meron ba sa inyo nakapag-install na ng cruise control sa innova? i'm planning na lagyan. hindi ko lang alam kung pwede.![]()
yep. ganito din yung nakasulat sa manual if i recall correctly. pressing on the hood will only cause unsightly dents. i know nabiktima na ko nito. gasoline boy na nagmarunong. di maisara yung hood pinilit i-press pababa kaya nagkaroon ng dimple. buti na lang nakuha sa PDR.
I press the hood sa scuff plate mismo mas matigas kasi sa part na yon. I find it easy to lock the hood by just pressing it rather than dropping it to lock.
good day mga Sir..
newbies lang po... tanong ko lang po sana ung bolt pattern ng gulong ng innova . same lang sya sa lahat ng model ng innova since birth (2005) dba po? bibili sana ko ng mags from Riyadh.. mura kasi d2.. help naman po kung anu ung bolt pattern pls..
thank you.
thanks po sa replies. medyo nagaalala lang ako baka wala sa alignment yung latch kasi ang taas na ng starting point bago ko irelease yung hood bago sya mag lock. definitely higher compared sa ibang sasakyan ko, at mas malakas yung banging sound nya pag drop.
Innova or All Toyota w/ PCD 5x114.3 Bolt Pattern > tama po ba ito? anu po ba yung Off set? may 45 offset ito
[QUOTE=liv;1910107]opo... kakukuha lang last wednesday.
weeeeee....patest-drive kami mam.....
In theToyota website the V variant has a seating capacity of 8, the same as the other variants. How can this be if the 2nd row has 2 captain's chairs?
Good Day mga ka Innova, just got my unit last Friday and I noticed earlier that there was water dripping from probably where the A/C goes under the car. I'm not well-versed with auto parts and the works and so I'm not completely sure if this is normal or not.
Your inputs would be greatly appreciated.
Other than that I am loving my Innova![]()
hi guys, meron ako 2007 innova v. a/t parang malakas diesel consupmtion ko mga 7km/l lang compared sa dati ko 2005 na J m/t nakakaabot sa 10km/l. me problem kaya?
