We have a 2011 Innova E and if there is really heavy smoke (black smoke belch) outside from other vehicles in traffic, the odor becomes very noticeable inside the cabin. If I'm not mistaken, this is more apparent when the passenger aircon at the back is on. Anybody experience this? Note: aircon is in recirculate mode.
This does not happen to our Fortuner (the one with the aircon switch at the third row passenger).
repost ko lang po.
tanong ko lang po kung anu maximum load in kilograms na kaya ikarga ng innova?
According to this site New Toyota Innova 2004 2011 2.5 G4 Diesel 8 seater Dimension | CarDekho.com - India
Innova Gross weight = 2300KG
How to compute payload: Gross weight - Curb weight = payload
Ho to get curb weight: check toyota.com.ph for your variant/model under the full specification.
Sample: 2300 - 1665 (Innova Diesel) = 635 KG payload
IF YOU LOOK at your LTO OR/CR you'll see that the GROSS WEIGHT stated there is 2900KG.
Disclaimer: Above computations are based on normal and ideal car condition. You are the best judge to know exactly what your car can take as payload considering the car condition specially the tires.
Hope this helps.
there is a "flap" that directs the outside air or just recirculate sa aircon vent. its edges are fitted with some kind of foam. overtime this gets brittle and will not be able to seal the outside air properly. dyan pumapasok yung usok. i had permanently closed mine para walang pumasok na usok.
Tail light bulb is the culprit. Nagsalubong ang dalawang filament that's why everything lightens up when i step-on the brake pedal. Problem solve. Thanks!
nandiyan na yung 2012 innova! :D
nakakita ako ng truck kanina, dala dala yung mga new facelifted innova!
share lang.
mga bro ask ko pala. saan nakakabili ng D-4D emblem bukod sa casa?
balak ko bumili ng isa kasi. ilalagay ko lang sa likod. dun sa baba ng emblem ng "toyota innova".
thanks! :D
Shorted ang dalawang filaments, ha?...
Well, that should explain it. Kaso, bihirang mangyari ang ganyan....
And so, the dashboard lamp for park lights(in the tachometer area) is not only to tell the driver that the switch is turned on, but also to feedback that the park lights are on... Well, low current lang naman, kaya walang isolation (relay)....
14.9K:kodak:
mga bos.dito ko na lang itanong sa thread na to ha...mabilis kasi dito e..hehehe...sa renewal ba ng comprehensive insurance natin, ,ay occasion ba talaga na mas mataas ang insured amount ng sasakyan kesa sa price ng sasakyan nung binili mo sya?alam ko kasi bababa kasi may depreciation..pero sabi sa kin sa BDO di sila nagbababa,nireretain nila yung SRP ng unit..in my case nman, gas variant yung sa kin pero ang insured amount na-quote sa kin ay for diesel variant so mas tumass pa yung value ng sasakyan ko vs pagkakabili ko...i called up BDO to verify kasi baka nagkamali sila pero sabi sa kin e yun daw kasi ang amount for my variant na nasa system nila..thanks po in advance..
Ni check ko muna kung pundido ba ung light bulb but apparently hindi. When I opened and look into the light bulb, medyo nangitim na ung transparent glass ng bulb and when I look closely, doon ko napansin na may parte doon na nagsalubong ung 2 filaments. I replaced it with a new double contact light bulb and nawala na ang problema.![]()
Bro.,- I suggest that you insure only to your vehicle's current market price...
Why? Kapag na-carnap ang sasakyan mo at hindi na na-recover,- normally, papalitan lang nila iyan ng equivalent na make/model,- nothing more... Hindi ka naman bibigyan nila ng brand new (not sure about your case now,- but ask them)..... So, what is the use of insuring it to the original SRP (or more in your case)?
14.9K:kodak:
