Results 2,621 to 2,630 of 15338
March 5th, 2012 11:54 AM #2621
March 5th, 2012 11:56 AM #2622
- 11
- Aug 2011
- 338
March 5th, 2012 12:51 PM #2624^baka cause ng knocking ay gasoline or station na pinapakargahan. Try nyo lang pong magpalit ng gas station or ng brand na kinakarga pag naayos na po yung sasakyan nyo. May experience kasi ako dati although sa ibang sasakyan na pag shell unleaded ang nilalagay ko, ang lakas ng tope or ng knocking sound. Pero pag caltex silver o kaya petron xtra unleaded e walang tope.
- 11
March 5th, 2012 01:04 PM #2625hi! hindi po gasoline issue alam na nila yung sira may na rocker something na nasira dahil kulang sa engine oil. nag over heat kc. everytime kc na kinakausap ko sila patagal ng patagal yung date na matatapos last time na tinawagan sila hindi daw nila alam kailan matatapos no explanation basta tatawag na lng sila pag tapos na. kaya naghahanap ako ng ibang shop.
thanks
March 5th, 2012 02:16 PM #2626
Ibig ba nilang sabihin ay natanggal sa position ang isa or dalawang rocker arm? Shimless ang VVTI ng Innova kaya misan nadi-dislodge talaga yung rocker arm. I have experienced this when I used very thin synthetic oil, ginawa lang sa Shell station ng less than an hour, re positioned rocker arms and tightened back the bolts on overhead cam shaft and off I go. From then on, palagi ko ng sinisilip yung rocker arms every 6 months by removing the valve cover.
If this is the case with your car, my worries was your mechanic, was now having problem with timing. Or worst your overhead cam shaft is really faulty.
Did they do OBD-II scanning before?
- 11
March 5th, 2012 03:01 PM #2627
March 5th, 2012 08:29 PM #2628
Hi! innova owners,
I'm planning to buy a unit and I'm making a choice between innova or alterra. Although i thought that both vehicle are reliable and efficient.
My question is what is the fuel consumption of the innova, regards with the 2.5dsl manual?
I also want to share with you, about rocker arm. kung tungkol po sa pagkasira ng rocker arm sa, timing po problema yan that is according to my experienced. thanks!
March 6th, 2012 10:03 AM #2629
I finally found why outside smoke (smell) is entering the cabin through the aircon. It is coming in through the passenger aircon (2nd and 3rd row). I tested this by just turning on the main aircon at the front and leaving the back aircon off (2nd and 3rd row).
Anybody experience this ? Esp. G or V owners. I think most owners don't use the back aircon that's why they don't notice this.
PS: 2011 " E " D-4D M/T
March 6th, 2012 10:36 AM #2630
Try to visit Toyota Abad Santos and look for Jun Macaraeg. He will try his best to help you with minimal cost.
GLD
Puwede siguro gapang ang wire sa space ng rear hatch lifter/struts papunta sa rear bumper, tapos...
