Page 459 of 775 FirstFirst ... 359409449455456457458459460461462463469509559 ... LastLast
Results 9,161 to 9,180 of 15487
    Mar 2012
    #9161
    sakin, hindi sa bubong. sa right rear fender. malamang, may kaunting leak ang insulation doon...
    sa right side sa ilalim ng glass sa bandang ilalim meron din. lalo na pag yung lumamig ng husto yung ac. ang concern ko lang is, hindi kaya makasama sa metal body yun at kalawangin. same effect ng dating starex ng unang lumabas. madaling mabulok yung fender dahil sa moist na galing sa ac.
    Jan 2014
    #9162
    Quote Originally Posted by jyg1995 View Post
    Meron din sa rear right gitna ng gulong saka salamin,kaso bakit pag tanghali Hindi efficient yung lamig Para sa cabin lalo na pag umpisa Parang tas nabilad,saka uneven ung hangin at lamig., sa gitna sa left mahina ung lamig kesa right sa last row naman mas malakas yung blower sa right kesa left?
    Actually sir maliit lang ang opening sa driver side compared sa right side
    yung opinion ko dahil driver lang naman dyan
    Jan 2014
    #9163
    dr.d ganyan di sa innova ko same sa crosswind din
    siguro lahat ng dual aircon ganyan
    Jan 2009
    #9164
    tanong ko lang po, bigla na lang kasing ayaw mag start ng innova g AT namin, almost 3years na din and using stock battery. tinesting ko yung busina at mga ilaw parang ok naman. wla kasi ako voltmeter to check eh. nung una nagcrank pa, pero ngayon hindi na nag crank. nagamit ko pa naman kahapon. meron ba indicator kung battery problem?
    Aug 2014
    #9165
    It needs new battery since 3 years of battery life and your unit is AT. Specially if its diesel.
    One of the signs of failing battery in innova G, when there's no enough juice is that climate control is always resetting when turning the key off and turning it to on, the orange light in the climate control will lit up.
    #9166
    Quote Originally Posted by frequenzy View Post
    it's definitely the battery. my 3.5 year old battery just recently died on me. it couldn't hold a charge anymore. after replacing battery, starting issues were solved.
    #9167
    Quote Originally Posted by n5110 View Post
    parang may nagalaw sa wiring ng innova nyo. G-gas itong sa akin normally pag switch ON ng ignition, iilaw ang mga indicator including ABS then mawawala din after 2-3 secs. pag patay at hugot naman ang susi dapat walang naka ilaw. bago ba pa install ng turbo timer ganun na?
    same as mine, Volution TT on different car. 2-3 sec abs lamp then off
    Jan 2009
    #9168
    battery problem nga, nag palit ako kanina motolite 2sm nasa 5.4k kuha malapit sa min. tnx sa replies.
    Jan 2014
    #9169
    sir di ba hirap ang 2sm sa pagstart,ang gamit ko sa innova 3sm saka every 2yrs palit ko
    Aug 2014
    #9170
    2sm ok na every 2 years ka naman magpalit.
    Or kung oc ka sa battery try mo yung dual battery system like in prado, it can be done by installing an aftermarket for the dual system.
    google mo na lang mga hilux para same flatform
    Jan 2014
    #9171
    Quote Originally Posted by vix View Post
    3sm gamit ko dahil para di mahirapan istart yung tsikot saka daily drive sya
    compare mo sa crosswind ko 2sm pang 4yrs. pero seldom use and recommended sa crosswind 3sm din
    May 2009
    #9172
    Mga sir,
    Anybody had their innova serviced for "tightening of bolts"? totoo ba (meaning personally nakita) na may bolts sila na hinihigpitan other than sa wheel nuts?
    Or lagi lang siya naka-charge dun sa bill na ginawa pero hindi naman nakita na meron nga ginawa?
    Please enlighten. Thanks.
    May 2005
    #9173
    Quote Originally Posted by matt chua View Post
    Mga sir,
    Same here. I don't see them tighten any bolts underneath the vehicle.
    May 2009
    #9174
    Thanks sir for sharing your experience.
    In any case, do you know which bolts are needed to be tightened? Can this be done out side the casa?
    Thanks again.
    Aug 2013
    #9175
    Throttle body. this is where the clean air is coming in preparation for combustion. i guess lahat ng gas fed engine have the same term naman. sa experience ko sa kotse ko dati once na sobrang dumi ng throttle body hinde na maganda ang idling ng sasakyan, kailangan baklasin at gamitan ng caburetor cleaner. dito sa innova at 32K wala pa naman akong na raramdaman na signs na kailangan ng i service. maybe you can check the manual kung may cleaning ng throttle body at XXXKM reading.
    +1 dito. added tip for TB cleaning, much better kung WD40 ang gagamitin, kasi kapag carb cleaner, medyo magiging maganit yung pag galaw nung butterfly valve kasi walang lubrication, plus combustible pa ang WD40.
    kadalasan sabay ang cleaning ng TB at MAF sensor.
    para iwas din sa pamumuo ng gunk sa TB, mag install ng oil catch can.
    kadalasan din naman ng gunk build up sa TB ay yung over fill ng oil during oil changes at madalas na pag high rev o birit. kaya kung may oil catch can ka, instead na mag build up sa TB yung oil, sasaluhin ni OCC.
    Aug 2014
    #9176
    Mas maganda yun egr blanking kung gunk build ang iniiwasan, dalawa maiiwasan sa egr blanking 1. soot build sa manifold at iwas damage engine dahil sa soot 2. gunk build up sa egr valve.
    Jun 2014
    #9177
    Mga Sir,
    Bago lang poh dito. Mga sir question lang poh.
    1). Pag nagpakabit poh ba ako ng accessories sa innova. Kailangan ko poh ba inform ang bank na pinag loan ko about sa mga papakabit ko?
    2.) Noong nilabas namin sa Casa yung car, lakas humatak. Tapos nag pa 1k pms poh kami, napansin ko na medyo humina hatak nya. Connected poh ba yung oil na pinalagay ko? Kasi pinapili ako kung Full synthetic o ordinary lang. Pinalagay ko eh ordinary lang.
    Sana poh matulungan nyo poh ako.. maraming salamat poh.
    Jan 2013
    #9178
    Mga sir,
    Ako sir nakita ko na hinihigpitan nila yung mga bolts tuwing nagpapa pms ako.. Toyota North Edsa casa ko..
    Jan 2014
    #9179
    Quote Originally Posted by Spark Plug View Post
    Mga Sir,
    sir saan kaba magpapakabit? sa labas o sa casa?
    kung sa casa kasama nayan sa monthly mo
    Jan 2014
    #9180
    sorry double post
Toyota Innova Owners & Discussions [continued 3]
