waterless is actually not waterless but less-water. engine cleaning requires some chemicals that are diluted by water like apc's and degreasers. ex. meg's apc requires a minimum dilution of 1:4 ( 1 part apc , 4 parts water ).
ano sabi ng toyota about the problem, covered ba ng warranty?
Tinanong ko ang TYT kung baket nangyari na huminto ang engine, di daw nila masabi sanhi ng pagkasira, hindi daw naman nila pwedeng buksan yung nasirang STARTER dahil papalitan ng bago ng planta (cost of bnew P16k). Last friday nag pa PMS ako sa TYT ODO 40k, monday after ko pa detail sa BB, mga 10mins na tumatakbo sa kalsada duon tumigil sa daan yung auto. Wala naman akong binayaran dahil mag 2 yrs pa lang yung unit.
good day, I'm planning to change may wheels to 17", my concern is would it do any harm to the mechanism of the Innova under chassis since the stock is only 15"? thanks
Na experience ko rin sa company car na gamit ko dito sa middle east, Toyota Yaris Sedan (Vios sa Pinas) brand new binigay sakin last December lang bago pa maka 1000 km, 6 times ko na experience di bumibitaw yung starter, pero naririnig ko naman ung tunog kaya sabay patay ulit ng makina.
Go to casa that let's you bring your own oil. Casa found out I had a leaky front shock, replaced under warranty. If not for them, I would never find out I had a leaky shock. Highly recommended is Toy Pasig. For 10, 20, 30K pms, Just politely decline engine flush, fuel additive, car wash and bring your own oil and spark plugs. Your 10, 20, 30K pms would be less than P1,800 for oil filter, drain plug washer and labor. You can even try to ask for 10% discount
Just got the plates. TQB ***. exactly 1 month. kaso wala pa stickers.
Hi, i'm new here & just got our innova last 2 weeks. I'm just curious about the tire pressure, our SA said that I put 29psi for the front & 30psi for the rear tires but the manual says that tire pressure should be 33psi for both front & rear(unloaded). What could you recommend based on your experience?
Sa mga nakaka-experience ng fumes getting in to your rear aircon, check you rear shutter flaps passenger side doon dumadaan ang usok galing labas.
Had my aircon cleaned and rear evaporator replaced today, found out also today that the rear aircon is not recirculate it gets outside air from the shutter flaps. The rear aircon assembly has a tube connected directly on the passenger side shutter flaps.
Problem with the shutter flaps is that it has no user control on opening or shutting it close, control is only by cabin pressure.
the rubber flaps are located at sides of the rear bumper. the flaps are one-way and if air is sucked from that portion, the flaps actually will close. the fan does not suck air from the outside but from inside the cabin. i intentionally covered the opening of the rear fan before and no air comes out of the rear air-con vents.
