Results 14,631 to 14,640 of 15485
February 6th, 2021 11:25 AM #14631
ang weird nito, natisod ko lang ..
best fake daw LOL
6 Best Fake Bendix Brake Pads Reviewed and Rated in 2 21
- Nov 2019
- 1,431
February 6th, 2021 07:41 PM #14632Baka fake nga na bendix nabili ko last time.
After 6-8 months, ang ingay habang naka brake.
Kaya hindi na ako bumili ng bendix dahil dun.
Pero madaling kumapit brake, kaya lang ang ingay.
February 9th, 2021 11:12 AM #14633
Thats the problem with famous brand they will copy it.... so lets see I might try the LKC (saw it in shopee) or probably advics for my next brake pad change.
February 11th, 2021 03:05 PM #14634
February 11th, 2021 09:08 PM #14635
That is what I heard too about bendix that it is harsh for rotor.
- Jan 2007
- 2,619
February 11th, 2021 10:11 PM #14636
Article from Bridgestone: Ceramic vs. Metallic Brake Pads | Bridgestone Tires
Emphasis mine:
Metallic Brake Pads
The final type of brake pad is the semi-metallic brake pad, often referred to as just “metallic brake pad”. Metallic brake pads are comprised of anywhere between 30% and 70% metals including copper, iron, steel, or other composite alloys. These various metals are combined with graphite lubricant as well as other fillers to complete the brake bad. The metallic brake pad compounds that are available vary, with each offering their own advantages for different situations as diverse as daily commutes to track racing.
For many drivers, especially those who value high-performance, the choice between ceramic vs. metallic brake pads is easy. Performance-driven drivers prefer the metallic brake pads because they offer improved braking performance in a much wider range of temperatures and conditions. Because metals are such a good conductor of heat, they tend to be able to withstand more heat while simultaneously helping braking systems cool back down more quickly. They also don’t compress as much as organic brakes, meaning less pressure needs to be applied to the brake pedal to affect stopping ability.
However, there are some disadvantages to metallic brake pads. They tend to be noisier than ceramic or organic brake pads - meaning a louder ride - as well as more stressful for the brake system, adding more strain and wear on the brake rotors. As far as price goes, metallic brake pads tend to fall somewhere between organic and ceramic pads. They tend to produce more brake dust than the other two varieties as well.
February 17th, 2021 09:50 AM #14637
The coolant of toyota super life long coolant premix 50/50. Is this good for 40k only or 100k odo?
February 17th, 2021 09:55 AM #14638
February 17th, 2021 09:59 AM #14639
Okay i will check it with the seller..... that is the only brand I know lkc, bendix and a shop selling advics not unless I go with toyota genuine brake pads.
- Dec 2019
- 2,073
February 17th, 2021 03:46 PM #14640Toyota PH to launch refreshed 2021 Innova on Feb. 20
facelift 2nd gen innova soon to be launched.
200hp 1GD engine from fortuner/hilux?
solution ng bansang CHINA WUHAN VIRUS - dumping of EVs in other markets
China cars
