After almost 2 mos. of waiting finally got the diesel g a/t last monday. Black nga lang kasi talaga daw ubos na yung bronze mica. Went to clark yesterday morning for the balloon festival pero after just two hours of driving pagbaba ko sa kotse parang pinulikat yung right leg ko. Compared to the 2005 innova g a/t in the office parang mataas yung accelerator ng 2011 version.
Tech talk naman. hehe. ok lang ba lagyan ng turbo timer ang innova natin? I admit talaga everytime na dumadaan ako Slex or Free road hataw ako plagi. anu ba pros and cons kung maglagay ako ng turbo timer. ang alam ko lang kasi it helps to cooldown your turbo after long drive kahit swtich off na agad engine to avoid oil drying up to our turbo. Long drive kasi palagi then after the destination hindi ko na maiwasan i idle yung engine. Anu ba yung mga number display sa turbo timer(sorry for being noob) Pros and cons sa ride natin kung pwede ito?
^yun turbo timer po delay lang para sa pag shutdown ng engine mo po...yun number po sa turbo timer yun yung timer niya para i shutdown engine..pag 1 mo nilagay after 1 minute automatic mag off yun engine mo po
Bro.,- I think it will be helpful in your case to get a turbo timer because of your driving style(hataw). Yup, it will make sure that the turbo (oil) is properly cooled down before it shuts off your engine.... 3 minutes should be good enough idling before shut off.
14.8K:cow:
Hi,
my battery is due for replacement. someone recommended a N50ZL GS Battery for 3,800.00 15-months warranty. Any feedbacks? I believe this is the 2SM equivalent.
Should i just stick to 1SM batteries or go ahead with 2SM?
car is 2009 VVTi
tanong ko lang po kung anu maximum load in kilograms na kaya ikarga ng innova?
I was driving earlier this morning and notices that the tail lamp indicator flashes in the dashboard whenever I step on the brake. The brake pedal now acts like a switch to activate it whenever I step on it. I also hear a 'tik' sound whenver I step on the brake probably signalling the tail lamp switch. Might be a case of a short in the circuit? what should I do?![]()
Aha! It looks like it is the park light.
It is the green light on the left side of your panel,- (and yes it is also the tail light indicator).
Mukha ngang may short circuit iyan,- because when you step on the brake pedal,- it turns on the double contact(of the tail/brake light bulb)... Pareho ba ng light intensity ang tail/brake lamps when you step on the brake pedal?
Maybe it is the tail light bulb that is dislodged from its socket, causing the brake signal line to short with the park light line (contact).
14.9K:kodak:
