Page 144 of 775 FirstFirst ... 4494134140141142143144145146147148154194244 ... LastLast
Results 2,861 to 2,880 of 15487
    Sep 2011
    #2861
    Mga ka-innova ask ko lang yung may mga rear window wiper kung yung washer is spray type gaya nung 2 sa front or bagsak flow ng washer fluid lng sya...thanks
    Feb 2011
    #2862
    Quote Originally Posted by 2yotaEnnova View Post
    bagsak lang flow sir. kaya di ko ginagamit yung washer nun eh, pag talagang basa lang chaka ako gumagamit ng rear wiper.
    Oct 2011
    #2863
    Quote Originally Posted by Mile2 View Post
    On D4d you can actually change fuel filter element as frequent as you would prefer since the element is just under 500 Pesos. I know few owners do every 5Kms PMS with D4d fuel filter element replacement. For VVTi the cost of Fuel filter assembly will cost more than 3000 pesos.
    wow, ang mahal sa vvti. ibang klase ung fuel filter assembly ng vvti as compared to d4-d?
    Oct 2011
    #2864
    Is it okay to top-off both the brake fluid and power steering fluid with a different brand but same specs (Dot 3 & ATF Dexron III) to the brake fluid and power steering reservoir respectively? Ung sa coolant kasi I remember that preferably ung pink coolant ng toyota or caltex ang dapat gamitin.
    Aug 2005
    #2865
    EFI, intank fuel pump and filter
    #2866
    Its ok to top up as long as theyre the same ratings/specs...just like the coolant..no worries ;)
    Mar 2011
    #2867
    Hi to all ka-Innova. Tanong ko lang, ano ang common causes ng dent sa likod ng innova, un bang part na kung saan nakalagay ang ating plate no. May mga nakita kasi akong may dent. Ano bang causes nito para maiwasan ko na, mahal din kasing magpaalis ng dent. TY
    Oct 2011
    #2868
    Quote Originally Posted by BoyBawang View Post
    okay, thanks sir! I was canvassing for the price of coolant, brake fluid and power steering fluid, surprisingly, mas mura pa sa casa compared sa mga binebenta sa store un nga lang, ung packaging nila mga 1Li or 2Li wala sila ung maliliit na packaging.
    Oct 2011
    #2869
    I was with my family earlier this morning for the mass and I park inside the church compound. When we were about to leave, the above pix happened (left corner rear bumper). Probably the car park behind me is the culprit but didn't noticed any car park behind me at that time.
    Questions:
    Option 1: Can I use a rubbing/polishing compound to remove the flare or scratches? or if not totally remove, just to minimize the damage.
    Option 2: If option 1 won't work, what is the typical cost for the repair and restoration of the above damage so that I have ballpark figure of the price when I negotiate with an authorized car body repair shop.
    Need your expert adivsed. Thank you so much!
    Jan 2012
    #2870
    pano po buksan yun sa ilalim ng manibela sir?
    #2871
    kung black/brown part near the keys, turn the steering wheel 90deg. meron 2 screw dyan na kailangan tanggalin.
    #2872
    Questions:
    mukhang paint transfer lang. kung hindi natuklap or scratched yung paint. madali lang tanggalin yan.
    How To Remove "Paint Transfer" - Auto Geek Online Auto Detailing Forum
    Oct 2011
    #2873
    Quote Originally Posted by Ginnova View Post
    Thank you sir Ginnova. Ano ba ang equivalent product ng "Pinnacle Paintwork Cleansing Lotion non-abrasive" that is equally effective that I could used to remove the paint transfer? ung available sa ace hardware or blade.
    #2874
    here are some paint cleaners that are available locally( blade ). pinakamura dyan would be the Moms scratch remover (mga around P350). don't buy the 3m scratch remover in sachet. its too aggressive.
    Meguiars SCRATCH X 2.0
    Meguiars SwirlX Swirl Remover
    Mothers California Gold Pre-Wax Cleaner
    Mothers California Gold Scratch Remover
    #2875
    Or you could take it to sir Ginnova and he can easily repair that defect. The cost may even be less than if you buy any of those products, ask him to be sure.
    May 2005
    #2876
    *retz
    I had something like that, but yours in worse condition. I just took it to Big Bert's Araneta. One of the partners of the shop personally took care of it. First he wet sanded it with a light sand paper. Applied some wax and etc. They charge me Php 400 but it was definitely worth it as it came out good as new.
    PS: As long as its paint transfer (from the hit and run guy's car to your innova), it can be remedied.
    Oct 2011
    #2877
    Maybe I'll try either the Mothers Pre-Wax Cleaner Step-1 or the Meguiars Deep Crystal Paint Cleaner. I think this are least abrasive compared sa mga scratch removers (correct me if im wrong). Hopefully It could do the job and remove the paint transfer to the rear bumper. Thanks again sir Ginnova.
    Oct 2011
    #2878
    *retz
    Yes, that would be my second option on taking it to a car body repair shop. Kung Php400 lang, it is very much worth it. Pwede ko na lang pagawa sa kanila kesa bibili pa ako ng paint cleaner na ganon din ang cost.
    Jul 2011
    #2879
    tama ba ito para sa deep scratches? wet sanding tapos by hand na ang polishing kaya ba talaga?
    Oct 2011
    #2880
    Update:
    I went to a reputable car body repair shop and they just rub it using a compound and wolah! the paint transfer has disappeared though they are still hairline scratches but it is not noticeable. Overall I would say it is 90% restored to its original form. Mabilis lang nga tangalin.
Toyota Innova Owners & Discussions [continued 3]
