Page 132 of 775 FirstFirst ... 3282122128129130131132133134135136142182232 ... LastLast
Results 2,621 to 2,640 of 15487
    Aug 2006
    #2621
    Quote Originally Posted by leumas08 View Post
    Hi!
    Can anyone recommend a trustworthy auto repair shop kc nag ka knocking issue yung 2007 innova namin and the auto shop thats fixing our car is dragging the repair. nung una 1 week tapos 10 days now hindi daw nila alam kailan matatapos tawag na lang daw sila. papatow ko na sana pero wala akng alam na ibang shop sa manila area or makati. Can someone help?
    Thanks
    Gas or Diesel? Para maka response other members.
    #2622
    Quote Originally Posted by Ginnova View Post
    Yung projectors ko was sourced out in China. my is lighting set-up is Quad Bi-xenon projectors. headlight at fogs. I have installed on several Innova's as well. pm for pricing.
    Hi Sir Ginnova! With regard the projectors, do you specialize instalations on innova units only or pwede rin ibang makes and models? TIA!
    #2623
    Quote Originally Posted by Mile2 View Post
    Gas po.
    Aug 2011
    #2624
    ^baka cause ng knocking ay gasoline or station na pinapakargahan. Try nyo lang pong magpalit ng gas station or ng brand na kinakarga pag naayos na po yung sasakyan nyo. May experience kasi ako dati although sa ibang sasakyan na pag shell unleaded ang nilalagay ko, ang lakas ng tope or ng knocking sound. Pero pag caltex silver o kaya petron xtra unleaded e walang tope.
    #2625
    Quote Originally Posted by spat View Post
    hi! hindi po gasoline issue alam na nila yung sira may na rocker something na nasira dahil kulang sa engine oil. nag over heat kc. everytime kc na kinakausap ko sila patagal ng patagal yung date na matatapos last time na tinawagan sila hindi daw nila alam kailan matatapos no explanation basta tatawag na lng sila pag tapos na. kaya naghahanap ako ng ibang shop.
    thanks
    Aug 2006
    #2626
    thanks
    Ibig ba nilang sabihin ay natanggal sa position ang isa or dalawang rocker arm? Shimless ang VVTI ng Innova kaya misan nadi-dislodge talaga yung rocker arm. I have experienced this when I used very thin synthetic oil, ginawa lang sa Shell station ng less than an hour, re positioned rocker arms and tightened back the bolts on overhead cam shaft and off I go. From then on, palagi ko ng sinisilip yung rocker arms every 6 months by removing the valve cover.
    If this is the case with your car, my worries was your mechanic, was now having problem with timing. Or worst your overhead cam shaft is really faulty.
    Did they do OBD-II scanning before?
    #2627
    they did not do a obd-II scanning..
    mechanic said that if there was no damage to the piston the only thing they would need to do is reset/reconfigure something which would cost 9500 minimum.
    Jan 2012
    #2628
    Hi! innova owners,
    I'm planning to buy a unit and I'm making a choice between innova or alterra. Although i thought that both vehicle are reliable and efficient.
    My question is what is the fuel consumption of the innova, regards with the 2.5dsl manual?
    I also want to share with you, about rocker arm. kung tungkol po sa pagkasira ng rocker arm sa, timing po problema yan that is according to my experienced. thanks!
    May 2005
    #2629
    I finally found why outside smoke (smell) is entering the cabin through the aircon. It is coming in through the passenger aircon (2nd and 3rd row). I tested this by just turning on the main aircon at the front and leaving the back aircon off (2nd and 3rd row).
    Anybody experience this ? Esp. G or V owners. I think most owners don't use the back aircon that's why they don't notice this.
    PS: 2011 " E " D-4D M/T
    Mar 2007
    #2630
    Try to visit Toyota Abad Santos and look for Jun Macaraeg. He will try his best to help you with minimal cost.
    GLD
    Mar 2007
    #2631
    Bro, I usually open the back aircon kahit sa minimum lang kahit ako lang magisa This will help the main aircon and will eliminate the odor problem.
    GLD
    Oct 2011
    #2632
    Quote Originally Posted by GLD View Post
    GLD
    Is he the manager of TAS?
    #2633
    Quote Originally Posted by crizelle23 View Post
    Hi! innova owners,
    Thanks for sharing. i'll be moving the car to toyota for the repairs.
    Feb 2011
    #2634
    di ko to na experience sa G ko. bukas man o patay yung 2nd and 3rd row AC.
    Oct 2003
    #2635
    I had this problem on my 2006 innova j gas. the problem is the aircon design at the back.
    Dito pumapasok yung outside fumes:
    1. Yung air flapper/side vents (not sure what this is called) located sa side ng rear bumper (left and right)
    2. yung bakal sa likod ng bumper. you will see this pag tinangal yung bumper. you will notice puro butas yung area na yon.
    Solution from TMP c/o Toyota Pasong tamo:
    1. Permanently takpan yung left and right flapper.
    2. Permanently takpan lahat ng butas sa bakal.
    Effect:
    Hinbdi kagad masara yung mga doors dahil hindi kagad makalabas yung excess air.
    Yung excess air lalabas sa left and right side ng dash board.
    After 5 years I sold my innova. However, I bought another 2011 innova j gas. Surprisingly, ganon parin!
    This time ako na lang gumawang solution 1 & 2. I used vulcaseal
    Dito sa office namin we have 3 innova j gas and 1 innova g gas. Lahat sila has the same problem on fumes entering the cabin. Im just surprise bakit hindi ito major issue sa tsikot.
    Apr 2005
    #2636
    I don't think the rear blower is getting air from the outside. It just probably recirculates the air inside the cabin. The rear blower is flushed under the ceiling so I don't see where it could get air from the outside.
    When you used vulcaseal mahirap pa din ba isara ang mga doors? As you mentioned hindi kasi makalabas ang air insude the cabin when you close the door. So the flaps and holes sa may bumper ay exhaust ng cabin air ang purpose.
    #2637
    yes there are air vents on both sides near the rear bumper but there is a thick insulating material in the form of a thick foam or some kind of material. I've seen this in my unit 2007 model. not sure about the earlier models. there are also rubber flaps that are normally closed and only opens when a door is closed. yes the fan at the back just re-circulate air inside but can suck air from 1 side of the vent. Have never encountered any smoke smell entering the cabin. The small holes on the rear bumbers are for the clips so if the clips are complete those holes are covered.
    what you can do is to close one side ( passenger side ) where the blower is located and leave the other side open.
    May 2005
    #2638
    It seems owners not experiencing smoke smell cabin through back aircon are at least G variant owners (and above).
    So far based on this informal (and extremely small sample), E and J variant are prone to this.
    G variant
    Ginnova
    SEALANDER
    ericson21
    V variant
    Louie_18
    E variant
    number001
    J variant
    wakin
    Oct 2011
    #2639
    haven't experieced any smoke smell from 2nd & 3rd row a/c vents w/ or w/out a/c. fyi.
    Aug 2011
    #2640
    Quote Originally Posted by wakin View Post
    Effect:
    ganyan din 2008 innova G namin. pag naka-On ang blower sa likod pumapasok amoy galing sa labas. never bothered to complain it sa dealer. pano nyo tinakpan sir? tinanggal nyo pa yung rear bumper? if yes, anong steps pag tanggal ng rear bumper? kung magawa ko kasi tatakpan ko yung iba para maminimize lang ang pagpasok ng amoy
    TIA
Toyota Innova Owners & Discussions [continued 3]
