1TR-FE (2.0) and 2TF-FE (2.7li) default from the factory, only need a 1SM battery.
What battery brand did Toyota put inside your Innova? AFAIK, Toyota sources their battery from Motolite and Oriental. Both companies supply them in similar looking black casing with dark blue + white colored labels.
Up!
I would really like to hear from G and V owners if you ever experience smoke from outside entering the cabin through the a/c system. I never had this problem with my Fortuner which had denso a/c system.
We are deciding whether to get a 2012 Innova G and want to make sure this does occur with the G variant.
Thanks!
ah i see bro. pero anu gamit mo pang linis dati sa upuan? mas mahirap ba linisin yung seats ng V? ako kasi nahihirapan maglinis sa sidings natin, G naman yung sakin. same pinanglilinis mo sa sidings at upuan bro?
sakin di pa natutuloy yung balak kong leatherette seat covers, probably this vacation ko, me pasok pa kasi ako sa school, di masyado maasikaso. tsk. BTW, anu yang sa seat covers mo bro, japan leather or german? may nakapagsabi kasi sa akin na japan leather daw mas matibay? yun kasi ang ipalalagay ko.
ayun sir Nognovot nga pala, naalala ko na! :D
V din sa inyo bro? mga V talaga mga bigtime. sarap maki-sakay sa inyo sa 2nd row!
panu sir nangyayare? bat di mo ipa warranty? sakin sir 2011 G owner ako, na experience ko yan minsan at napansin ko amoy usok sa loob, pag tingin ko sa AC ko, di pala naka circulate mode, nakalagay sa screen is yung arrow from the outside going inside kaya ayun naamoy ko usok sa labas so i pressed the circulate mode and it did not happened again to may innova. napindot lang siguro ng ermats ko yung isang button kaya pumasok sa loob amoy usok pero di na talaga na ulit.
Actually the air intake opening has rubberize foam lid on the edges, in due time this rubberize foam gets brittle and cracked. You can replace them with silicon rubber or rubber from tire interior cut-out AND/OR permanently sealing the opening with a glued thick plastic sheet.
try out some All Purpose Cleaners like Megs APC+ or Optimum Power Clean to clean seats and other surfaces. If it can clean this accumulated dirt then it should be easy to clean minor stains.
