Sir,
    Ilan liters po capacity ng radiator ng Innova? If no dilution for the Toyota coolant, how many liters of coolant ang ilalagay?
    TIA
    Nov 2014
    #11274
    Quote Originally Posted by tioPAENG View Post
    LAST TIME JUST FOR THE CHANGE OIL BOUGHT ORIGINAL FILTER FROM CASA OIL SEMI SYNTHETHIC 10W-30W PhP 3K ++..... front brakes no need to open up only the rear brakes for adjustment of brakes clearance between the pad and brake drum, you can DIY this if you have done it before or ask a mechanic to do it and watch and learn on how to... cleaning the rear brakes assembly, once the brake drum is removed exposing the brake pad lining and the Cylinder/piston assembly,, just hose it down with water and using a paint brush to clean the nook and cranny's then blow dry using a blower no need for the expensive cleaner. if you want to using a 120 grit sandpaper you can rub the brake drum lining ...
    Nov 2014
    #11275
    Apr 2015
    #11276
    Quote Originally Posted by mumuy View Post
    Sir,
    TIA
    As per vehicle manual, MT = 9.0 L, AT = 10.3 L
    Jan 2009
    #11277
    Quote Originally Posted by desertfox615 View Post
    See my feedback >here<.
    Jun 2009
    #11278
    thanks. will have to try figuring out how to remove the rear bumper.
    Jun 2009
    #11279
    Feb 2014
    #11280
    Hello guys!
    Has anyone tried using 225/70/R15 tires on stock mags? Does it fit our wheel well? And hows the feel on the ride?
    Thanks in advance.
Toyota Innova Owners &amp; Discussions [continued 3]
