Page 1 of 294 123451151101 ... LastLast
Results 1 to 20 of 15487
    Quote Originally Posted by Terrence View Post
    If there's anyone of you guys who have added power steering fluid in your innova i just want to know the brand to buy, kasi yung innova ko nasa minimum hot level na yung fluid.
    kung nagbabawas, may leak. better have it fix. kung wala pa budget para ipagawa, you can add any ATF na Dexron II or III. hth.
    MODERATOR'S NOTE:
    The previous (old) discussion thread can be found at:
    http://tsikot.yehey.com/forums/showt...76202&page=125
    Quote Originally Posted by revo View Post
    Yung friend ko po nagpalit ng alternator sa innova 05 d4d manual nya it cost him 12-13k sa toyota pasong tamo. Bearing po talaga nagiging problem pero la pa special tool na pambukas
    thanks for sharing sir revo, pero parang mura masyado pag 12-13k lang.. around 17+k sa Casa wala pang installation sir.
    san po kayo sa mindanao miss kristine?
    May 2009
    Quote Originally Posted by kristine123 View Post
    Sir, Kakapalit ko lang around 18K.. kung sa Casa hingi ka ng discount.
    Oct 2009
    nasa Mindanao po kami sir
    san po sa mindanao? meron po kasi dyan banda sa cotabato... yun sa mga padlan.
    -Kurtsm
    Alam ko ung padlan,dito yan sa amin sa cotabato..
    But i dont think so,meron sila nun..??
    Quote Originally Posted by morlack View Post
    pagadian kami sir...
    Oct 2009
    -Kurtsm
    ok. baka sakali lang. lam ko kasi umoorder sila sa manila. i've been there kasi sa kanila. anyway, malayo din kung sakali si mam kristine, pagadian pala sya. na miss ko tuloy yun tricycle sa pagadian na nakatingala.
    Dec 2009
    Quote Originally Posted by Louie_18 View Post
    Guys ano ba kailanagan ko ipacheck kasi yung Innova namin parang may unusual sound pag nagbebreak lalo na pag-kakaandar
    plang. Yung parang dumidikit yung preno. Thanks.
    Brod, palinis mo lang yung mga breaks mo malamang mga residue ng brake lining dumidikit sa brake drum.
    ok layo mo pala..
    Tama ka tol nakakamiss din ung tricyle kala mo matutumbana na.. hehe
    share lang mga paps. it is our 2nd tym going to baguio. 1st dala namin ung revo and ngayon ung innova namin. napapansin ko lang ibang iba tlga hatak ng revo sa innova pagdating sa mga steep road. parang under power ung innova compare sa revo... isa pa experience ko sa slex cruising at 150kph bakit parang may amoy na nasusunog sa a/c.tumigil kami sa gas station to check pero wala naman.. everything seems fine. tapos sa nlex sinubukan ko ulit after reaching 160kph ganun na naman ulit pero kpag chineck naman namin ung engine ok naman... may naka experience na ba nito?By the way FC namin satisfied naman ako 800kms=more or less 65liters of diesel
    Jan 2011
    Hope this helps. Pasig allows outside oil basa orig. Pasig even alllows imported OEM toyota oil filter 90915-yzzd1 from US but driver forgot to bring it. Makati doesn't allow outside part.
    Had my 20K pms in Toyota pasig today 2010 innova a/t gas
    told them NO additve/fuel treatment and engine flush.
    Brought our own 6 quartz of Mobil 1 10w30 oil and ikh20 iridium plugs from US
    20K labor 1148
    oil filter 426
    drain plug gasket 28
    misc 113
    sand paper 25
    Total is P1740
    Mar 2011
    Quote Originally Posted by lowrider17 View Post
    Ok lang sir yan, ganyan din malimit maexperience ko kapag more than 100 kph na takbo. Nagaactivate lang ang mga seatbelt tensioner nyan at ung abs. Kaya yung naaamoy mo, fumes or gas pero di naman delikado na maamoy yan, inixplain yan sir sa manual.
    Quote Originally Posted by brench View Post
    ah yun ba yun sir, nabasa ko sa manual akala ko naman mag activate lang yun in an accident kasabay pag deploy ng airbag.nagulat lang family ko kasi early morning kami umalis at bakit daw ganun amoy. anyway thanks sir Brench
    do you know how to safely remove the rear view mirror of an innova? is there a clip there somewhere?
    Jan 2011
    Yesterday my 2010 innova diesel had its 15,000 km maintenance check-up. When I picked it up the SA just handed me the billing statement and did not mention any problems or findings. Just the usual oil change, tune up and inspection he said. Since I was in a hurry I did not go over the details of the billing.
    When I finally had the chance to read the details of the billing at home I noticed there was an entry in the bottom which reads " Recommendations: FRT RH Shock Absorber leak".
    Anything to worry about this finding? Tried calling the SA but he is unavailable.
    Covered ba ng warranty ang shock absorbers?
    Has anybody encountered this same problem with their unit?
    Feb 2011
    mga paps, share ko lang na experience ko sa unit ko last sunday. i own a 2011 innova G D4D. nagsimba kasi kami, so i parked. tagal lang naka idle engine ko ng hindi pa ako nakaka park kasi ang tagal lumabas ng mga sasakyan nung unang mass kasi palm sumday diba, masikip. kaya medyo matagal akong nag antay. nung naka park na ako in-off ko na engine tapos bumaba na ko sa sasakyan. nung i llock ko na, i pressed the lock button in the remote of the key, hindi nag lock. pinindot ko din yung unlock button, di din nag function kasi hindi umilaw. nung pinindot ko ulit yung lock, i pressed the lock button 2 seconds then it locked same thing with the unlock button. di sya ng lock ng isang pindutan lang, i hhold pa yung button. tapos i started ulit the engine, nilipat ko parada ko. tapos nung i llock ko na doors ulit, pinindot ko lock sa remote ng key, ok na ulit. isang pindutan lang nag lock at unlock na sya, i tried lock and unlock 3x, ok naman na siya ulit.
    may naka experience na ba sa inyo ng ganun mga paps? anu kaya naging problema sa key at hindi nag function agad to lock and unlock? imposible namang battery kasi 5 months pa lang unit ko eh.
    thanks for the feed back.
    Quote Originally Posted by apc10 View Post
    common issue na ng Innova yang leaking shock absorbers. should be covered ng warranty.
    Jun 2015
    Mga Sir newbie lng po.. Just want to know po, im planning to sell my honda city 2010 mdl a/t due to need bigger car. my coming soon na baby po kse.. question ko lng po, tipid po ba sa diesel ang 2011 e automatic. ( png 2nd hand lng po ang kaya )
    Thanks in advance sa mga sasagot po.
    Feb 2011
    I dont think so sir, activate lang pretensioners pag me collision and dun lang mag emit ng burning smell. ABS naman pulsing action on your pedal on hard braking kung umamoy man brake pads sa pag stop mo yun. dun sa nag post ng question ano ba amoy? kung parang burnt rubber your belts might be too tight kaya me ganun amoy. saka naka recirculate ba vents mo o open? kung parang parang kuryente might be brake pads maaring needs cleaning or adjusting.
Toyota Innova Owners & Discussions [continued 3]
