Page 22 of 775 FirstFirst ... 121819202122232425263272122 ... LastLast
Results 421 to 440 of 15487
    Dec 2007
    #421
    Quote Originally Posted by first_light View Post
    You can remove the rust by brushing it (use fine steel brush) with WD40.
    Make sure it's clean. Then spray paint it with galvanized paint.
    If I'm not mistaken, blacksun25's issue is with the turbine side (where exhaust gas passes through), any paint to be used must be high temp (for exhaust system) so as not to burn the paint immediately. Be careful in using wd40 or anything similar, it is always flammable and may catch fire if some are still present and engine heats up.
    Dec 2007
    #422
    Quote Originally Posted by blacksun25 View Post
    Question lang mga ka-innova. Paano niyo na-miminimize yung rust or if prevent yung rust sa turbo niyo? Medyo pangit kasi tignan yung kalawang. I tried yung mga rust remover like WD40 then wipe off with paper towel pero I'm still not satisfied sa result. Thanks.
    blacksun25,
    Ako hinahayaan ko lang, ganon talaga yon dahil bakal at any ordinary paint will just burn-off (toxic pa yon pag nalanghap). Kung talagang bothered ka, use High Temp paint, if possible yung mataas na rating, say 1500 deg F para matagal magwear-off (but it will eventually wear off over-time).
    Jun 2010
    #423
    ask ko lang po kahit hindi exact yun sagot nyo, pag nagilaw na yun sa fuel malapit na maubusan ilang kms pa kaya itakbo non reserve na fuel? kahit hindi po exact kasi iba iba naman.. basta po magkaroon lang ako ng idea, thanks po. ^_^
    Mar 2011
    #424
    Quote Originally Posted by xinyuiyin View Post
    More or less upon reaching last 10 liters nag l light up ung fuel warning lamp. depende sa driving habit/traffic condition, malayo pa ang mararating nyan but don't take chances, mahirap matuyuan sa daan ;) (estimate: 8km/ltr = 80 kms)
    Sa experience ko kasi 45 ltrs & above na lang ang naikakarga ko after mag fuel warning na. (55 ltrs tank capacity natin)
    #425
    nasubukan ko na less than 2 liters na lang ang natira sa gas tank. this during the shell fuelsave challenge a few years ago. was able to fill-up more than 53 liters of fuel. syempre libre c/o Shell.
    Jun 2011
    #426
    Quote Originally Posted by Ginnova View Post
    Innova is classified as large vehicle pala. so price is P1800 for new paint protect. yes sucat na pinakamalapit kapag south. quarterly ang application.
    Salamat Sir! will check them out this weekend.
    Mar 2007
    #427
    Mga kainnova,
    May alam ba kayong nagaayos ng side stepboard na aluminum? Nakita ko na lang may balukutot sa bandang gitna, i just wonder kung mayroon ng nakapag pareform nito.
    Thanks.
    GLD
    #428
    Guys,
    tanong lang, magkano na ngayon roofrail ng innova? last time na nagtanong ako 7500 na. tama ba yung offer sakin?
    Jan 2009
    #429
    Quote Originally Posted by lowrider17 View Post
    Guys,
    had mine installed at toyota otis last September 11, 2010. discounted price of Php 7,373.90
    contact person: Criselle 09279732897 / 5641811
    God Bless!
    -dongb
    #430
    Quote Originally Posted by wolfmanila View Post
    God Bless!
    -dongb
    mas mura pa sa casa... sa banawe ako nagtanong 7500 offer sakin. anyway tnx for reply sir wolfmanila
    Jul 2011
    #431
    OT lang po. bakit ganun di ko makita mga pictures dito sa thread, pili lang lang nakikita? sorry po NOOB!!!
    Mar 2011
    #432
    Any one here na owner ng Innova G naka-experience na di nagpafunction ang second na engine key. Nacheck ko na ung battery ng key, ok naman. Nalaman ko na di nagpafunction ung second na susi, nung ibigay ko kay misis para nasa kanya ung pangalawang susi so that para kung emergency meron sya. Kaya lang, ayaw talagang gumana. Ung dinadala kong susi, lahat gumagana, alarm, door lock/unlock, door ajar. Ano kaya mga possible na solution? Thanks.
    #433
    Quote Originally Posted by MrQ5 View Post
    baka di ka naka log in, try to log in first para ma view mo yung mga pics posted.
    hth
    #434
    Quote Originally Posted by brench View Post
    baka di naka-program yung spare key mo. have it checked by casa during your pms.
    Jul 2011
    #435
    Quote Originally Posted by ryan jimenez View Post
    hth
    naka log-in nman po, ty sa reply.
    cnu po ba naka pag adjust na ng level of sensitivity ng impact sensor ng TVSS dito, wala kasi budget pag nagpakabit pa ng code alarm
    #436
    sadly walang sensitivity adjustment ang TVSS. kinalas ko na dati yan. its mounted sa likod ng instrument panel.
    actually sensitive yung shock sensor if you tap the casing itself. kaso its mounted to a solid bar inside the dash kaya mahirap matrigger.
    Jul 2011
    #437
    ty sir ginnova for the reply, kaw din yung nabasa ko na nakakita ng sensor ng TVSS, baka kasi may sumubok na iba kaya up ko lang,,,,:help2:
    baka sir may step by step ka pag kalas ng dashboard mo pa post naman TIA
    #438
    I created a diy procedure a year ago how to remove the dashboard. here's the link.
    http://tsikot.com/forums/toyota-cars...removal-71750/
    Mar 2011
    #439
    Thank you Mr. Ginnova. Ipa-check ko na lang 'to on my 30T PMS.
    Jul 2011
    #440
    ty uli sir!!! more power to you...
    kaya lang Innova G po saken eh, meron kaya dyan panu tinanggal yung a/c switches panel ba
    tawag dun. nakakatakot kc tanggalin. Yun nga lang a/c filter this week ko lang nalinis pero
    matagal ko na try, this with more exert force to push sa glove box to release/remove it. our
    INNOvie mag one year na kc.
Toyota Innova Owners & Discussions [continued 3]
