Page 462 of 775 FirstFirst ... 362412452458459460461462463464465466472512562 ... LastLast
Results 9,221 to 9,240 of 15487
    Jan 2014
    #9221
    Quote Originally Posted by nujsimon View Post
    Hello everyone.
    Which is a better battery for gasoline Innova G , 2SM or 1SNF? TIA
    Hi
    I will use 3SM motolite for my innova diesel and it last for 2yrs.
    I will recommend you the 3SM for easy starting on cold weathers and eraly morning
    if seldomly used get the 2SM
    Aug 2008
    #9222
    i had my alternator pulley replaced because it causes this loud noise and the battery does not charge, my question is do i need to have my ECU reset because i notice na parang ma malakas ang vibration ng car during idle. tnx
    Oct 2013
    #9223
    nung tinangal battery mo, nagreset na ecu mo. mag adjust rin ecu mo later on.
    #9224
    Quote Originally Posted by Terrence View Post
    Babalik din sa normal yan, i replaced my alternator. Upon leaving the dealer akala ko something is wrong with the car todo yung vibration pag idle to the point na akala mo mamamatay yung engine.
    May 2005
    #9225
    Just the pulley bearing? Usually if its casa they want the entire assembly replaced.
    Jun 2013
    #9226
    Guys nagbibigay ba yung toyota ng loaner/ service car habang nasa casa yung car niyo? Kasi 2 weeks daw sa kanila yung innova.. May inooffer ba sila na ganun?
    Posted via Tsikot Mobile App
    Apr 2012
    #9227
    Quote Originally Posted by rsa527 View Post
    Wala. Never pa sila nag offer ng ganun. Kahit abutin pa ng buwan ang repair or service.
    Aug 2014
    #9228
    Sir laging nakailaw yung fuel logo sa may dashboard..nagpalit na ako ng fuel filter but still ganun parin..ano kaya pwedeng gawin?
    Jan 2014
    #9229
    Bring it to the nearest dealer to have it check.
    under warranty pa ba??
    Baka naman di ka pa nagpapagas
    May 2012
    #9230
    Baka sa electrical yan,kase yung gauge natin puri wire na lang last time nga ginalaw ko yun yung turo ng needle nabago nausog sya,dato pag fulltank lagpas sa F ngaun di na Pero kahit mababa pa ung fuel warning light iilaw lang sya kung kelan ma reach ung certain level sa tangle,dati above ng konti sa pinaka last na guhit ngayun below na dun bago umilaw.
    May 2012
    #9231
    Last time I ask the dealer if how much it will cost me to replace my panel gauge sabi nasa 20k daw.
    Jan 2014
    #9232
    Quote Originally Posted by jyg1995 View Post
    A
    Sir anong year yung innova mo?Bka lemon yan
    Oct 2013
    #9233
    Diesel? Alin na fuel logo, dalawa yan, isa sa empty at isa sa change filter. Kung yung change filter, reset your ECU.
    May 2012
    #9234
    Vvti second hand,pinakielaman ko lang Kaya nag ka ganon,I found out that innovas panel gauge uses led or parang IC light unlike ng adventure namin na may mga bulb.
    Oct 2013
    #9235
    Mukhang yung optitron ang gauge mo. Yung sa amin hindi optitron kaya buldang gamit.
    Ano ginawa mo sa panel? I have been resetting innova odometer, pero di pa nangayri yan experience mo.
    Reset mo ecu or check your fuel float, baka yan issue.
    Ako yung experience ko sa akin kapag nasa below half na ang gauge, and naka idle ako ng mga 10 minutes, bumababa yung gauge, pero pag andar balik normal.
    #9236
    Quote Originally Posted by Skylar View Post
    may nag-sabi na ng solution niyan. somewhere dito. hindi ko lang matandaan ang detalye.. but it costs nothing to do.
    i-backread nyo na lang.
    or do what i did in ignorance: i replaced the entire fuel filter assembly. (hey! it ain't that expensive.. less than 3K)
    Jan 2014
    #9237
    Sino na dito nagpalit na ng timing belt?
    Kasi 10k nalang saakin palitin na
    Does anyone know where is the most reliable place to buy
    or sa casa nalang?
    #9238
    Quote Originally Posted by crosswind View Post
    or sa casa nalang?
    for essentials like timing belts, it would have to be a very reliable source. mine would be the casa. expensive, yes, but i wouldn't chance it..
    May 2012
    #9239
    Quote Originally Posted by vvti2.0 View Post
    Pardon me sir Pero wala po,I just want to see and know how this and that looks like and where and what thing you can see inside of the panel gauge,I remove the needle hand po kase,isang buong assembly po yan and it is divided into three or four panel tas yun Para ma access ko yung mga ilaw I remove those needle and when I put it back again Hindi ko na balik sa dati ang style dapat. Ung needle ituro mo na sa zero sa rpm and speed same as the fuel and temp..Pero Hindi ko na binalik sa dati ang hirap tanggalin ng mga kamay nya matigas -_- ....I dunno if optitron po to pero may adjustment to sagilid ng steering malapit sa tuhod mo.
    Oct 2013
    #9240
    The easiest way to remove needles sa gauge ay gamitan mo ng tinidor as lever. Alam ko itsura ng instrument cluster nyan as I have been resetting odometers as a hobby. Just make sure lagyan mo ng cloth sa papatungan ng tinidor mo sa cluster para hindi magkamarka.
    Servo type motor ng needle nyan, di kagaya nung old school na parang basta may coil lang.
    Check your RPM, Speedometer and temp if calibrated pa sa sasakyan mo, wala needle stopper ang innova, so sa pagbalik ng needles, make sure counter clockwise ang paglagay mo kasi yung stopper nyan mismo ay sa motor.
Toyota Innova Owners & Discussions [continued 3]
